so, I'm back. regretted selling my 89 for quite awhile and found this locally and jumped on it. plan on doing gears/shafts and steering soon. some specs:
1991
5 speed
4.0ho
d30/d44 stock
rustys l.a. kit. 7'-8' springs
fiberglass front fenders and bedsides.
bumpers f+r.
little stuff here and there.
here's a couple pics. the zj is also mine.
Image Not Found
Image Not Found
and the one i sold to m1a1tankertom(
Image Not Found
the rear ujoint blew the caps off itself the other day. not sure why. when i was looking at the yoke, there was nothing on it to keep the ujoint centered. usually there are little raised spots that hold the caps from moving? the only thing hold the ujoint to the yoke are the 2 straps, and its pretty impossible to get it centered and stay there. any ideas?
Yes, there should be. There are raised tabs on the pinion yoke u-joint cup to hold them in. You have a D44, right? I'd pick up and install a new u-bolt pinion yoke and seal like this one on Ebay HERE.
Since you have a D44 there's no need to worry about the pinion crush sleeve because the D44 uses shims. Just install the new yoke and re-torque to specs.
thanks for the link/info. i will be picking one of those up next week
getting 4.88s put in the d44 monday. looking for a non-disconnect hp30 to swap in the front then gear. I'm just going to rebuild the factory limited slip with aggressive clutches. for the time being i put my 33s from the zj on it. also ordered the 97-01 front end. should be here in a week. when that arrives ill being doing the body work and picking out a color. pics coming soon!
  • 2 months later...
  • 2 months later...
Got some work done. Motor mounts in, new tranny fluid, paint, d30'abs model with 4.88s, raised sway bar mounts, LCD skids...little stuff here and there. Putting off the full widths for a different rig. Let me know what you think!
Image Not Found
Image Not Found
Now with some 36" tsl's.
Image Not Found
:agree: That's a great example of a different twist on body panels! I'd love to have an excuse to put a set on an MJ but I've got plans for all my trucks. Guess that means I'll need to get another someday... I think it would be a great alternative for our rusty trucks of the north. Yours looks great!
