MancheKid86 Posted April 5, 2012 Author Share Posted April 5, 2012 BEST UPGRADE YET! i do the shock mounts after school tomorrow :banana: then she's on the road Link to comment Share on other sites More sharing options...
MancheKid86 Posted April 7, 2012 Author Share Posted April 7, 2012 Link to comment Share on other sites More sharing options...
shawn Posted April 8, 2012 Share Posted April 8, 2012 :thumbsup: Link to comment Share on other sites More sharing options...
MancheKid86 Posted April 10, 2012 Author Share Posted April 10, 2012 had the death wobble, what an experience, my jeep turned iinto an eep and I'm shy of more than a few pairs of pants, ive narrowed the problem down... (shhh) i think its my track bar :shake: so.. i installed this steering stabilizer to mask the problem until i can buy another one forgot to post pics of my shocks mounted :yes: now time to start on odds and ends, got my wiring harness adapter installed re did all the connections on my positive + negative cables for my amp got my subs installed. i had to remove the top of my center consol to get it in, then re-attach it more to come, i need to fix my speedo Link to comment Share on other sites More sharing options...
camjeep3 Posted April 10, 2012 Share Posted April 10, 2012 Good luck with the Death Wobble... and as far as your track bar, we werent crazy when we said it wasnt right. Either way the truck looks good, keep up the good work. you are going a whole lot faster than I am Link to comment Share on other sites More sharing options...
MancheKid86 Posted April 11, 2012 Author Share Posted April 11, 2012 decided to join the "cool" club put my other 97+ mirror on :banana: this is what i mean when i say i turned my jeep into an eep XD during the install this happened, i don't know how but it did, took a razor blade to the end of it until it popped back in while i was out i decided to investigate why my left speaker wasnt working, hmm... :wrench: Link to comment Share on other sites More sharing options...
Blue88Comanche Posted April 11, 2012 Share Posted April 11, 2012 are those electric mirrors, or manual? Link to comment Share on other sites More sharing options...
MancheKid86 Posted April 11, 2012 Author Share Posted April 11, 2012 used to be electric :shake: now they are manual :thumbsup: went to a meet n greet today, bout 4 people didnt make it, but it was alright, all different rigs were there Link to comment Share on other sites More sharing options...
MancheKid86 Posted April 17, 2012 Author Share Posted April 17, 2012 went 4x4ing with my buddy, but i sketched out and turned around and he decided to keep going ended up rolling his truck down the cliff so went up today, got to say i told ya so, started cutting his truck outta the side of the mountain, luckily there is a trail below, here's some pics, doesnt look to steep from this angle winch to move all the logs holding him up and to put it into perspective, hes standing straight up almost out going out on wednesday to finish the job and here's a pic of my manche :D Link to comment Share on other sites More sharing options...
Dirteatr717 Posted April 17, 2012 Share Posted April 17, 2012 If I were you I wouldnt weld on your rear shock mounts like that, I just put the u bolts through the plates and bolted them up, it looks like you have another 1" or so left on the ubolts to do it too Link to comment Share on other sites More sharing options...
MancheKid86 Posted April 17, 2012 Author Share Posted April 17, 2012 U bolts weren't the proper size, they bent the radius too small, Trust me they are not coming off And the shocks were an after though the bolt holes didn't lime up where I wanted them, And the welds are burned in there deep a lot stronger than ubolts would be :P :thumbsup: Link to comment Share on other sites More sharing options...
MancheKid86 Posted April 18, 2012 Author Share Posted April 18, 2012 new project, do alignment proper, chewed through a brand new set of rubber in roughly 2 weeks TRE's rusted solid, a bit of seam foam deep creep and this handy vice with the pipe bender and they came out like pie clamp a vice grip as hard as possible on it, vice grip in tube bender, apply all weight on crescent wrench cleaning the inside with the deep creep (breaks down rust) purple power :D all done, 1/8" toe in with tape measure gotta start this project some time Link to comment Share on other sites More sharing options...
MancheKid86 Posted April 19, 2012 Author Share Posted April 19, 2012 recovered my buddys vehicle, its done, but its in his yard now, parts truck jeeps to the rescue (well mostly jeep obsessed, couldnt have done it without him) clearining out the rest of the tree's jeep obsessed doing his thing a happy 4x4'er no more forest left, who wants some fire wood? back on the trail tire changed my rig down, corroded wires +loose terminal on the road again!! [rockin] Link to comment Share on other sites More sharing options...
89Comanche4x4 Posted April 20, 2012 Share Posted April 20, 2012 wanna do my alignment? nice recovery Link to comment Share on other sites More sharing options...
MancheKid86 Posted May 15, 2012 Author Share Posted May 15, 2012 finally got my speedometer going swaped gears, took a torch to it, hammered it out with punch while stacked up in sockets, and install used a vice to press back in, don't have a pic of the final product but here is the left overs dash ripped apart, connected the other end of the speedo cable, in the process i some how made my oil pressure sensor on my gauge stop working, will fix in the future look all my interior lights work :yes: changed my spark plugs look at the gap old vs new! time to take the old man topper off, summer is here found some rust :( upgraded from my non air box, warm air intake, to the stock cold air intake adjusted my e-brake more, I'm almost running out of adjustment but atleast i don't roll down hills anymore whats this thing do? mine kills my truck when ever i plug the other end in more to come, almost snagged a set of brand new jks acos coil spacers, too bad the seller had a winch, he said otherwise they'd be mine. oh yeah. i got COMANCHE OF THE MONTH!!!! viewtopic.php?f=3&t=35548&p=350060#p350060 Link to comment Share on other sites More sharing options...
ComancheKid45 Posted May 16, 2012 Share Posted May 16, 2012 That thingy is the EGR solenoid. don't as me how it works though....lol Keep up the progress :wrench: Link to comment Share on other sites More sharing options...
MancheKid86 Posted May 24, 2012 Author Share Posted May 24, 2012 went 4x4ing and i parked at the top of the mountain to enjoy the view, starter gave out on me, luckily i parked on a slope and my buddy with gaintism, he gave me a push and off we went. so out comes the starter bad solenoid vs good soleniod back together and re-installed ran a new ground while i was at it on the road again fixed my IAC, pulled it out cleaned it up, took a screw driver and pried the seized solenoid free, good as new, lost camera somewhere today, no pics :( Link to comment Share on other sites More sharing options...
MancheKid86 Posted May 25, 2012 Author Share Posted May 25, 2012 enjoyed the simple things in life, cleaned it head to toe just to get it muddy again I'm also selling my winch, at the moment I'm stuck in college, i need brakes and exhaust more than my winch, once I'm done school ill be a 2nd year aircraft maintenance apprentice, will make enough money to get another one Link to comment Share on other sites More sharing options...
MancheKid86 Posted May 28, 2012 Author Share Posted May 28, 2012 went about doing my brakes today, worse than i imagined, went 4x4ing 2 weeks ago and i heard a clunk and then my rear locked up, my inspection before putting my professional grade pads on turned out displeasing good side, don't know where all the moisture came from, brake res. is full as is my rear diff (which has black fluid in it now :???: ) so much grease inside any takers of what it could be? (water from mudding?) just a small amount of the grease inside this is what fell out the BAD side looks can be deceiving, keep scrolling BAM found the problem! i need new drums this is what fell out on this side... yes thats a clutch dog, brake pads and retaining spring, my old pin that held the retaining spring in failed from the e-brake arm shearing it in half GOOD VS. BAD and this is where i called it a night well, looks like I'm off the road for a few days, I'm broke, atleast i won't spend money on gas :shake: atleast my lug nuts are still good!! Link to comment Share on other sites More sharing options...
vaquaro Posted May 28, 2012 Share Posted May 28, 2012 :wrench: Riveted brake shoes / pads the only way to go :yes: :yes: :yes: Link to comment Share on other sites More sharing options...
knever3 Posted May 28, 2012 Share Posted May 28, 2012 Have you checked your axle seals and wheel cylinders for leaks? Brake fluid will EAT friction material turning it into paste. I completely disagree, bonded brake shoes are much better since you have more wear area before the rivets ruin your drums when ground down. Whatever works for you I guess. Glad to see you got it fixed up! Link to comment Share on other sites More sharing options...
MancheKid86 Posted May 29, 2012 Author Share Posted May 29, 2012 seems like i have an admirer, found that a few days ago after checking my diff i found the gear oil was black inside, i made er puke :brows: the hard ware, i only picked up one drum, since the other one was still usable all bare fully loaded drums back on good to go my work station, dam rain :shake: just have to wait for the diff cover to cure then i can tighten the diff back up and put fresh gear oil in, also found a leaking axle shaft seal so i used black rtv to solve that problem, will be cured tomorrow as well, then bleed brakes and I'm on the road again Link to comment Share on other sites More sharing options...
MancheKid86 Posted June 23, 2012 Author Share Posted June 23, 2012 went 4x4ing about a month ago, bent my LCA mount, finally let go bent + twisted straight enough figured id spend more time bracing the old bracket, so i made a new one out came the plasma cutter old vs new mocking it up, i think it fits pretty good :thumbsup: final draft, cambered the edges to make more ridged look at that not so good flex! welding it on bolted back into place :D Link to comment Share on other sites More sharing options...
87Warrior Posted June 25, 2012 Share Posted June 25, 2012 welding it on That's your problem right there. Those LCAs are not designed to twist, therefore your axle mount did. Weld a johnny joint to the end of the LCAs and you won't twist off any more brackets. Nice work on the new bracket. Looks like an exact replacement! Link to comment Share on other sites More sharing options...
MancheKid86 Posted June 29, 2012 Author Share Posted June 29, 2012 tid bit of an update decided to reseal my axle shaft, p/o cheaped out and used a destroyed seal when re-doing the axle first time grinding off a bearing + retainer, watched lots of vids, every one did it straight across which scored the shaft and destroyed the retaining plate i did it on an angle, worked perfectly see not a scratch! pressing it on, my man power didnt have enough force to press them on, ended up bending the bar took it to school and used the 12 ton hydraulic press took about 5 seconds to get it on the last inch all pressed on and ready to install also replaced my fuel filter, I'm assuming the original was still on also gapped my spark plugs to .035 more to come Link to comment Share on other sites More sharing options...
