aquiring93 Posted November 9, 2011 Share Posted November 9, 2011 I am going to be investing in some new shocks soon and I was wondering what the best for my money would be if I wanted something that will give me a firmer ride with less lean around the corners. Thanks for the help. :wrench: Link to comment Share on other sites More sharing options...
89JeepMJ Posted November 9, 2011 Share Posted November 9, 2011 I have monroe sensa trac coil overs on my MJ. I love them best ones i got ever got in my opinion. Link to comment Share on other sites More sharing options...
Motion Offroad Posted November 9, 2011 Share Posted November 9, 2011 Bilstein 5100's. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 10, 2011 Share Posted November 10, 2011 OMEs. Link to comment Share on other sites More sharing options...
jeepdoggydogB Posted November 10, 2011 Share Posted November 10, 2011 OME's as well :cheers: Link to comment Share on other sites More sharing options...
zagscrawler Posted November 10, 2011 Share Posted November 10, 2011 Not to got off subject but ive always thought shocks to help body role to be a small bandade, specially in long corners. just my opinoin but spring presures and anti-role bars are what makes a vehicle perticularly stable in corners as shocks even with all the high end complicated valving slow down the effect. The way i see it is if you sit high (high center of gravity) compared to passenger cars springs, and where they sit compared to weight over axles, are what in the long run control body role, the shock may slow it down when weaving but onces you set the weight in motion it will lean untill stoped by equal forces (springs), the shocks offer valving that is supposed to recognize this but i believe this to be a bunch of crap unless computer controled and with a back up presure source. The reason i say this is for example if your are on the freeway and cornering at speed and hit some bumps what keeps the shock from giving until the spring, or combiniation of springs via sway bar, stops it... It is a give and take and for now and maybe someday it won't be, if you want flex you need low spring rate if you want to be stable in corners you need higher spring rates however achieved. I'm sure you can find a happy medium but a cut and dry solution is bout imposible. Just as a side note if you do go with a stiffer valved shock you will feel it on the rocks for sure...enouph to be uncomfortable...maybe not but if i were you i would beef the hell out of my sway bar and get good disconnects for it lol. good luck Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 10, 2011 Share Posted November 10, 2011 :agree: If your goal is to to control body roll and obtain better handling, shocks alone won't do it. To do it right you'll need a beefier V8 Grand or XJ Country sway bar, firmer front coils (OME here too), a larger Teraflex adj. track bar, ZJ solid tie rod, beefier WJ LCAs, and a set on MT springs on the back is what I did. Works well, and all bolt-on components. Link to comment Share on other sites More sharing options...
com_mako Posted November 10, 2011 Share Posted November 10, 2011 Bilstein 5100's. :agree: Link to comment Share on other sites More sharing options...
88pioneer Posted November 11, 2011 Share Posted November 11, 2011 Bilstein 5100's. :agree: 100% Link to comment Share on other sites More sharing options...
mnkyboy Posted November 11, 2011 Share Posted November 11, 2011 I would get some nitro shocks,I had RRO hydro shocks and with the sway bar I still got a lot of body roll. I went to skyjacker nitros and it stiffened it up a lot,even with the sway bar disconnected its very stable. The ride is a bit rough now though Link to comment Share on other sites More sharing options...
carnuck Posted November 11, 2011 Share Posted November 11, 2011 I run the NAPA Gas Grande shocks made for commercial vehicles. Link to comment Share on other sites More sharing options...
