cody4359 Posted October 24, 2011 Posted October 24, 2011 sounds like it might work but what about frying the grease when welding the tabs on, and would balancing be an issue? http://www.ironrockoffroad.com/Merchant ... y_Code=PFX
89eliminator Posted October 24, 2011 Posted October 24, 2011 no thanks. what if you snap a u-joint? then you got to cut all those "things" off.
500 MJ Posted October 24, 2011 Posted October 24, 2011 People will make anything just to turn a profit...wow.
Geonovast Posted October 24, 2011 Posted October 24, 2011 Aduuuur I've seen products that made more sense on kaleco.
mule13 Posted October 25, 2011 Posted October 25, 2011 Had a old mud truck that had a wore out drive shaft that would throw the cap out we just tacked a few places around the cap to the shaft ears,whenever it needed changed grind off the welds and change.
dfreeman616 Posted October 25, 2011 Posted October 25, 2011 Aduuuur I've seen products that made more sense on kaleco. uhhh...WTF? :huh???:
87Warrior Posted October 25, 2011 Posted October 25, 2011 Aduuuur http://inlinethumb11.webshots.com/43978/2059412130104836601S425x425Q85.jpg I've seen products that made more sense on kaleco. uhhh...WTF :huh???: Haven't you ever heard of folks welding their gears? :yes: :rotf:
87Warrior Posted October 25, 2011 Posted October 25, 2011 thats the wrong gears Maybe that is why I keep burning up my clutch. Can't say if say if welding helped my traction at all since I can't get the rig to move. :dunce: :thwak:
Donkey Posted October 25, 2011 Posted October 25, 2011 i used to tack my d30 and d44 caps, the stub shafts would wallo out and id lose the caps eventually the ears would break on the stub and i just get another stub grid down the tack on the main shaft and reassemble.
