So the motor blew on my MJ. I am starting the build on making my 88 comanche into a 2000 comanche using everything from drivetrain wiring carpet to fenders and doors should be fun!! i just thought i should write up something and show everyone the progress!
so i picked up a 2000 rolled xj to get the parts from:
pulled the two in next to eachother and started ripping the MJ apart and then got it all gutted had a little rust to deal with but no big deal:
all primed:
painted :
and now onto the fun stuff cut the brackets off to allow for room for the new steering colum bracket:
started mocking the steering column bracket in:
had to nip the corner off:
and started to get some wiring in:
XJ torn apart:
Relocating the steering column hole through the fire wall :
Made a plate to fix the hole:
Started with the insulation:
And did a bit more insulation and pad... then started mounting the new steering column bracket :
made some plates and welded them on to the existing flange to mount the upper part of the dash:
got the dash in and and mounted:
started looking at where the ebrake and shifter go:
Sorry guys I missed a couple inbetween pictures like doing more insulation and the lower mounting holes for the dash... I will be doing more work on it today so look for more updates tonight
Thanx for looking
Justin
thank you and will do :) I have been doing pretty good soo far
and guys sorry about the crappy pic all i have is a scratched up old i phone so pics arent too good
Looking good. I can't wait to be doing this swap soon! How many hours would you say you have to get it to this point? Good Luck and keep us posted.
thats a really good question haha I'm just going to take a guess:
tear apart of mj =about 4-5 hours only because i have disassembled quite a few mjs/ xjs so i know where everything is and what exactly needs to be pulled... i know the first time i pulled one apart i took a bunch of stuff apart that didnt need to takin apart
sanding and painting= about 2 hours
custom fab/relocation of things= about 4 hours lol took my times
installing of dash and steering column bracket = about 3 hrs it was kinda a pita
misc work on it = about another say 4 hours
so so far kinda just guessing i have i have about 17 or 18 hrs i think haha havent really been keeping track
"a little rust to deal with.....really? Are you trying to be a jerk? I suppose you could make it up to us unfortune rusty MJ owners by borrowing a better camera for your next round of pics. I'll have more hours of rust repair in my truck then you'll have in your whole project!
Really though, looking foward to see how this one shapes up! (assuming you get a better camera of course) image_209027.gif
Just a quick question/reccomendation if that's just primer on your floor board you need to seal it with some sort of top coat (paint, por15, rhino liner, ect) as primer is pours and won't protect your floor from moisture,,....
No i wasnt trying to be a jerk i guess i am one of the lucky ones to have gotten my 3rd MJ with little to no rust on it... i guess thats one positive to having worked at a jeep parts shop ;) (i don't anymore tho) and yeah yeah yeah i will try and get a better camera (although i figured that most of you know what you are looking at in the pictures even though the quality isnt so good but still shows what you need to see) but yes agreed i will try to get a different camera
and yes it primed and painted and i also put another coat of paint right before i lay the insulation in but thank you for the advice...CHEERS
This is an unfortunate truth for many of us with rusty MJs. I've been doing a similar conversion to my '88MJ (97+ Interior, front end, doors, etc) and I've spent more time cutting out rust/rot and sealing up the frame to prevent further rust than I have actually getting the 97+ XJ parts in the MJ and fitting them up.
Good work,
Thought I'd let you know that I received a vision from God, he said anyone who completes this swap gets to hang out with John Wayne and Steve McQueen in heaven and you all get to go wheeling together in a 5 trillion acre off road park designed specifically for MJs. It even has a snow cone stand. :wrench:
Good work,
HAHAHA can't wait.... that would be great but on the other hand the SWAP reallly isnt that hard it is just very time consuming with alot of this image_209027.gif this :cheers: and this :huh???:
and i guess i should tell how i even got this thing..... a guy called my shop and asked if anyone was interested in a comanche so being me i said of course i will always look at one...so he brought it in and explained to me that it couldnt go over 25 mph but overall the MJ was in great shape very mineute amouts of rust and also not many dents. (I already knew what was wrong with it, having had prior problems with xjs and mjs) i asked him what he wanted and he said "there is something seriously wrong with thing so $450?" I counter offered at $350 and and in my hand the title came and out of the parking lot he went :yes: :yes: After had been gone for about 30 minutes i came back out of the shop with a sledge hammer :wrench: and went straight for the cat :idea: spent about 2 minutes smashing the cat....then hopped in the cab and started her up! And guess what Revved up like a charm :banana: took it around the block and everything worked great!!! I was very happy with my purchase :clapping: and i remember thinking to myself
"if only this guy knew he would be doing one of these :wall: and i do one of these :banana:
well she has been through a lot of running and a ax 15 swap and used motor swap but now this swap
sorry guys havent been updating... i have been dealing with fuel issues on another xj and mine so lots of gas but i got it figured out :)
but the progress on mine:
I got the 2000 gas tank installed where the spare used to go
fuel lines all extended the motor tranny and tcase are in
steering column installed and wiring hooked up
the engine wiring harness computer fuse block and vacuum lines are all done
the brake lines are all done( used 2000 brake booster and proportioning valve)
did a tranny fluid change with filter
New spark plugs
lots of the small time consuming tedious stuff is done but more to come
I will try and take some pictures today and get them up
ok so i feel like a jack @$$ and thought i would remember this but i can't lol the ac lines that go from the compressor one goes to the top of the accumulator and one goes into the firewall.... question is does the one that goes to the accumulator go to the left or the right spot on top on the accumulator? i think the one that comes from the ac goes to the left and the other coming out of firewall goes to the right spot on top???? am i right?
The line from the firewall goes to the port nearest the switch on the accumulator. The line from the compressor goes to the port nearest the fender.... HTH!
Thanx backdraft.... I got that figured out... Now on to the next thing I got everything hooked up besides some interior lighting(instrument panel wire for dome lights and wire for rear speakers nd light then the grounds under the seats are not connect thought they are just for seatbelt ground but not sure) and the tail lights are not connected (still have to extend the wires to reach) I extended the fuel pump wires with some wires that were for the rear door(rear wiper lic light and defrost) I hope I didn't mess something up there... But the problem is it will turn over but no fuel... I don't even hear the pump turn on when key is in acc... I dunno if I was just getting anxious to hear it run and I should attaching more but I thought I should have it connected enough to start???? Any help is greatly appreciated thank you
Justin
Oh I am using the stock xj tank sender and pump too
Beware, if you just hacked out some of the back door wiring your electric locks and windows won't work. The XJ has a crazy cross over harness for those.
I would double check your grounds and that the fuel pump is actually getting power. IIRC, the fuel pump ground on the XJ was near the rear seat on the driver side.
I was in your position. I was getting it to turn over, but wasn't getting fuel. I think it ended up being a bad or unconnected ground.
I know I had one on the rear harness toward where the lock/window connections are, but I think it was on the passenger side. I think there was another one in the very back toward where the rear wiper connection and tail light connections were on the driver side; I remember that one because I had to ground it on the frame rail. I'm not sure how it would be without the power windows.
ok so my tail lights are broken so i wanted to make some led ones... what i got is 3 lead leds for the stop brake and turn and i got another "driving Light" led for the reverse lights but I'm not to sure how to hook them up because the stock xj used a 3 light system verses me using a 2 light system....i tried wiring them a couple ways but won't work.... this is how i tried first
What happens is when u turn on the turn signals it acts as if the emergency flashers are on... so then i tried this (just removing on major on one side)
Then everything works fine like that but when the brake lights are on i get no blinker??? any help again is greatly appreciated
thanx
Justin
Oh someone had mention a foreign to American tail light module or something?
