comanchekid
Contact Methods
AIM
justin44kxf
MSN
yzskater4
Yahoo
jeepkid444
Location
evergreen colorado
comanchekid's Achievements
Can Spell Comanche (2/11)
making led tail lights need help
comanchekid replied to comanchekid's topic in MJ Tech: Modification and Repairs
ok so i got them working ended up making my own "module" out of 4 relays wired together the only problem is when the blinkers are on...i get a smaller blink on the opposing side???? everything works fine except for that -
bump? -
all of my grounds are connected to one should i make more grounds? -
. i got a converter and wired it in and nothing...?? maybe i need more grounds? the convert wires are white=ground red=brake green=right turn yellow=left turn brown= park/tail so i wired it where i cut off the bulbs with all the grounds into one on the frame.. i took both the majors (brake i believe) and wired them to the red wire then the right turn wire to the green... left to the yellow...and took both minors(running lights) and hooked them to brown But i get nothing also the reverse lights are not hooked up but the grounds are... i don't know if that helps any but I'm kinda lost what to do someone help -
have someone sit in front of your jeep and watch all the steering components while you turn it back and forth just to the point of resistance u don't need to really turn the vehicle... could be a tie rod end or really check the track bar
perfect thank you :) now the question is there are seperate wires going to each tail light on the xj... do i need to go back further before the wires split and wire it in there or is there a different way? -
2000 XJ power train in my MJ
comanchekid replied to BHelton's topic in MJ Tech: Modification and Repairs
how did you wire the lights? I'm needing some help doing it viewtopic.php?f=2&t=31899 -
ok so my tail lights are broken so i wanted to make some led ones... what i got is 3 lead leds for the stop brake and turn and i got another "driving Light" led for the reverse lights but I'm not to sure how to hook them up because the stock xj used a 3 light system verses me using a 2 light system....i tried wiring them a couple ways but won't work.... this is how i tried first What happens is when u turn on the turn signals it acts as if the emergency flashers are on... so then i tried this (just removing on major on one side) Then everything works fine like that but when the brake lights are on i get no blinker??? any help again is greatly appreciated thanx Justin Oh someone had mention a foreign to American tail light module or something? no clue where to find that i call some auto parts and they have no clue
ugh now tail lights
just curious what ground was it for you? and the donor didnt have power locks... so I'm not sure
Thanx backdraft.... I got that figured out... Now on to the next thing I got everything hooked up besides some interior lighting(instrument panel wire for dome lights and wire for rear speakers nd light then the grounds under the seats are not connect thought they are just for seatbelt ground but not sure) and the tail lights are not connected (still have to extend the wires to reach) I extended the fuel pump wires with some wires that were for the rear door(rear wiper lic light and defrost) I hope I didn't mess something up there... But the problem is it will turn over but no fuel... I don't even hear the pump turn on when key is in acc... I dunno if I was just getting anxious to hear it run and I should attaching more but I thought I should have it connected enough to start???? Any help is greatly appreciated thank you Justin Oh I am using the stock xj tank sender and pump too
ok so i feel like a jack @$$ and thought i would remember this but i can't lol the ac lines that go from the compressor one goes to the top of the accumulator and one goes into the firewall.... question is does the one that goes to the accumulator go to the left or the right spot on top on the accumulator? i think the one that comes from the ac goes to the left and the other coming out of firewall goes to the right spot on top???? am i right?
sorry guys havent been updating... i have been dealing with fuel issues on another xj and mine so lots of gas but i got it figured out :) but the progress on mine: I got the 2000 gas tank installed where the spare used to go fuel lines all extended the motor tranny and tcase are in steering column installed and wiring hooked up the engine wiring harness computer fuse block and vacuum lines are all done the brake lines are all done( used 2000 brake booster and proportioning valve) did a tranny fluid change with filter New spark plugs lots of the small time consuming tedious stuff is done but more to come I will try and take some pictures today and get them up
thanx i will probably do that down the road this is kinda budjet thing for now... i endend up moving the exhaust and putting the stock cherokee tank where the spare tire would have gone..ill try and get some pics up later
