btm24 Posted May 30, 2011 Posted May 30, 2011 A friend of mine helped me Installed the front part of a RC 4.5" lift the morning of (4:00 am) my high school graduation as a graduation present. The parts we installed are 4.5" coils, lower control arms, shocks, and Swaybar drop brackets. Since then there has been a lot of creaking up front when going over much of any thing. I was wondering if there was any thing i could grease up to make this creaking go away? Or is this just the new parts settling in place? Thanks Brandon
SW86 Posted May 30, 2011 Posted May 30, 2011 everything torqued to spec?? I'm not aware of anything you can grease that you just put on. you could go back through everything up front and grease it. now how about some pics of the new stance :brows:
philbert001 Posted May 30, 2011 Posted May 30, 2011 Did you loosen the upper control arms before everything went in, then re-tighten them at ride height with everything in place? On that note, did you tighten everything at ride height? Or did you torque it all down with the axle at full droop? If you tightened everything at droop, (Or if you didn't loosen the uppers first), it could be twisting the bushings into their new home at a different ride height.
btm24 Posted May 30, 2011 Author Posted May 30, 2011 Nothing is "torqued" but tight with air tools. I went though and tightened every thing down before I put the tires on and set it on the ground but the front 2wd axle was held up by a full size jack. But it is posible that i missed something seeing as how it was 4 in the morning and had been working on this for like 8hr's. To put on the lower control arms we had to loosen and take off the uppers then we put them back on. Do you think thats good? Come tuesday i have access to a lift at my old high school thanks to the shop teacher so ill be able to do any thing that is needed to stop the creaking. Thanks Brandon Oh and ill have pics up on this thread my next post :D
philbert001 Posted May 30, 2011 Posted May 30, 2011 You took the uppers completely out, or you took them off at the axle? What about the frame side? Also, with that much lift, you'll need an alignment. (It'll be toed in pretty good at 4.5 inches) And you should be thinking about and adjustable track bar too. (Or at least drill a new axle side mount hole.
btm24 Posted May 30, 2011 Author Posted May 30, 2011 I just took them off the axle. And yeah my alignment is a bit off ill be getting that done soon. Also i can think all i want to but its gonna be a tad before i will be able to afford the adjustable track bar and such. I don't think its gonna stay this high either I wana go higher as soon as i get a job Brandon
Hubbell Posted May 30, 2011 Posted May 30, 2011 Don't pay good money for an alignment. Do it yourself. Plenty of write-ups on the web and it's very easy to do in your driveway.
philbert001 Posted May 30, 2011 Posted May 30, 2011 I've been tape measure aligning jeeps for years. Like Hubbell said, find a write up. And as far as the track bar goes, just drill a new hole in the Axle side mount towards the drivers side a half inch, or whatever it takes to re-center the axle. You'll need to put a nut on the backside, as the tab-nut will no longer fit in there and line up with the bolt. I ran my XJ with a stock track bar for like a year, (DD and wheelin it pretty hard too!), and never had issues with just moving it over!
Automan2164 Posted May 30, 2011 Posted May 30, 2011 Screw the hole in the axle mount. That's something for experienced dudes who know how to do it properly. Even at that, with whats riding on top of that axle (your @$$, your friends @$$, your womans @$$, and possibly other drivers on the road) the $150 for an adjustable trackbar should be a non issue. Don't hodge-podge and cut corners on lifts. Good way to get yourself hurt and possibly others. Rob
Incommando Posted May 31, 2011 Posted May 31, 2011 Rough Country's own instructions for the 4.5" lift is to drill a new hole 3/4" toward the center of the truck.
Automan2164 Posted May 31, 2011 Posted May 31, 2011 Rough Country's own instructions for the 4.5" lift is to drill a new hole 3/4" toward the center of the truck. Hmm. Wonder if a quality lift company such as Rubicon Express or BDS says the same... :rotf: Get a new bar. Rob
HOrnbrod Posted May 31, 2011 Posted May 31, 2011 Agree. If you want to cheap out here's a link to do it right: http://gojeep.willyshotrod.com/HowtoTrackbar.htm I'd never do it. You screw it up and you're screwed. But cheap out if you must. :roll:
Incommando Posted May 31, 2011 Posted May 31, 2011 I have actually said many times that Rough Country is a terrible company and should have included that caveat. I mainly posted up because an earlier post recommended drilling a new hole 1/2" over. That being said, redrilling track bar mount caused no handling issues and the truck got into alignment spec just fine.
btm24 Posted June 6, 2011 Author Posted June 6, 2011 Got the front fixed good now thanks to you guys. Ill still try and get some pics up soon but ive been so busy moving and what not, that it may take some time. But ill keep my word :cheers: Brandon
btm24 Posted June 15, 2011 Author Posted June 15, 2011 here's a pic that a friend of mine took for our towns 4x4 sight it sits very nice i just wana go higher... Brandon
meljr Posted June 15, 2011 Posted June 15, 2011 Nice looking job you have done with your truck. I could use some of that sunshine here in Oregon. -meljr
btm24 Posted June 15, 2011 Author Posted June 15, 2011 Thank you :) and u might want the sun now but wait till it gets hot like yester day 98 out side :ack: Brandon
SW86 Posted June 16, 2011 Posted June 16, 2011 nice! yeah 4.5 sits great but I'm thinking 6 would be the beez neez. ill let you know next week cause I'm throwing in long arms and SOA 8.25 rear. can't wait! but enjoy that new height already and go get stuck! :banana:
btm24 Posted June 16, 2011 Author Posted June 16, 2011 nice! yeah 4.5 sits great but I'm thinking 6 would be the beez neez. ill let you know next week cause I'm throwing in long arms and SOA 8.25 rear. can't wait! but enjoy that new height already and go get stuck! :banana: Brandon
btm24 Posted June 16, 2011 Author Posted June 16, 2011 More pics (I really need to update my build page :oops: Brandon
ggcnash Posted March 13, 2014 Posted March 13, 2014 Just installed RE lift and it says same thing drill hole 3/4" but I went with adjustable track bar
