1tonMJ Posted May 19, 2011 Posted May 19, 2011 Searched, found nothing on specifics of what I want to do. So, since I got my Comanche, there never was an ignition key. The lock had been busted out, and all there is is a tab that I use plier to grab. Othere than that it was turning and starting just fine. The other day I was driving around, and when I got where I was going and went to turn the truck off, I found I couldn't turn the igniton back to 'off'. It was stuck in the 'on' position. I said, ok, decided to really ream on it, still didn't budge. So my truck was stuck 'on'. I ran around like that till noon or so, and once I got my truck in the driveway, that's when I tried to stop it. Ended up yanking the distributor wire, stopping the engine. So, no my truck is in my garage, dead until I can fix the ignition. What I want to do is catch the wires before they go up the steering column, and splice in 2 switches. One will be an 'off/run' 2 position switch, the other will be for the starter. That switch you can push up, and it returns to 'off' position when you let go, perfect for the starter. So, the big question is, which wires do I snip and splice? I know how to do the work, just need the right wires. Push button start, baby, oh yeah!
skinnyg Posted May 19, 2011 Posted May 19, 2011 Where are you located? I have a column with keys you can have for the cost of shipping from virginia 22405
Backdraft Posted May 19, 2011 Posted May 19, 2011 Where are you located? I have a column with keys you can have for the cost of shipping from virginia 22405 This is EXACTLY why I love this club. Way to go! Mike
1tonMJ Posted May 19, 2011 Author Posted May 19, 2011 I live in NY. Replacing the column is not something I want to do. The ignition is the only problem, and I will deal with having the switches (way cooler than keys, IMHO), and even if someone wanted to steal it, they couldn't get the thing going anyways. I have the only MJ that I have seen around me (rural area), and it's the only green spray painted VEHICLE I have seen around here, and anyone who see's it knows it's mine. I don't let them forget. :D Thanks for the offer, but I am just going to throw switches on there. That said, I still need which wires to splice into.
jimoshel Posted May 19, 2011 Posted May 19, 2011 A 10GA red wire is the +12V input. A 14GA dark green is the starter A 12GA orange is the run This will work and I have done it. However I suggest you take skinnyg up on his offer. Jim
1tonMJ Posted May 19, 2011 Author Posted May 19, 2011 I crawled under the dash, and based on this info, I found 2 harness plugs that I think are the right ones. The one has a dark green (starter I'm told), brown, and yellow wire: The other one has a large red (power), a large orange (run), small purple, gray and black/white wires: So, what do I cut to put on a different switch? What DON'T I cut and leave in that plug? And where do I put them on the switches I have? Switch #1: has 3 poles, top, middle, bottom, switch only has 2 positions. Switch #2: has 2 poles, switch returns to starting position.
1tonMJ Posted May 19, 2011 Author Posted May 19, 2011 Ok, I think that this is what I am supposed to do:
whowey Posted May 19, 2011 Posted May 19, 2011 Okay.. having done exactly what you are asking about.... Take Skinny up on his offer.. switches suck... When I finally take the dashboard out of my truck for the harness replacement.. a newer column is going in. To replace my damaged ignition lock solenoid.
Geonovast Posted May 19, 2011 Posted May 19, 2011 You shouldn't have to replace the whole column... just replace the cylinder...
1tonMJ Posted May 19, 2011 Author Posted May 19, 2011 Look guys, I get what you are saying, and I will replace the column eventually. But I need this running RIGHT NOW. Or else I don't make the money to get that new steering column. Just replacing the cylinder won't work either, this thing is fawked, which is why I want to move the ignition to the dash, so the only thing I am using on the steering is the wheel itself. This is what I am working with:
Geonovast Posted May 19, 2011 Posted May 19, 2011 Look guys, I get what you are saying, and I will replace the column eventually. But I need this running RIGHT NOW. Or else I don't make the money to get that new steering column. Just replacing the cylinder won't work either, this thing is fawked, which is why I want to move the ignition to the dash, so the only thing I am using on the steering is the wheel itself.This is what I am working with: :eek:
jimoshel Posted May 19, 2011 Posted May 19, 2011 :eek: Me too. Get a test light, or volt meter. Find the hot wire. Usually it will be larger than the others and red. Hook a short length of wire to it. Take the other end of the wire and touch the various terminals in the connector(s). The starter will be obvious, make sure your not in gear. When you touch the run wire the dash will activate, lights will come on, needles will move. A shower of sparks will be ground. To confuse the enemy you might install a dozen switches on a panel with only 2 hooked up. Bien suarte.
MJCARENA Posted May 20, 2011 Posted May 20, 2011 Ok, I think that this is what I am supposed to do: Why do you have a ground wire on the run switch, won't that ground out the +12v when switched to that position.
1tonMJ Posted May 20, 2011 Author Posted May 20, 2011 OK, so red on the bottom, orange on top, and black/ground in the middle? Like this?:
1tonMJ Posted May 20, 2011 Author Posted May 20, 2011 Well, I just tested all the wires in every combo possible, and every time it said the voltage was 12.8. How exactly am I supposed to do this? Even with the black and red leads switched, 12.8. Also, nothing turned on when I made contact, and the starter did not engage when I went from red to green. The only thing I disconnected was these 2 harnesses and something should have been making some noise.
1tonMJ Posted May 20, 2011 Author Posted May 20, 2011 No one knows? I have this question posted on 5 forums, and I cannot believe some of the stuff I have seen built, yet no one know this wire configuration.
jimoshel Posted May 20, 2011 Posted May 20, 2011 Your just doing something wrong and/or not giving us enough info. If you apply +12 volts to all the wires in that connector, SOMETHING is going to happen, somewhere. Turn signal blink, wipers come on, something.
mkbruin Posted May 20, 2011 Posted May 20, 2011 I can't help the immediate issue, but I would recommend a third switch (hidden if possible) to the fuel pump. No fuel means no start means no stealing. From what I found: "the GREEN wire is the starter & the YELLOW is the ignition coil. So I hooked up a toggle & push-button to those, and BA-DA-BING! Keyless ignition." Diagram: http://www.pirate4x4.com/forum/showpost ... stcount=10 http://bellsouthpwp2.net/b/o/bottlework ... agrams.pdf
