Paul Bruchal Posted April 13, 2011 Share Posted April 13, 2011 http://cgi.ebay.com/ebaymotors/CHRYSLER ... ccessories For my 35" tires.. right? Or have body work done. Link to comment Share on other sites More sharing options...
codymanche Posted April 13, 2011 Share Posted April 13, 2011 thought the comanche was wider in the rear? Link to comment Share on other sites More sharing options...
offroader461 Posted April 13, 2011 Share Posted April 13, 2011 :no: 1500 for that...no way....you will still have to modify the spring perches to get it to fit plus you don't even know if its a 27 or 29 spline axle get a used one from a 99-01 (29 spline) from a 4 cylinder (4.10) for around $200-300 or get one that has the wrong gears for cheaper than that and have the whole axle set up for around $600 Link to comment Share on other sites More sharing options...
mvusse Posted April 13, 2011 Share Posted April 13, 2011 That axle doesn't specify if it's 27 spline or 29 spline. The 29 spline variety is fine with 35" tires, but I would get one out of a 97 or newer (late 96 model year was the switch over) Cherokee from the junk yard for less than $100. Link to comment Share on other sites More sharing options...
streetjeep2.5 Posted April 13, 2011 Share Posted April 13, 2011 How can they advertize a rear differential for both cherokee and comanche? Perch problem! Link to comment Share on other sites More sharing options...
codymanche Posted April 14, 2011 Share Posted April 14, 2011 thats what i thought what about the width? Link to comment Share on other sites More sharing options...
streetjeep2.5 Posted April 14, 2011 Share Posted April 14, 2011 emailed them. They said "you have to change the perches for some applications". Didn't say what it is now set up to fit. Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 14, 2011 Share Posted April 14, 2011 width is fine, I have a stock XJ perches and all under the XJ, bushings are shot as hell, bought it that way. but XJ perchs are 45" on center and MJ perches are 42" on center. :wrench: Link to comment Share on other sites More sharing options...
Motion Offroad Posted April 14, 2011 Share Posted April 14, 2011 They are Omix-Ada surplus from the "crate XJ's" that were found that Omix purchased several years back. They are the 27 spline versions with the perches setup for the XJ. Link to comment Share on other sites More sharing options...
Exgrayxj Posted April 18, 2011 Share Posted April 18, 2011 They are Omix-Ada surplus from the "crate XJ's" that were found that Omix purchased several years back. They are the 27 spline versions with the perches setup for the XJ. :hijack: "crate XJs" Tell me more. I love stuff like that. Link to comment Share on other sites More sharing options...
Geonovast Posted April 18, 2011 Share Posted April 18, 2011 thats what i thought what about the width? I believe the Comanche itself (i.e., the bed) is marginally wider than an XJ is the back, but XJ and MJ axles are the same width. Link to comment Share on other sites More sharing options...
MiNi Beast Posted April 18, 2011 Share Posted April 18, 2011 thats what i thought what about the width? I believe the Comanche itself (i.e., the bed) is marginally wider than an XJ is the back, but XJ and MJ axles are the same width. glad you could clear that up. :waving: width is fine, I have a stock XJ perches and all under the XJ, bushings are shot as hell, bought it that way. but XJ perchs are 45" on center and MJ perches are 42" on center. :wrench: :rotfl2: Link to comment Share on other sites More sharing options...
SouthShore440 Posted April 28, 2011 Share Posted April 28, 2011 For that kind of money you can put a 9inch under it. Link to comment Share on other sites More sharing options...
btm24 Posted April 28, 2011 Share Posted April 28, 2011 Or a set of rockwell's :drool: Brandon Link to comment Share on other sites More sharing options...
