STERLING STINGER Posted March 7, 2011 Author Share Posted March 7, 2011 can i get a straight awnser not a presidential debate and whats this last post??? huh Link to comment Share on other sites More sharing options...
Pete M Posted March 7, 2011 Share Posted March 7, 2011 can i get a straight answer not a presidential debate and whats this last post??? huh straight answers: -the stock unit isn't all that bad. -aftermarket intakes are not a panacea of performance. -don't do it because you might save money. do it because you think it's cool, or it looks better, or whatever. -individual results may vary. Link to comment Share on other sites More sharing options...
cody4359 Posted March 7, 2011 Share Posted March 7, 2011 the 30-34 mpg results werent in his mj Link to comment Share on other sites More sharing options...
STERLING STINGER Posted March 7, 2011 Author Share Posted March 7, 2011 thanks pete :bowdown: ans sheesh, why even bring it up if it isnt in his mj? :dunno: Link to comment Share on other sites More sharing options...
Automan2164 Posted March 7, 2011 Share Posted March 7, 2011 thanks pete :bowdown: ans sheesh, why even bring it up if it isnt in his mj? :dunno: Because it was brought up in the post, and he wanted to know. Apparently you wouldn't be interested in an air intake with his MPG claim? Rob L. Link to comment Share on other sites More sharing options...
Darren Posted March 7, 2011 Share Posted March 7, 2011 http://www.thor4x4.com/html/xj_cowl_induction.html Link to comment Share on other sites More sharing options...
Sir Sam Posted March 7, 2011 Share Posted March 7, 2011 so i already have one? Your factory intake is already a "cold air" Even on newer XJs without the "cold air" it doesn't really make a difference. If you want a "cone intake" go for it, but don't get a K&N or other crapola, get something quality. K&N flows better by sacrificing filtration, amsoil for example won't. Link to comment Share on other sites More sharing options...
btm24 Posted March 7, 2011 Share Posted March 7, 2011 http://www.thor4x4.com/html/xj_cowl_induction.html ive read alot about this and thought about it. Would be great for an off road rig but for a DD it would get really annoying. That would make so much sound in the cab. Brandon Link to comment Share on other sites More sharing options...
87mjdriver Posted March 16, 2011 Share Posted March 16, 2011 like mj mike did, I got the rusty's cone filter adapter 30$ the I got some card board and cut, shaped, and taped together a "splash" shield and took it to a HVAC company. For 25$ they took a piece of 16 guage aluminuim(sp) and bent it into shape. Then I tok some of that door edge guard stuff, its like 5$ for 2 doors worth, and wraped the splash shield so I would get cut on it while working on the truck. Link to comment Share on other sites More sharing options...
hick92 Posted March 16, 2011 Share Posted March 16, 2011 hey brandon it don't make alotta noise unless at high rpms then it has a sucking sound but i mean i seem to like mine since i got the great big red spectre filter in a trade Link to comment Share on other sites More sharing options...
tazer15 Posted April 9, 2011 Share Posted April 9, 2011 My vote is for the filter in the cowl as i have a setup like this on my tj its called a MCAI but they go alittle further into detail than that one.It seals the whole cowl compartment you cut your vent in the middle out another filter goes there and then a air damn/ram air vent lookin :dunno: thing goes on top of that.But they do use a red tubing thats pretty flexable kinda like a radiator hose type feel.I have heard neg about using metal tubes all they do is get hot but you can also wrap them with header wrap.My jeep sounds better gained 1 to 2 mpg and seems to have slight bit of power.You can only hear it thru the vents when it first starts up and the colder it is the louder it is it disappears after a few miles.But sounds really good and your most noticable diff is on the hwy about 60 and you push it to the floor.I wish i had seen that erics xj write up if you have seen mine you can add to his what mine has for a little more $ and be in one pretty cheap when you consider mine sells for $350ish i believe.Is it worth $350? no but making youe own for under $200 yes! Link to comment Share on other sites More sharing options...
btm24 Posted April 9, 2011 Share Posted April 9, 2011 You should get a video from the inside of the cab. That would give me a good idea of how it sounds Brandon Link to comment Share on other sites More sharing options...
