Dadinator Posted September 3, 2014 Author Share Posted September 3, 2014 Promised tow hook pics: And my free 8 ball shift knob! Link to comment Share on other sites More sharing options...
4cyltoy Posted September 29, 2014 Share Posted September 29, 2014 Awesome job man! Link to comment Share on other sites More sharing options...
badazzelanore Posted November 8, 2014 Share Posted November 8, 2014 that is the simplest cleanest homemade cup holders I've seen. what did your wife use for the actual cup holders they look like the ones from my couch. Also just get a piece of material and glue it to the top so it looks more factory kinda like a speaker box. Link to comment Share on other sites More sharing options...
jbain Posted November 10, 2014 Share Posted November 10, 2014 I've got a 01 Dakota bench in the building I've had for a couple years.... Sometimes I wish I could take the wife and the kid with me when I'm wheeling. I really like how yours turned out, might have to take another look at doing the swap. Link to comment Share on other sites More sharing options...
87Warrior Posted November 14, 2014 Share Posted November 14, 2014 Nice work on the Dakota seat. Thank you for sharing how you actually went about the brackets. Did you reuse the MJ seat belt buckles or did you use the built in Dakota buckles? Some of the top of the line Dakotas had a flip up console lid (might have included cup holders?). If you ever find one, the center seat/console should bolt right in. Link to comment Share on other sites More sharing options...
Dadinator Posted November 25, 2014 Author Share Posted November 25, 2014 She did a great job on the cup holders. Got them online somewhere. Dakota seats using comanche seatbelts. Dakota seat has the flip open console. No cupholders within. Thanks for all the props! Link to comment Share on other sites More sharing options...
Dadinator Posted December 4, 2014 Author Share Posted December 4, 2014 Bypassed the rear load level brake proportioning valve or whatever the damned thing is called. Truck stops like it should now. Yes i can lock up the rears first if i slam it, but really worth it as now the truck feels much safer. Now it is time for new tires, steering stabilizer and another alignment. Gonna get some cooper at/3s. Have them on wifes tj and could not be happier with them. Then i have to see if i can diagnose that annoying stalling problem. Have to go through cruisers tips. Link to comment Share on other sites More sharing options...
91Pioneer Posted December 4, 2014 Share Posted December 4, 2014 Bypassed the rear load level brake proportioning valve or whatever the damned thing is called. Truck stops like it should now. Yes i can lock up the rears first if i slam it, but really worth it as now the truck feels much safer.That is actually more dangerous, not safer. The @$$ end could lock up causing you to lose control in a hurry (think: sideways). I don't know where you live but be careful on dirt and slippery roads. Link to comment Share on other sites More sharing options...
Dadinator Posted December 5, 2014 Author Share Posted December 5, 2014 Yes that can happen. I have tested it and have no problem with it. It is safer because now when i press the brakes, the truck stops instead of going oh say 30 feet further than it should. The brakes sucked before i did this. Scary sucked. I had replaced everything in the system. The valve must have been clogged or something as i only had fronts as far as i could tell. Now truck stops normally. Link to comment Share on other sites More sharing options...
Dillithium Posted December 5, 2014 Share Posted December 5, 2014 I removed my valve, too. Have been fine driving and braking ever since. It just means you need to be mindful of the middle pedal. I've been a little scared of doing the brakebooster upgrade since I removed the load valve; it already stops very well now. I feel that a bigger booster would make it lock up too easily(based on testimonials of people who've done it) I love your towhooks, they look much sturdier than mine. Link to comment Share on other sites More sharing options...
Dadinator Posted December 5, 2014 Author Share Posted December 5, 2014 I love your towhooks, they look much sturdier than mine. Thanks! Link to comment Share on other sites More sharing options...
Dadinator Posted December 5, 2014 Author Share Posted December 5, 2014 Today i installed new speedo cable. Then i disassembled the friggin steering column because last time i did not reassemble properly and the bright light switch wasn't working. All good now. Link to comment Share on other sites More sharing options...
Dadinator Posted December 27, 2014 Author Share Posted December 27, 2014 New Tires and all cleaned up! Link to comment Share on other sites More sharing options...
Kickinmule Posted February 20, 2015 Share Posted February 20, 2015 I reallty dig the seats in your mule! Gonna have to plan that for the future! :thumbsup: Link to comment Share on other sites More sharing options...
Dadinator Posted February 22, 2015 Author Share Posted February 22, 2015 Thanks! Link to comment Share on other sites More sharing options...
Dadinator Posted May 13, 2015 Author Share Posted May 13, 2015 How 'bout that... Cheap xfer case shifter. Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted May 13, 2015 Share Posted May 13, 2015 My seat belts don't work and my dad wants me to seats with headrests. Should I go with the Dakota seats? Is there anything better? I think I could make those brackets. Link to comment Share on other sites More sharing options...
Dadinator Posted May 13, 2015 Author Share Posted May 13, 2015 Better is just opinion. I like the dakotas. my brackets make the seats higher. I like it that way. I am average height. If you are tall you might want to use flat stock instead of the square tube like i did. Link to comment Share on other sites More sharing options...
Dadinator Posted May 17, 2015 Author Share Posted May 17, 2015 Here is my cheapo headliner solution. I got tired of trying to find a headliner board that wasn't in terrible shape. Picked up this fatigue mat for $17. Glued it up and trimmed. It is by no means perfect, but looks way better than the bare metal. Matches the floor mats too. :) Link to comment Share on other sites More sharing options...
Little jeep Posted May 17, 2015 Share Posted May 17, 2015 Looks awesome Link to comment Share on other sites More sharing options...
Dadinator Posted May 18, 2015 Author Share Posted May 18, 2015 Thanks. Link to comment Share on other sites More sharing options...
Dadinator Posted June 3, 2015 Author Share Posted June 3, 2015 Looks like the ignition cylinder has given up the ghost. I get to tear into the steering column... Again! I hate that thing. Link to comment Share on other sites More sharing options...
Dadinator Posted June 4, 2015 Author Share Posted June 4, 2015 Fixed. $15.99 at advance auto. Old one was toast. Link to comment Share on other sites More sharing options...
dwa175 Posted June 17, 2015 Share Posted June 17, 2015 dadinator oil pan gasket I have been serv mng for 15 years.when replacing pan gasket use new factory gasket they are reuseable no sealent beleave me we had our share of problems factory gasket works the best can get at any mopar parts dept :chillin: Link to comment Share on other sites More sharing options...
Dadinator Posted June 17, 2015 Author Share Posted June 17, 2015 Ok... Thanks, but I replaced that dude like 4 years ago. Link to comment Share on other sites More sharing options...
