MancheKid86 Posted December 4, 2010 Share Posted December 4, 2010 hey guys, would you pay this much for a 5.5 inch lift? http://www.rubiconexpress.com/jeep/MJ/P ... art=RE6500 Link to comment Share on other sites More sharing options...
mnkyboy Posted December 4, 2010 Share Posted December 4, 2010 I wouldnt Link to comment Share on other sites More sharing options...
jimoshel Posted December 4, 2010 Share Posted December 4, 2010 Considering what your getting, seems reasonable. I placed a jack on top of my axle and and the floor of my MJ.I then jacked it up until I had 5.5 inches of clearance. Cut a 4X4 into 2 pieces 5.5 inches long and placed them between the top of the axle and the frame. Then removed the jack. Rides a little rough but didn't cost no $1000. Link to comment Share on other sites More sharing options...
Incommando Posted December 4, 2010 Share Posted December 4, 2010 That is closer to a new suspension system than a typical "lift. Look at it this way: you can go all out for $1,200 or get ripped off for $600 by Rough Country and a crappy product that won't make you nearly as capable. Link to comment Share on other sites More sharing options...
mnkyboy Posted December 4, 2010 Share Posted December 4, 2010 Problem with RE is they are way over priced,for far less then $1200 you could put together the same lift. That kit is basically what's under my mj except mines an inch taller and I have adjustable uppers/lowers with flex joints,I'm not even close to $1200 Link to comment Share on other sites More sharing options...
comanche13 Posted December 4, 2010 Share Posted December 4, 2010 I slowly parted my rubicon express kit together and I'm still under 1000 bucks Link to comment Share on other sites More sharing options...
MancheKid86 Posted December 4, 2010 Author Share Posted December 4, 2010 Problem with RE is they are way over priced,for far less then $1200 you could put together the same lift. That kit is basically what's under my mj except mines an inch taller and I have adjustable uppers/lowers with flex joints,I'm not even close to $1200 went to the site u got urs from, got every thing i wanted and then some, grand total with shipping was 1100 :D and that comes with everything, I'm thinkin I'm going there, bit more resonable, the 6` kit from them was about $600 with shipping, but i put lots of the upgrades on :P Link to comment Share on other sites More sharing options...
mnkyboy Posted December 4, 2010 Share Posted December 4, 2010 Mine would be hard for you to price out as its a mixture of stuff. The original kit was an rro kit which is now on my xj. I have RC 6.5" coils I found on ebay $90 iirc RC adj uppers and lowers w/6 flex joints,$300 at hell creek RRO track bar (for now) came in kit but about $120 RRO soa kit $110 you could do this much cheaper Chevy 2wd brake lines $25 RRO long travel shocks $125 I made my own drop brackets,so you would have to figure that out. I also made my own sway bar discos Now that's about what I payed,I'm sure prices have changed a little Link to comment Share on other sites More sharing options...
Pete M Posted December 4, 2010 Share Posted December 4, 2010 rubicon express has a reputation for high quality stuff and you'll get your money's worth. :thumbsup: Link to comment Share on other sites More sharing options...
jpnjim Posted December 5, 2010 Share Posted December 5, 2010 You can go longarm for that money, if you like RE stuff (I do), then use their ft coils, with a 'long arm upgrade' kit of your choosing + a track bar kit. Grab some good sway disconnects (JKS), whatever shocks you can afford after dropping all that coin, and SOA the rear. Done. (well, then you should do steering, upgrade the axles, get a hula girl doll for the dash, tires....) Link to comment Share on other sites More sharing options...
87Warrior Posted December 5, 2010 Share Posted December 5, 2010 Would I? No. I have mixed feelings about RE. Ran their kit on my TJ (8 adjustable CAs, front/rear TB, coils, brake lines). Only the coils and front TB remain. Parts kept failing regularly (1-3months) and a brake line burst (from the inside out) on me in a college town on game day. They did a good job and sending me bushings every 3 months (for a year) until I sold the arms. The coils have a great ride and match my OME shocks great. I have 70K miles on my RE coils and they have sagged down to a nice 3"s from 3.5"s. I do not believe there is any 'perfect' or 'best' out of the box lift. Build to suite. Buy used parts when possible (budget for new joints/bushings) to save cash. Link to comment Share on other sites More sharing options...
Dirteatr717 Posted December 5, 2010 Share Posted December 5, 2010 Nope, piece together your own lift... I've been doing so for the past year and I've spent 500 for everything up front for 4.5-6 now I need SOA stuff and tires... Eventually I'll go longarms when I can afford it but until then I'll deal with my onroad handling Link to comment Share on other sites More sharing options...
