Jerry Posted December 3, 2010 Share Posted December 3, 2010 How do you remove the 'comanche' & '4x4' badges? Thanks guys :cheers: Link to comment Share on other sites More sharing options...
jimoshel Posted December 3, 2010 Share Posted December 3, 2010 A little heat to soften the adhesive, no open flame tho. Push a putty knife down behind the baddge being careful not to scratch the paint. Link to comment Share on other sites More sharing options...
knever3 Posted December 3, 2010 Share Posted December 3, 2010 Use a little heat like a heat gun or hair dryer and use a piece of dental floss to get behind it to cut the adhesive then use goo gone or WD-40 to remove residue. Link to comment Share on other sites More sharing options...
artimus Posted December 3, 2010 Share Posted December 3, 2010 Use a little heat like a heat gun or hair dryer and use a piece of dental floss to get behind it to cut the adhesive then use goo gone or WD-40 to remove residue. Link to comment Share on other sites More sharing options...
btm24 Posted December 3, 2010 Share Posted December 3, 2010 or just put a flat head screw driver behind it and pry it off. Brandon Link to comment Share on other sites More sharing options...
Oizarod115 Posted December 3, 2010 Share Posted December 3, 2010 i've seen fishing wire, it's a little tougher than dental floss... but most the badges ive ever seen were about to fall off from age anyways lol. Link to comment Share on other sites More sharing options...
kawaboy13 Posted December 3, 2010 Share Posted December 3, 2010 What'd you use to put them on? And I need pictures of where for the comanche emblems Link to comment Share on other sites More sharing options...
btm24 Posted December 3, 2010 Share Posted December 3, 2010 you use emblem tape. Brandon Link to comment Share on other sites More sharing options...
kawaboy13 Posted December 3, 2010 Share Posted December 3, 2010 Where can I get this? Anyone still have the badges on from the factory that have never moved so I can see them closely? Link to comment Share on other sites More sharing options...
jpnjim Posted December 3, 2010 Share Posted December 3, 2010 There was a thread on another message board 7-8 years ago, someone had bought a new-used XJ, that had the used car dealer's badge on the back. He asked "how do I remove it carefully-bla bla bla". He got a ton of answers & opinions: heat gun, wait till a hot day, use a plastic bondo scraper once you get it started, etc etc. It seemed like the guy hadn't done much mechanical work, because he replied to most of the posts, and asked alot of questions. Anyway, he buys a heat gun, and takes his time, and very carefully lifts & removes the emblem.... only to find the dealer had removed the last dealer badge with a screwdriver, gouged the crap out of the paint, and just slapped the new emblem over the damage. :doh: :wall: :wall: :wall: Link to comment Share on other sites More sharing options...
jimmy21669 Posted December 3, 2010 Share Posted December 3, 2010 There was a thread on another message board 7-8 years ago, someone had bought a new-used XJ, that had the used car dealer's badge on the back. He asked "how do I remove it carefully-bla bla bla". He got a ton of answers & opinions: heat gun, wait till a hot day, use a plastic bondo scraper once you get it started, etc etc. It seemed like the guy hadn't done much mechanical work, because he replied to most of the posts, and asked alot of questions. Anyway, he buys a heat gun, and takes his time, and very carefully lifts & removes the emblem.... only to find the dealer had removed the last dealer badge with a screwdriver, gouged the crap out of the paint, and just slapped the new emblem over the damage. :doh: :wall: :wall: :wall: :doh: :no: :thwak: Link to comment Share on other sites More sharing options...
Jerry Posted December 4, 2010 Author Share Posted December 4, 2010 Thanks for the info guys. I use 3M tape a lot, it'll hold anything anywhere! :thumbsup: http://solutions.3m.com/wps/portal/3M/en_US/3M-Industrial/Adhesives/Product/Bonding-Tapes/VHB-Tape/ Link to comment Share on other sites More sharing options...
mnkyboy Posted December 4, 2010 Share Posted December 4, 2010 That 3m VHB tape is some good stuff. That's what they use to hold the wall panels on cargo trailers to get that smooth look instead of screws. Its amazing how strong the stuff is as long as its put on correctly. Link to comment Share on other sites More sharing options...
kawaboy13 Posted December 11, 2010 Share Posted December 11, 2010 Also how easy will they come off afterwards? I don't want them to like blow off. Can you get the tape at wal mart? Also has anyone ever painted emblems? What was your experience and how did you do it? thanks! Link to comment Share on other sites More sharing options...
btm24 Posted December 11, 2010 Share Posted December 11, 2010 Also how easy will they come off afterwards? I don't want them to like blow off. Can you get the tape at wal mart? Also has anyone ever painted emblems? What was your experience and how did you do it? thanks! I have just repainted 2 Comanche emblems and put them on where they are supposed to be ( on the front fenders). If you use emblem tape they are really easy to take off don't know about any other tapes, but the Black emblem tape is a pain in the @$$ to get off where an emblem used to be. If you have the paint that came with you truck still there then trying to remove the emblem tape will also rub off alot of paint (happened to me so I just left mine on). To paint the emblem use black acrylic paint that you can by at walmart for like 3 bucks. squirt the paint all over them emblem and use a soft paper towel or cotton balls and rub the paint off of the raised edges. Wipe as much off with out pushing hard, as you can. Then take a fine brush and brush and missed spots in the black. let it sit to dry for 24hr's then go back and use the cotton balls or a SOFT paper towel to gently rub off the paint on the raised parts. may have to get a very very very small amount of water on the towel or cotton ball to get all of it off. Brandon Link to comment Share on other sites More sharing options...
