littlezeeker Posted November 14, 2010 Share Posted November 14, 2010 I Was Thinking about Having my Entire Jeep Comanche Rhine Lined Has anyone ever had it done or seen it done? I would like to know if its a good idea or not. Thanks Link to comment Share on other sites More sharing options...
88MJXLS Posted November 14, 2010 Share Posted November 14, 2010 You might get more responses/opinions if you move this to the MJ Tech or Pub. In my opinion it depends on what you'll be using your Jeep for, if it's going to be for offroading, rock-crawling, etc, the bedliner could protect against scratches and whatnot (I think Rhino lining the whole Jeep could add a decent amount of weight too, but I'm not positive :dunno: ) but if it's just a DD, I'd go with a regular paint job. Just my two cents Link to comment Share on other sites More sharing options...
littlezeeker Posted November 14, 2010 Author Share Posted November 14, 2010 It will be for playing and hunting and maybe a little rock climbing, I was thinking it would be good for protecting from trees and rock damage. Link to comment Share on other sites More sharing options...
Incommando Posted November 14, 2010 Share Posted November 14, 2010 Protecting what? Paint? The paint is ruined if you rhino-line and there are horror stories out there about people trying to go back to paint afterwards: it is pretty much a non-reversable project, from what I read. If you like the look, go for it. Link to comment Share on other sites More sharing options...
Pete M Posted November 14, 2010 Share Posted November 14, 2010 it hides rust (but doesn't stop anything from just rotting away beneath it), it peels, it grabs hold of rocks/trees instead of sliding by, it's expensive, it has an insanely complicated spray procedure making it impossible to fix application mistakes (once the product starts flowing out the gun, you can't stop it without it spontaneously curing inside the nozzle), and, I'm sure there are some other reasons why I hate that stuff. I had it applied to the rockers on my truck and regret it. when it came time to paint my 88, I came across an old product called Zolotone. It's kinda a hybrid between paint and a true liner and has it's own set of complications. It still only hides rust, has a semi-complicated application procedure (but I was able to spray it myself), and is not dissolved by anything meaning the gun you use needs to be considered sacrificial just in case you don't get it all out. but I'm much happier with it. :D It's rock hard with a textured surface. I'd suggest finding a place near you that knows how to apply it. ranges from 40 to 50 bucks a gallon. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted November 14, 2010 Share Posted November 14, 2010 Not to mention, all bedliner material fades over time (alot faster than paint) so it might look cool at 1st but it wouldent be long till the nice color is gone. Doing accents on a truck with Bedliner is 1 thing but Id never consider doing the entire vehicle. :typing: Link to comment Share on other sites More sharing options...
btm24 Posted November 14, 2010 Share Posted November 14, 2010 it fads on the hood the fastest because of how much heat there is there. Brandon Link to comment Share on other sites More sharing options...
Carl'sMJ Posted November 14, 2010 Share Posted November 14, 2010 it fads on the hood the fastest because of how much heat there is there. Brandon I believe the fading is due to the UV rays from the sun, not heat. Anyway, I agree with pretty much everything said above. I opted to use Herculiner on my rockers and in my bed primarily because it can be fixed easily by myself if damaged. Rhino Liner is good stuff and a tough product, but it's not invincible and will get worn and look terrible after awhile... My vote, don't do it, use the regular paint on the exterior. Link to comment Share on other sites More sharing options...
kbusch18 Posted November 14, 2010 Share Posted November 14, 2010 hey i painted my jeep grand cherokee a while back and i thought it was great i used the herculiner and rolled it on myself as far as fading not really it started out a shiny finish and eventually ended up flat back which was ok the only thing i slightly didnt like was that no matter what it always would rub off on ur fingers or clothing if you really rubbed up on it but overall if ur gonna keep it for a while and use it for what you say go for it Link to comment Share on other sites More sharing options...
Pete M Posted November 14, 2010 Share Posted November 14, 2010 the only thing i slightly didnt like was that no matter what it always would rub off on ur fingers or clothing if you really rubbed up on it the color rubbed off, or the product itself rubbed off? Link to comment Share on other sites More sharing options...
btm24 Posted November 14, 2010 Share Posted November 14, 2010 it fads on the hood the fastest because of how much heat there is there. Brandon I believe the fading is due to the UV rays from the sun, not heat. I don't think so because my friend kept his mud truck in a garage and it looked almost warped on top of the hood. and pete your truck looks amazing! i don't think ive ever seen them hood handles either. very cool. Sorry didnt mean to get off of subject. Brandon Link to comment Share on other sites More sharing options...
Pete M Posted November 14, 2010 Share Posted November 14, 2010 when I pulled the latches out, that removed the springs that pop the hood up that first inch so I needed something to do that job (better than a screwdriver). :D Link to comment Share on other sites More sharing options...
kbusch18 Posted November 14, 2010 Share Posted November 14, 2010 i believe it was just color hard to tell though because i had it previously painted flat black from what i seen it held up great did do well with protection with the whole rubber pellets in it and not to mention i only did one coat i would say do so should only be about 150 Link to comment Share on other sites More sharing options...
juan Posted November 14, 2010 Share Posted November 14, 2010 Hey, how about the durabak in either rough bedliner or straight paint???? anyone? Link to comment Share on other sites More sharing options...
Carl'sMJ Posted November 15, 2010 Share Posted November 15, 2010 it fads on the hood the fastest because of how much heat there is there. Brandon I believe the fading is due to the UV rays from the sun, not heat. I don't think so because my friend kept his mud truck in a garage and it looked almost warped on top of the hood. and pete your truck looks amazing! i don't think ive ever seen them hood handles either. very cool. Sorry didnt mean to get off of subject. Brandon After doing some research on Rhinolinings Industrial website... "When subjected to constant UV exposure, Rhino Linings may fade. However, Rhino Linings offers a UV topcoat capable of protecting your lining from UV damage." "Our formulations are designed to withstand temperatures between - 40° and 175°F. Rhino Linings were designed to withstand abrasion, impact, corrosion, vibration, expansion, contraction, flexing and chemical wear." Link to comment Share on other sites More sharing options...
littlezeeker Posted November 15, 2010 Author Share Posted November 15, 2010 This Is my friends truck he has had it for about a year or so and it still looks great he hunts and muds and works in it all the time. the color hasn't faded a bit and he use a uv protecting kinda like you would waxing normal paint. https://sites.google.com/site/rhinoliner1/ Link to comment Share on other sites More sharing options...
pilotblake Posted November 15, 2010 Share Posted November 15, 2010 I vote no. Paint it rattle can flat, and keep touching it up if you don't like the scratches. Then down the road if you, or the next owner of the truck wants to put a decent coat of paint on it, it could be done. It's like painting the walls in our house black. YOU might think it looks cool, but it is a :fs1: for the next guy, or you when you decide you don't like it anymore. Link to comment Share on other sites More sharing options...
87Warrior Posted November 16, 2010 Share Posted November 16, 2010 You asked for an opinion. NO! Having seen several lined vehicles I can say I find them extremely ugly. I don't even understand why anybody considers it. If you want a tough overpriced paint job, paint the entire truck in POR15. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted November 16, 2010 Share Posted November 16, 2010 If you want a tough overpriced paint job, paint the entire truck in POR15. Now that would be cool! but a top coating would still be required to maintain a pretty color, POR15 fades to a dull grey in No time if expeosed to UV rays. Link to comment Share on other sites More sharing options...
87Warrior Posted November 17, 2010 Share Posted November 17, 2010 If you want a tough overpriced paint job, paint the entire truck in POR15. Now that would be cool! but a top coating would still be required to maintain a pretty color, POR15 fades to a dull grey in No time if expeosed to UV rays. Yup, POR15 sells the UV top coat too :clapping: Link to comment Share on other sites More sharing options...
littlezeeker Posted November 17, 2010 Author Share Posted November 17, 2010 Does the UV protection work Pretty Good ? Link to comment Share on other sites More sharing options...
Pete M Posted November 17, 2010 Share Posted November 17, 2010 even por-15 won't stop our trucks from rotting from the inside-out. Link to comment Share on other sites More sharing options...
cluricaunne Posted November 17, 2010 Share Posted November 17, 2010 I used Herculiner on my MJ. I think it turned out nice, and I only spent $210 on three kits, I still have a kit and a half left, and only a few minor pieces left to finish. You can see it in my build thread. http://comancheclub.com/forums/viewtopic.php?f=7&t=17707 Link to comment Share on other sites More sharing options...
