4 minute Jeep dis/assembly
mjeff87
Yea, was everything just hand tight or attached with rods/cotter pins? I think the only thing that was bolted were the wheels.
I also want to know their shut-off valve setup for the radiator so they don't spill a drop of coolant. I must lose a quart of coolant on the ground every time I need to drain the coolant to do some cooling system-related fix...
the Rad probably wasn't attached at all. it only runs for a few seconds.
