'74(ish) VW Dune Buggy Build
  • Replies 105
  • 3 months later...
Yeah... kinda. I suppose, since it's back to the top, an update is in order: not much. It's gotten moved around the garage a bit. I've got the Eliminator, my brother's VW, and the buggy in there (it's only 24'x32' so it's a little cramped right now). Been waiting until spring to get back on this one when my brother's car is out of the way. Thanks for resurrecting the post though!
  • 3 months later...
Yeah... I know... with me moving this summer and a huge waste of my time over another MJ, this poor thing got pushed to the back burner... then off of the stove completely and back into the freezer! I pick at it from time to time, but for now it's just going to have to wait. The way it sits now is mobile and for the most part assembled enough so I don't loose anything when we move.
Sitting right next to it right now is my Beetle waiting to get its carb rebuilt. Darn thing dried up on me over this last winter. Always something with these VWs...
  • 3 years later...
Holy old thread! Figured I might as well let everyone in on what I've been up to lately. The majority of this last summer has been a total pile of garbage so I've been lacking on all of my projects. Little by little, I'm getting back to things. I wanted to return to something that I could come and go as I please with little projects when I've got a few open hours at a time. Even though my white truck could probably get done faster than this, I felt is easier to get back to a simpler vehicle to pick at. So... lets get up to date.
Here it is after a couple more years of sitting and waiting patiently for its turn.
I wanted to get things rolling again on what makes it... well... roll. Obviously these wheels/tires are just for moving it around. Not a whole lot of cool factor in pizza cutters on a dune buggy.
10696360_643965455702321_121854733849484
My plan from the start was to run 295/55s on the rear and 235/60s on the front. I had options but not much in the VW lug pattern variety. Either find a nice wheel and run adapters or redrilled hubs, or get creative. I chose the to get creative... and a little old school. Ever hear of a steel wheel that's been "banded"? It's kind of a gray area as it means to cut a wheel in half and add in an extension to the barrel. Personally, I wouldn't ever run a set of wheels that I didn't know who did the welding, but I wouldn't even give it a second thought if it were my own work. So this happened...
10541999_624709367627930_399996747309119
I got the first one done, painted, and a tire mounted as an experiment. I spent a ton of time keeping the wheel spinning round, but more on that later. I ended up with this...
10350422_625126740919526_304880826539521
10312712_625126727586194_443079306888199
Yup... it's wide! I I started with a 4" wheel and ended with a 9". The fronts also started as 4" but are now 7.5" wide. Want to know how I did it? Thought you'd never ask. It all starts with making sure they're all the same backspacing.
10405548_643965465702320_181109901976046
This is where things turn into a bit of a hassle. For those unfamiliar with my shop, I'm a bit of a minimalist. Ideally, I should be using a lathe for cutting the wheels in half to keep everything nice and true. Well... I have no such fancy things.
10636006_643965535702313_849673350814482
So, measure everything a bunch of times and slap on some red tape.
10358140_643965509035649_121980423483860
Then I scribe a line with a cut wheel on a grinder.
10635872_643965545702312_394254153840742
... and send it home.
10405379_643965569035643_483432820511066
Now was a good time to clean everything up. Again, proper tools would be a big help here. A sand blaster would be best, but a grinder with a wire wheels works too... slowly, but well enough.
10671222_643965595702307_753143933077701
I sheared some 3/16" material and gave it a whirl in a slip roller. This is where things start to take shape.
10687210_643965622368971_723862777304050
10660249_643965642368969_299705782695043
Fancy tools thrown out still, keeping things round was done with a square and some TIG filler.
10665271_643965682368965_547583742578611
10373501_643965699035630_970252555907146
Let's compare.
10450737_643965725702294_497647361287723
Anyhow, some other stuff happened and I ended up with one more rear and two fronts.
10653575_643965819035618_289281234121931
Going to be sweet!
10698646_643965662368967_205542261700934
With everything welded up, the reborn wheels got some paint this afternoon.
10703680_645632675535599_919192401221598
10352906_645646658867534_282793071776776
Tomorrow the rest of the tires mounted. Very excited to get this one back on the ground and mobile again. Then on to something else. I'd really like to be doing some tube work this winter... which means I need to figure out a bender. Stay tuned for that or whatever else might be next.
10599268_630620213703512_567902677615020
Tires!!!
10698683_646031148829085_426987621373918
This little car took on a whole new personality today. First time it's ever had anything more than those tiny little bike tires. I think it looks tough!
10636043_646031268829073_687111752984596
10394130_646031182162415_221215285989363
16101_646031222162411_879047565441708064
10612605_646031135495753_525559900645531
10689627_646031205495746_572070830926541
Everything is mobile again!
10698573_646031255495741_355951283945296
Best part is one less pile in a corner.
10689627_646031288829071_196441714170221
Now to pick something else from the box.
10686768_646031305495736_273892305153875
  • 1 month later...
So... been working on my shop for a while and it's pretty much done. Done enough to be tired of working on it and wanting to get back to working on fun stuff anyhow.  :D
10313081_671098866322313_405273787827246
10409201_671098879655645_415210318003506
It's not much... 14'x28'. It's big enough to call home for now. As for the buggy, it actually saw the light of day!
1531648_671098106322389_4290129751439451
... and then it got put in it's winter home. It's pretty much the same as it has been for the last few years with the addition of wheels and tires just recently. Looks almost presentable in some decent light!
10712797_671098186322381_775767838295600
10671391_671098279655705_235120774258187
Unfortunately a good camera angle only hides everything that's been hiding in it.  :roll:
10374438_671098306322369_440342756559458
10689870_671098249655708_199210449387885
Ah well... it's in a workable area now so that's a step in the right direction, right?
10346620_671098369655696_710183310026754
65573_671098382989028_435348632223950053
So glad I got to see this sweet project in person!
:thumbsup:
Everybody likes cutting and welding on a used gas tank, right? :yes:  Didn't have anything to worry about though... the tank has been dry since the '80s with zero vapors left in it. I've started trying to take care little things up front that add up in the end that seem to take forever after getting major things done.
I started with putting the tank in and putting the hood on... things didn't fit quite right. Those sexy sloping lines just didn't jive with what was happening inside. The tank was from the donor '74 Beetle so I knew that the fuel intake would be in the wrong spot. I like where the filler was cut originally so I used the hood as the template. Here's how it went...
1920611_672051982893668_6556755457465199
10561779_672051909560342_360359218202079
10806343_672051946227005_622761180236914
10690167_672052032893663_136557517715711
10678853_672052052893661_153384289950951
For now, I used a short piece of 2" exhaust tubing as a place holder for whatever I choose as a cap. Like I said before, I like the fuel fill low to keep the hood looking clean. Just not a fan of a giant cap in the middle of the hood. Next on the list was adding a mini sump in the bottom of the tank. The fitting in the bottom was completely screwed up so I figured it needed to be cut out anyhow. It's not the absolute lowest point of the tank but I was planning on adding a drain elsewhere. I like the idea of being able to completely drain the tank if need be.
1240667_672052082893658_2239574805652713
10734262_672052096226990_755945489881666
10378200_672052126226987_225257914056773
Obviously, fittings to come later. I see a small body lift in my future too. The steering coupler rubs on the bottom of the tank as shown in the dirt.
10382146_672052162893650_222563376474020
Last on the list is to patch up the last corner. I left it open to be able to clean it out as I go along.
10606184_672052206226979_536220578353729
Not done with it, but I had to put the hood and lights back on for the evening. Couldn't stand leaving it without its face on.   :roll:
10696349_672052226226977_123440750276590
  • 9 months later...
Eek... facebook strikes again in the form of dead picture links.  :fs2:
I'm still picking at this thing from time to time. Got the bug to do something with it this weekend in the form of a front bumper.
Had a real humid week and the newly finished but unpainted front bumper turned a little orange. A quick scuff, prime, and paint solved that...
Got back to the rear too. I continued with the failed attempt of the front bumper.
Future tie-ins for the cage...
Dat @$$...
It's amazing how fast one of these little plastic cars can go from a pile of steel and fiberglass to a car-looking thing. This afternoon I got back to tapping those holes. Lots of oil... brand new and sharp tap... no problems today. That allowed me to completely fasten down the body. First time I've even been able to do that! Must of the fiberglass still needs to relax to the point of being completely tight to the chassis, but it's a start. It's been outside for a few sunny days, but it's really due now. The lights went on along with the windshield. Funny thing about that... I always knew that I had the windshield installed backwards looking back at old pictures, so I tried to put it on the correct way with the channel around the glass facing forward. Wouldn't you know it... it wouldn't go on. The seal at the bottom of the windshield was also backwards and the mounting holes didn't line up. Whoever put together the windshield in the first place put it together all wrong. Granted, I like how it looks with the windshield installed backwards, but it'll sure make it difficult when it comes time to figure out a top.
The tape is still there waiting for me to figure out what I want to do with the rear body lines. Of the few pictures I've found of other bodies like mine, they just don't look right. I'm not a fan of cutting up a buggy body, but this one has really been around the block a few times already. The suspension kind of bugs me too. Not sure if I should raise the rear or to lower the front. Once the metal work is done I should have a better idea of where the weight will be sitting in the car.
I had the wife come out and take a few angles with me in the car too. This let me play around with lines and different angles for the future cage. Kind of difficult though... I'm tall and I don't want the car to look too cartoonish. Here's what I'm thinking on that...
Yup... not a whole lot one can do to jazz up the lines of a cage in a buggy when wanting to keep things somewhat simple. She snapped one last picture that I couldn't help but compare to 2004.
