STERLING STINGER Posted May 7, 2010 Share Posted May 7, 2010 here's the lift....yep done after like 3 months! front: 2 1/2" coil spacers = $35.00 rear: add a leaf = $75.00 total +++$110.00 and about 4 hrs total in labor. I'm not adding the alignment cuz a mechanic had to do it for me.....but fyi that was $65.00 whadda ya think? i like it alot. Link to comment Share on other sites More sharing options...
shawn Posted May 7, 2010 Share Posted May 7, 2010 sweet lookin truck - i like its stance. now maybe go up one tire size. Link to comment Share on other sites More sharing options...
DJM/78 Posted May 7, 2010 Share Posted May 7, 2010 Looks good man , thats about as much as you want to go before it really starts to add up fast . Did you do anything with the track bar ? Link to comment Share on other sites More sharing options...
STERLING STINGER Posted May 7, 2010 Author Share Posted May 7, 2010 my track bar is from a v8 grand cherokee, thanks Link to comment Share on other sites More sharing options...
sinkrun Posted May 7, 2010 Share Posted May 7, 2010 Looks good thats exactly what I need to do. Off topic do you know if your wheels are the 7 inch or 8 inch ones? Link to comment Share on other sites More sharing options...
-600JeepMJ Posted May 8, 2010 Share Posted May 8, 2010 now that you have lifted it, will it even fit in the garage? Link to comment Share on other sites More sharing options...
Sir Sam Posted May 8, 2010 Share Posted May 8, 2010 Looks good thats exactly what I need to do. Off topic do you know if your wheels are the 7 inch or 8 inch ones? Those are the 8 inch. Link to comment Share on other sites More sharing options...
Automan2164 Posted May 8, 2010 Share Posted May 8, 2010 O.W.L. FTW! Rob L. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted May 8, 2010 Author Share Posted May 8, 2010 :rock on: now that you have lifted it, will it even fit in the garage? Ya its in there now Link to comment Share on other sites More sharing options...
STERLING STINGER Posted May 8, 2010 Author Share Posted May 8, 2010 O.W.L. FTW! Rob L. I don't know what o.w.l. means but...thanks? Link to comment Share on other sites More sharing options...
Automan2164 Posted May 8, 2010 Share Posted May 8, 2010 Outlined White Letter. Turn those black walls in man! Bring the white letters back! Rob L. Link to comment Share on other sites More sharing options...
aemsee Posted May 8, 2010 Share Posted May 8, 2010 what size tires are those? I finally got my LT245/75/16 MT/R's on my truck and trying to decide if the 3" lift I have to install will look silly with those size tires. Link to comment Share on other sites More sharing options...
mnkyboy Posted May 8, 2010 Share Posted May 8, 2010 what size tires are those? I finally got my LT245/75/16 MT/R's on my truck and trying to decide if the 3" lift I have to install will look silly with those size tires. yours should be about 30.5",i had 31s on mine for a while with a 5" lift and it didnt look silly. Link to comment Share on other sites More sharing options...
WahooSteeler Posted May 8, 2010 Share Posted May 8, 2010 how bout a good side shot from a little more distance? looks good.......I like the color combo :brows: Link to comment Share on other sites More sharing options...
Sir Sam Posted May 8, 2010 Share Posted May 8, 2010 Outlined White Letter. Turn those black walls in man! Bring the white letters back! Rob L. More than that the long trials are asymmetric, so his tires are on incorrectly right now. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted May 9, 2010 Author Share Posted May 9, 2010 Outlined White Letter. Turn those black walls in man! Bring the white letters back! Rob L. if there was good lettering on those used tires i got i would have. when i get a bran new set, there going out. Link to comment Share on other sites More sharing options...
over2land Posted May 9, 2010 Share Posted May 9, 2010 Looks good. OT: did you use a kit to get those shackles out there? If so, whose kit is it? Link to comment Share on other sites More sharing options...
STERLING STINGER Posted May 9, 2010 Author Share Posted May 9, 2010 Looks good. OT: did you use a kit to get those shackles out there? If so, whose kit is it? I ripped out the plow frame and there was quarter inch plate bolted to the frame...so i just lwft them and put the shackles in the bolt holes. Link to comment Share on other sites More sharing options...
over2land Posted May 9, 2010 Share Posted May 9, 2010 Looks good. OT: did you use a kit to get those shackles out there? If so, whose kit is it? I ripped out the plow frame and there was quarter inch plate bolted to the frame...so i just lwft them and put the shackles in the bolt holes. OIC. Thanks. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted May 10, 2010 Share Posted May 10, 2010 Looks like you stacked factory isolators.........? Link to comment Share on other sites More sharing options...
STERLING STINGER Posted May 10, 2010 Author Share Posted May 10, 2010 Looks like you stacked factory isolators.........? what does that even mean? Link to comment Share on other sites More sharing options...
WahooSteeler Posted May 10, 2010 Share Posted May 10, 2010 Looks like you stacked factory isolators.........? what does that even mean? is that coil spacer on your front springs all 1 piece or 4 pieces stacked together is what he's asking. Link to comment Share on other sites More sharing options...
STERLING STINGER Posted May 10, 2010 Author Share Posted May 10, 2010 Its all one piece...it was reccomended for me on this site Link to comment Share on other sites More sharing options...
WahooSteeler Posted May 11, 2010 Share Posted May 11, 2010 Its all one piece...it was reccomended for me on this site i thought it was. the design of it with the slits in it made LNFollow think it may be stacked, which is a generally agreed upon as a no-no from a safety standpoint. :thumbsup: Link to comment Share on other sites More sharing options...
comanche13 Posted May 11, 2010 Share Posted May 11, 2010 looks sweet man! Link to comment Share on other sites More sharing options...
