Bedliner question
the Roll on bed liner is only as good as the prep work done to the bed. I put rinoliner in my 86XJ and only had it peal up were i did not do the full prepand clean in the very back.
the rest of it has lasted several for several years of hard muddy use.
Ive found the roll on stuff is pretty rough, the rattlecan stuff fades really fast, and line-x is spendy,
There's some that can be sprayed on with a gun, and a member on here has used it, can't remember who.
I think your referring to that raptor stuff. Yeah, I've heard a lot of really good things about this stuff.
Here's the link to the stuff:
http://www.tptools.com/p/2600,233_U-Pol ... r-Kit.html
Here's a link to a very informative thread about someone who used it to line their interior:
http://www.jeepforum.com/forum/f9/my-u- ... ub-580879/
i had the reflex sprayed in mine and liked the looks of it but it does chunk up in a few places.to be fair though i throw engines,rea axles,wood,rocks and anything else you could think of in it so i'm probably asking a bit much of it.
I did it. U-Pol Raptor. Lots of pictures in my build.
Texture is slightly rougher than most plastic liners, but smoother than any other liner. Smooth enough not to capture grime or tear up the dogs feet.
I used Raptor Ive used several on different projects and this one was the best Ive used.
But its only been 5 months since I sprayed it in.If you have a compressor buy a cheap undercoat gun it works great,spend the time sanding and cleaning the bed or none of them will stay in.
duplicolor spray on bedliner sold at advanced they make roll on too.. i used the roll on for inside on my floors when i replaced the rotted pans and spray on for underneath and my rockers same as my f-150 i used spray on for my rockers as well heolds up good with a good scuffing
