xflowdaboi352 Posted March 14, 2010 Share Posted March 14, 2010 what the trans power button on the dash does Link to comment Share on other sites More sharing options...
jpdocdave Posted March 14, 2010 Share Posted March 14, 2010 changes the shift points to a higher rpm when in power mode, thats all. Link to comment Share on other sites More sharing options...
the_wizard_of_fire Posted March 14, 2010 Share Posted March 14, 2010 or, dumbed down, makes your manche go ZOOM! Link to comment Share on other sites More sharing options...
STERLING STINGER Posted March 14, 2010 Share Posted March 14, 2010 someone told me on here if you leave it on youll get better gas mileage too! :clapping: Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted March 14, 2010 Share Posted March 14, 2010 The AW4 tranny shifts electronically, so as mentioned it simply shanges the electronic shift points for better power or better economy. CW Link to comment Share on other sites More sharing options...
STERLING STINGER Posted March 14, 2010 Share Posted March 14, 2010 ya that Link to comment Share on other sites More sharing options...
jpdocdave Posted March 14, 2010 Share Posted March 14, 2010 STERLING STINGER said: someone told me on here if you leave it on youll get better gas mileage too! :clapping: i hear people say that to, simply not true in my personal usage. i get way better gas mileage in economy mode. rpm's kill gas mileage, bottom line. Link to comment Share on other sites More sharing options...
Pete M Posted March 14, 2010 Share Posted March 14, 2010 jpdocdave said: STERLING STINGER said: someone told me on here if you leave it on youll get better gas mileage too! :clapping: i hear people say that to, simply not true in my personal usage. i get way better gas mileage in economy mode. rpm's kill gas mileage, bottom line. Not necessarily. Fast acceleration kills mpgs. 80 mph kills mpgs. rpms are generally associated with these 2 circumstances, but are not the bad guys unto themselves. Link to comment Share on other sites More sharing options...
jimoshel Posted March 14, 2010 Share Posted March 14, 2010 I was told that for best fuel economy keep the engine on it's torque peak and max vacuam. So I installed a tach and a vacuam gauge. They were right. I haven't burnt a drop of gas since I hit that garbage truck I didn't see 'cause I was busy watching my gauges. :doh: Link to comment Share on other sites More sharing options...
M1A1TankerTom Posted March 14, 2010 Share Posted March 14, 2010 I don't think my trans power button works. The light does not come on and I don't feel crap when I flip the switch back and forth :fs1: Link to comment Share on other sites More sharing options...
STERLING STINGER Posted March 18, 2010 Share Posted March 18, 2010 T M1A1TankerTom said: I don't think my trans power button works. The light does not come on and I don't feel crap when I flip the switch back and forth :fs1: Check the fuse :dunno: Link to comment Share on other sites More sharing options...
Geonovast Posted March 18, 2010 Share Posted March 18, 2010 It also makes the tranny shift slower in comfort mode so you don't get that "annoying" shift shock. My 88 XJ was getting 26 in power mode averaging 70-75 on the interstate before I switched out the motor. Then it went to 18.5, found out the old motor was fine, and I was :headpop: Link to comment Share on other sites More sharing options...
one_bad_MJ Posted March 18, 2010 Share Posted March 18, 2010 my 89xj has the power button and i used it when towing a trailer it maked life alot easier when pulling. then when done i flip it back onto economy mode Link to comment Share on other sites More sharing options...
jpdocdave Posted March 18, 2010 Share Posted March 18, 2010 Pete M said: jpdocdave said: STERLING STINGER said: someone told me on here if you leave it on youll get better gas mileage too! :clapping: i hear people say that to, simply not true in my personal usage. i get way better gas mileage in economy mode. rpm's kill gas mileage, bottom line. Not necessarily. Fast acceleration kills mpgs. 80 mph kills mpgs. rpms are generally associated with these 2 circumstances, but are not the bad guys unto themselves. ok, but if 80 mph was only at 2,000 rpm it would not be bad. and when in economy mode, the same 3/4 throttle acceleration will shift sooner at less rpm. :typing: Link to comment Share on other sites More sharing options...
STERLING STINGER Posted March 18, 2010 Share Posted March 18, 2010 jpdocdave said: Pete M said: jpdocdave said: STERLING STINGER said: someone told me on here if you leave it on youll get better gas mileage too! :clapping: i hear people say that to, simply not true in my personal usage. i get way better gas mileage in economy mode. rpm's kill gas mileage, bottom line. Not necessarily. Fast acceleration kills mpgs. 80 mph kills mpgs. rpms are generally associated with these 2 circumstances, but are not the bad guys unto themselves. ok, but if 80 mph was only at 2,000 rpm it would not be bad. and when in economy mode, the same 3/4 throttle acceleration will shift sooner at less rpm. :typing: i guess if you use the power in the city and secondary roads, and the economy on the highway, youll be ok! Link to comment Share on other sites More sharing options...
terrawombat Posted March 18, 2010 Share Posted March 18, 2010 Pete M said: Not necessarily. Fast acceleration kills mpgs. 80 mph kills mpgs. rpms are generally associated with these 2 circumstances, but are not the bad guys unto themselves. This would explain my lackluster MPG ratings in my '01XJ. I need to slow down, but I always seem to be running late... Link to comment Share on other sites More sharing options...
Pete M Posted March 18, 2010 Share Posted March 18, 2010 jpdocdave said: Pete M said: jpdocdave said: STERLING STINGER said: someone told me on here if you leave it on youll get better gas mileage too! :clapping: i hear people say that to, simply not true in my personal usage. i get way better gas mileage in economy mode. rpm's kill gas mileage, bottom line. Not necessarily. Fast acceleration kills mpgs. 80 mph kills mpgs. rpms are generally associated with these 2 circumstances, but are not the bad guys unto themselves. ok, but if 80 mph was only at 2,000 rpm it would not be bad. and when in economy mode, the same 3/4 throttle acceleration will shift sooner at less rpm. :typing: But if you need to really accelerate to get into traffic, using econo-mode will use more fuel because the engine is struggling to keep up. mpgs become more about the driver and the situation at hand, and less about the Jeep. There's no reason power mode can't get the same mpgs as grandma-mode. grandma-mode just forces you to drive like, well, like grandma. Link to comment Share on other sites More sharing options...
the_wizard_of_fire Posted March 18, 2010 Share Posted March 18, 2010 personally, mine is always on power. people who touch that switch get their hand slaped... :fool: Link to comment Share on other sites More sharing options...
jpdocdave Posted March 18, 2010 Share Posted March 18, 2010 STERLING STINGER said: jpdocdave said: Pete M said: jpdocdave said: STERLING STINGER said: someone told me on here if you leave it on youll get better gas mileage too! :clapping: i hear people say that to, simply not true in my personal usage. i get way better gas mileage in economy mode. rpm's kill gas mileage, bottom line. Not necessarily. Fast acceleration kills mpgs. 80 mph kills mpgs. rpms are generally associated with these 2 circumstances, but are not the bad guys unto themselves. ok, but if 80 mph was only at 2,000 rpm it would not be bad. and when in economy mode, the same 3/4 throttle acceleration will shift sooner at less rpm. :typing: i guess if you use the power in the city and secondary roads, and the economy on the highway, youll be ok! that button has no effect while cruising on the hiway. Link to comment Share on other sites More sharing options...
xflowdaboi352 Posted March 18, 2010 Author Share Posted March 18, 2010 Thanks for all the replys i think i understand now lol :cheers: Link to comment Share on other sites More sharing options...
