jiffyjet2 Posted January 3, 2010 Posted January 3, 2010 My genuine official 1989 Jeep Comanche Service Manual refers refers to the manual transmissions in the 1989 model as either the BA-10/5 or the AX 5 (which mine has thank goodness) but I notice most on this forum refer to an AX 15. Is that a different gear box than the AX 5? Just curious. Jess
freakjeep93 Posted January 3, 2010 Posted January 3, 2010 :agree: but to explain more . the ax5 is the little brother of the ax 15 . the 1x 15 goes behind 4.0 L and the ax5 goes behind the 2.5L :thumbsup:
Geonovast Posted January 3, 2010 Posted January 3, 2010 To explain even a little further. 1989 was the switchover year from the BA 10/5 to the AX-15 Early 89 4.0 will have a BA 10/5 behind it Later 89 4.0 will have an AX-15 2.5 will have either the AX-4 or AX-5. AX-4 and AX-5 are identical with the exception that the AX-4 is missing the 5th gear.
akamcbird Posted January 3, 2010 Posted January 3, 2010 your "genuine official 1989 Jeep Comanche Service Manual" is stating the two 5 speed manual trannys offered '86-'89, (the ax-15 replaced the ba10-5 in mid '89)... in '89 4.0l came with either the ba10-5 or the ax-15, the 2.5l came with the ax-5. :mad: dam lack of words per minute.... you beat me
freakjeep93 Posted January 3, 2010 Posted January 3, 2010 now ive got a question . To explain even a little further. 1989 was the switchover year from the BA 10/5 to the AX-15 Early 89 4.0 will have a BA 10/5 behind it Later 89 4.0 will have an AX-15 2.5 will have either the AX-4 or AX-5. AX-4 and AX-5 are identical with the exception that the AX-4 is missing the 5th gear. does that mean the gears n a ax4 are higher so you can cruise at highway speed or is the gearing identical to the ax5 exept for no 5th
Geonovast Posted January 3, 2010 Posted January 3, 2010 AX-4 and AX-5 are identical with the exception that the AX-4 is missing the 5th gear. Generally the AX-4 received 3.55 gearing in the axles, and AX-5 received 4.10 gearing. AX-5 w/ 4.10 had better acceleration and overall power in the lower gears, but the top end ratio somewhat evened out between the 2. AX-4: 3.55(axle) x 1(4th gear) = 3.55:1 AX-5: 4.10(axle) x 0.85(5th gear) = 3.485:1
jimoshel Posted January 3, 2010 Posted January 3, 2010 Now I've got a question.I could look it up myself but I'm to lazy. If you're looking for a AX15 for a swap. or whatever reason.In what other models and years should you, I, me look at?
Geonovast Posted January 3, 2010 Posted January 3, 2010 AX-15 was used... mid 89-99 XJ mid 89-92 MJ mid 89-95 YJ 97-99 TJ 93 ZJ It may have been used longer in the TJ, not 100% on that.
Geonovast Posted January 3, 2010 Posted January 3, 2010 Yes it was. Even behind the 2.5 in the Dak 93(I think) and up.
jiffyjet2 Posted January 3, 2010 Author Posted January 3, 2010 Thanks for info. This forum is absolutely the best resource you could find!
Pete M Posted January 3, 2010 Posted January 3, 2010 Wasn't it also used in the Dakotas? and in some Japanese makes too. though I'm not entirely sure of the differences.
Geonovast Posted January 3, 2010 Posted January 3, 2010 Some Toyotas received the R151, which is a very close cousin to the AX-15. There's also some cousins to the AX-5, most of which are not interchageable, however I believe the W58 can be used to replace an AX-4/5 if you swap in an AX-4/5 input shaft.
RLCollins Posted January 4, 2010 Posted January 4, 2010 Which year and model AX-15 uses and external clutch slave cylinder? :hmm:
Geonovast Posted January 4, 2010 Posted January 4, 2010 I thought it was mid 93 :hmm: Definitely somewhere between the beginning on the 93 model year and the 94 model year. :thumbsup:
dasbulliwagen Posted January 4, 2010 Posted January 4, 2010 Another trans to consider would be the NV 3550. Though I can't tell you at the moment which vehicles to look at as donors. It is a much smoother trans than the AX models, but will also be more costly to find used.
Geonovast Posted January 4, 2010 Posted January 4, 2010 NV3550 is certainly an option... but unless you have a specifc reason to need the extra strength, AX-15(IMO) is the better way to go. More plentiful, cheaper, and a little less work to get in. They were the 5 speed behind the 4.0 in 00/01 XJs. From what I understand, finding a 5 speed in those years is not an easy thing to do.
RLCollins Posted January 7, 2010 Posted January 7, 2010 How do you tell the difference between an AX-4 or 5 and an AX-15? I saw an 1996 2.5 4 cylinder XJ in the bone yard this morning with a stick, I don't know which tranny it is. IIRC an AX-15 has a center piece added in the middle of the housing, but what about an AX-4 or 5 what is the difference? Also the external slave cylinder IIRC started in 1993 is this true? :hmm:
dasbulliwagen Posted January 7, 2010 Posted January 7, 2010 How do you tell the difference between an AX-4 or 5 and an AX-15? I saw an 1996 2.5 4 cylinder XJ in the bone yard this morning with a stick, I don't know which tranny it is. IIRC an AX-15 has a center piece added in the middle of the housing, but what about an AX-4 or 5 what is the difference? Also the external slave cylinder IIRC started in 1993 is this true? :hmm: An AX15 would not have been mounted behind the 2.5 in an XJ. It would have been the AX5.
Pete M Posted January 7, 2010 Posted January 7, 2010 yup. in Jeeps the AX-5 is a 2.5/2.8 trans, the AX-15 is a 4.0 trans.
Geonovast Posted January 7, 2010 Posted January 7, 2010 But for a cursory glance, since the AX-4/5 and AX-15 look similar, the AX-4/5 has a steel midplate, while the X-15 has an aluminum one. AX-4/5: AX-15:
RLCollins Posted January 8, 2010 Posted January 8, 2010 I want to Thank eveyone for their knowledge, and each one of you for your personal input, I will be going to the boneyard with a magnet. :D :USAflag: Does anyone have a picture of a external slave clutch cylinder on an AX-15?
