jmderyke Posted November 30, 2009 Share Posted November 30, 2009 No one made a throttle body spacer for my 86 2.5 so i made my own for free, from scraps. If it doesnt help atomize the fuel then i will rip it out and it will only would have cost me time ( i have a lot of it ) I will let you know in a week or so if it helped low end power or not. :fool: Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted November 30, 2009 Share Posted November 30, 2009 WHY NOT!! Good show!!! Post up what you find!! I have one on my TJ, with complete free flowing exhaust, K&N intake and a larger 62MM TB, I DO FEEL a difference. It's got a whine like a turbo with the air rushing into the bore!! CW Link to comment Share on other sites More sharing options...
Automan2164 Posted November 30, 2009 Share Posted November 30, 2009 How did you make it? Rob L. Link to comment Share on other sites More sharing options...
jmderyke Posted December 1, 2009 Author Share Posted December 1, 2009 i used 5/8" aluminum ( i had enough space for 3/4" but didnt have any laying around) and 1/16" aluminum sheet for fins (not sure if they are going to help). I made a template of the throttle body holes with gasket material and then I just used my drill and dremel with a hole cutter attachment on the drill and saws all. The hardest thing is making sure everything is center. then sorry to say i used jb weld to make sure the fins had a good seal on them. Now I'm matching the tbi, spacer and intake together for good flow. One thing i may change next time if this works is to use Teflon it insulates and has a melting point of 500 degrees and very easy to work with. Ive seen someone use a plastic cutting board for spacer i don't think its a good choice because polyurethane has a melting point of 260 degrees. :thumbsup: Link to comment Share on other sites More sharing options...
500 MJ Posted December 2, 2009 Share Posted December 2, 2009 I'm not so sure I'd hold the fins on with JB weld... I would think that stuff is the last thing I would want to get stuck somewhere in my fuel system. Doesn't it have a melting point too? Link to comment Share on other sites More sharing options...
anthony Posted December 3, 2009 Share Posted December 3, 2009 when you step on the go pedal does the throttle blade clear the fins ??? Link to comment Share on other sites More sharing options...
jmderyke Posted December 3, 2009 Author Share Posted December 3, 2009 I will refine this later, yeah jb sucks but beats the hell out of epoxy. the jb weld isnt in the bore of the plate.I have screws on the side holding the fins in too. fuel won't hurt jb weld and it can handle temps up to 400. and yes the fins are clear of the butterfly. Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 9, 2009 Share Posted December 9, 2009 update? Link to comment Share on other sites More sharing options...
jmderyke Posted December 9, 2009 Author Share Posted December 9, 2009 Well today was the first day i got to drive her around (I replaced the control arm bushings) and it is actually a noticable difference! I had a weak spot when taking off in first gear and it completely gone, with slightly better throttle response. I didn't notice any increase or decrease in top end power. Its most noticeable when the throttle plates are barely open, and you can hear the vacuum at different throttle positions or load conditions. Cruising was easier to do for better words it seemed a bit smoother. I haven't noticed anything bad or worse yet, I will run a tank or two threw and calculate my mpg and post that later. All and all not a bad trick. :yes: Link to comment Share on other sites More sharing options...
ICEBOX Posted December 14, 2009 Share Posted December 14, 2009 jmderyke Guess what was at the pull-a-part. and 86 with a 2.5 tbi still on it :( Link to comment Share on other sites More sharing options...
freakjeep93 Posted December 16, 2009 Share Posted December 16, 2009 just noticed but ive got a few throttle bodies . but tehh shipping wpuld kill me :ack: Link to comment Share on other sites More sharing options...
bermsurfer230 Posted December 16, 2009 Share Posted December 16, 2009 Any news on MPG difference? i'm considering making a spacer if not just for better throttle response. I spend a lot of time in the lower RPMs. Wring it out from time to time though, too ;) Link to comment Share on other sites More sharing options...
jmderyke Posted December 17, 2009 Author Share Posted December 17, 2009 Ive only ran threw 1/4 of a tank so far, with mixed driving in town and highway and it really about the same. (I will get some numbers soon) One thing I have noticed, that my throttle body now sweats. Its really cold on the outside of it, kinda like a soda on a hot day. wtf? I believe it is creating a bit of a pressure change with the turbulence kinda when you drain a O2 bottle it gets cold on the outside. Or its always done this and i just noticed haha. The only problem ive ran into is that my throttle body is now too tall for the cold air intake I was trying to build for it, I will figure something out though. Link to comment Share on other sites More sharing options...
jmderyke Posted December 18, 2009 Author Share Posted December 18, 2009 ok, I filled her back up and did the math with mixed driving highway and town 1.34 mpg increase. this is only my first fill up it can be more or less, cause here in Oregon you're not allowed to pump your own gas unless you have a motorcycle, so fill up can very. I will post a average down the road. :banana: Link to comment Share on other sites More sharing options...
Pete M Posted December 18, 2009 Share Posted December 18, 2009 have you cleaned or replaced the fuel injector at all? If the injector isn't spraying right, there'd likely be an increase. Link to comment Share on other sites More sharing options...
jmderyke Posted December 18, 2009 Author Share Posted December 18, 2009 I had already bought a new one and havent installed it yet to compare mpg. When I first got the truck i soaked the injector in seafoam for a few days. Link to comment Share on other sites More sharing options...
one_bad_MJ Posted January 30, 2010 Share Posted January 30, 2010 how does it atomize the fuel when the injectors squirt right into the valve openings i never liked TB spacers because there a waste of money and are added weight. MPFI shoots the fuel 1" away from the head openings and there is no way to "swirl or mix the fuel" before it goes into the head. unless you make a spacer that sits between the Intake manifold and the head. totally pointless i don't want to bash you for your work I'm just giving my opinion on TB spacers in general Link to comment Share on other sites More sharing options...
Pete M Posted January 31, 2010 Share Posted January 31, 2010 The original poster owns an 86 2.5L and so has throttle body injection so it's technically possible that the swirling action can enhance the distribution of the fuel. especially if the old injector isn't spraying like it should. Link to comment Share on other sites More sharing options...
Geonovast Posted January 31, 2010 Share Posted January 31, 2010 cause here in Oregon you're not allowed to pump your own gas unless you have a motorcycle Really? :nuts: Link to comment Share on other sites More sharing options...
reson46 Posted February 8, 2010 Share Posted February 8, 2010 cause here in Oregon you're not allowed to pump your own gas unless you have a motorcycle Really? :nuts: Yes, I avoid filling up in Oregon. I don't care for anybody touching my vehicle. Luckily last time I filled up in Oregon the pump attendant at Love's let me pump my own fuel. Maybe he just didn't want to mess with filling up the auxiliary tank. :yes: Willy Link to comment Share on other sites More sharing options...
dakal Posted June 16, 2010 Share Posted June 16, 2010 its true. i stand right at the back of the truck and watch them. Link to comment Share on other sites More sharing options...
