Accurate Wheeling Simulation / Physics
Automan2164
  • Replies 82
where do you download new maps and vehicles? and can you use more than one vehicle per map? like auto you use a hauled and the xj at the same time how does that work?
Check here: http://repository.rigsofrods.com/
Basic instruction. Download the .zip file, place in: My Documents\Rigs of Rods\packs, start up the game. As Rob suggested, only add one at a time in case there are problems. To get more than one truck in the game just pull away from the garage and walk back to the office.
I need to learn how to make a truck. I have a very good MJ model that I used during school when rendering SketchUp scenes.
Interesting. I have not experienced any issued with the RoR sites while using Google Chrome, which usually happens on sites. If you have an e-mail account that can accept up to 10mb I can send the .zip. PM your address if you want.
I am going to attempt making an MJ model. We will see how well this goes since tech-talk hurts my brain :shake:
Edit: started learning how these trucks are built. Just a little goofing off I did while trying to learn this stuff:
Image Not Found
My version must be different.
I can't drop vehicles in the packs folder. I can't even find it. I open the streams folder and then go into vehicles and drop the zip file in there. It has worked for most of the files. I was having the problem with the XJ just crashing the game. Some how I deleted the zip file and the XJ stayed. It works but my CPU is too slow for it.
I got a trailer pack that has 2 trailers in it. One with a gate and one without. I had to drop that pack in the terrain folder to get them to work.
There are a few other packs that have been freezing the game on start up too. I do not know why they do it.
Can someone take a screen capture of the proper way to download vehicles into the pack folder? I think a lot of compatibility issues are because I am going about it the wrong way to introduce vehicles into the game.
well here is my latest trip.
got the XJ all loaded up, and so is the camper
had to stop off at the RTI ramp really quick. pretty flexy for leafs...
then it was off to the rocks. was going good until i hit a few "steps". wrong wheelbase for them so i had to giver some throttle. well that didnt end well..
Version 0.36.2 here.
You are simply placing the vehicles in the wrong folder. Go to "My Documents" [NOT My Computer]then open the "Rigs of Rods" folder. You will see 6 folders, one of which is named "packs". Simply copy the (.zip) file you downloaded and paste it in the packs folder.
Image Not Found
(Note: your file path may read C:\My Documents\Rigs of Rods\packs)
You can see I have a few trailer, trucks, a Camaro pack, and the Rock Crawl track. All are working well together. As Rob suggested, I only put one .zip file in the packs folder at a time in case there are any issues with the game. This way I would know what caused the problem, but I have not had any issues yet.
