socal1200r Posted November 2, 2009 Share Posted November 2, 2009 I'm about ready to buy a 1988 Comanche 4wd, and it has stock steel wheels with 235/75-15 tires. I was looking on the local Craigs List, and someone is selling 15x8 chromed steel wheels with 31x10.5 tires. Will these wheels/tires work without rubbing on a non-lifted Comanche? Robert Norfolk, VA Link to comment Share on other sites More sharing options...
Geonovast Posted November 2, 2009 Share Posted November 2, 2009 Yup, although you may get some rubbing on the LCAs with the wheels turned to full lock. Link to comment Share on other sites More sharing options...
Pete M Posted November 2, 2009 Share Posted November 2, 2009 which wheels? 31s on no lift with aftermarket rims (typically ~4" of backspacing) will contact the fender flares something fierce. Stock Jeep rims will work better, but then you'd have rubbing on the lower control arms (which is actually easier to work around than flare contact). Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 2, 2009 Share Posted November 2, 2009 Yup, although you may get some rubbing on the LCAs with the wheels turned to full lock. Not necessarily. Are the 15x8 chromed steel wheels you refer to regulation Jeep wheels? If so, I agree, If not, better find out what the wheel back space is. EDIT: Pete beat me. :D Link to comment Share on other sites More sharing options...
Geonovast Posted November 2, 2009 Share Posted November 2, 2009 I always forget about the backspacing. :wall: Link to comment Share on other sites More sharing options...
Pete M Posted November 2, 2009 Share Posted November 2, 2009 backspacing can be a deal breaker sometimes. :( Link to comment Share on other sites More sharing options...
socal1200r Posted November 2, 2009 Author Share Posted November 2, 2009 Here's the link to the wheels/tires on Craigs List: http://norfolk.craigslist.org/pts/1443161626.html I have a '98 GMC Sonoma 2wd, 2" body lift, stock GMC alloy wheels, with 30x9.50 tires. They rub on the frame when turned full lock. To me, these wheels/tires on Craigs List look too big for a non-lifted Comanche. But if I'm wrong, by all means let me know! These are the other wheels/tires I'm thinking of getting. I know these will work, because the tires are 225/75, and the tires on there now are 235/75s. I'm kinda liking these better, because they're Jeep alloys, not chromed steel, and would give it more of a "jeep" look, lol! http://norfolk.craigslist.org/pts/1441868615.html So what's the verdict?! Link to comment Share on other sites More sharing options...
Pete M Posted November 2, 2009 Share Posted November 2, 2009 the alloy Grand Cherokee rims will fit better. those steel ones would only work properly with a 3" lift. Link to comment Share on other sites More sharing options...
Eagle Posted November 2, 2009 Share Posted November 2, 2009 I'm going to guess that those rims have about 4" backspacing. They will definitely NOT work on an MJ with no lift. I don't even think they'd work on an MJ with 3" of lift, without some serious trimming. Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 2, 2009 Share Posted November 2, 2009 :agree: Link to comment Share on other sites More sharing options...
akamcbird Posted November 2, 2009 Share Posted November 2, 2009 the tires on the alloys look like they have an odd wear pattern (like the sholders are almost gone) but those rims are nice lookn on an mj Link to comment Share on other sites More sharing options...
mvusse Posted November 2, 2009 Share Posted November 2, 2009 The only way 31s fit with no lift is with stock wheels. Even though 8" wide rims are better for 10.50" wide tires, most after market wheels have less than factory backspacing. You wouldn't be rubbing the control arms, but you would be eating your fenders. You'd need 3" lift and extended bump stops. Link to comment Share on other sites More sharing options...
socal1200r Posted November 2, 2009 Author Share Posted November 2, 2009 Thanks for the quick feedback. I think I'll pass on the chromed steel wheels and 31's, and go with the Jeep alloys with 225/75s for now. And the comment about the tires having an odd wear pattern on the Jeep alloys, the seller mentioned that in his ad, said it was due to an alignment problem or something. I'll probably put those tires on the back, and put the "normal" looking ones on the front (after I get them re-balanced of course!). Probably get the alignment checked as well once I get the truck and put different wheels on anyway, just to be safe... Link to comment Share on other sites More sharing options...
harlemantg@verizon.net Posted August 24, 2023 Share Posted August 24, 2023 Does anyone know if 225/70R16 BFG All-Terrain T/A KO2s will fit on a stock (no lift) 1988 Comanche? Now has 15x6 stock wheels. Switching to 16x7 aluminum wheels (Jeep Ultra Star from 1988 Grand Wagoneer). Getting conflicting guidance from various websites. Thanks! Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 24, 2023 Share Posted August 24, 2023 They are slightly smaller than 235/75R15 (28.4” vs. 28.8”) so should fit as long as the wheels don’t have some weird backspacing (I’m not familiar with those wheels). Link to comment Share on other sites More sharing options...
Pete M Posted August 24, 2023 Share Posted August 24, 2023 doesn't the grand waggy have a 6 bolt pattern? Link to comment Share on other sites More sharing options...
