jeepman09 Posted August 28, 2009 Share Posted August 28, 2009 OK i know most of you here have 4x4 MJ's However I do not and I am not intrested in doing the conversion to 4x4.. as i have a great YJ for just that purpose! My question is How do i go about lowering the suspension lets say 4" to 5"? If any one here has done this or can point me to where i can find info that would be GREAT!!!! Link to comment Share on other sites More sharing options...
89eliminator Posted August 28, 2009 Share Posted August 28, 2009 blocks in the rear, i think V8 rear coils from a ZJ will lower the front 3" Link to comment Share on other sites More sharing options...
mvusse Posted August 28, 2009 Share Posted August 28, 2009 I don't know that you can lower it that much without doing some serious front end work. The front axle would get in the way of the engine. For dropping it an inch or two you could get lower springs for the front, may have to get a shorter track bar, and shorter shocks. Rear could be done with blocks. Again, shorter shocks may be needed. Link to comment Share on other sites More sharing options...
Geonovast Posted August 28, 2009 Share Posted August 28, 2009 Doing blocks in the back won't need shorter shocks. 4-5 inches just isn't feasible. At that point your axle is going to be hitting stuff, like, say, your motor. These trucks were designed to go the other way, after all. beaterjeep put ZJ rear coils on the front of his 2.5, and it dropped it about 2 inches IIRC. A 4.0 would be dropped a bit more. You will probably need a shorter track bar after a few inches, and honestly I've never even heard of one. Link to comment Share on other sites More sharing options...
beaterjeep Posted August 28, 2009 Share Posted August 28, 2009 Agreed with 89Eliminator and Geonovast, I have done this using ZJ rear coils in the front with a 2.5. The initial drop was around 2", but has settled to 3" currently. The only thing that needed to be done to accommodate the coils and drop was that the upper bumpstop retainer had to be ground down a bit all around, and an alignment afterwards. For the rear, I have a set of 3" STEEL (do NOT use aluminum, as it will cause corrosion issues between the two metals) blocks that will be added to the factory SUA setup. EDIT: If you click on "Baby" in my sig, it links to my build thread, and has a lot of pics before, during, and after, including a side by side of the coils. Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 28, 2009 Share Posted August 28, 2009 As low as it gets. viewtopic.php?f=7&t=14658 http://www.streetsource.com/Profile.asp ... leID=39205 Link to comment Share on other sites More sharing options...
jbhill Posted August 28, 2009 Share Posted August 28, 2009 yea who would do that :nuts: lol Link to comment Share on other sites More sharing options...
fiatslug87 Posted August 29, 2009 Share Posted August 29, 2009 yea who would do that :nuts: lol How's it coming by the way? Link to comment Share on other sites More sharing options...
mvusse Posted August 29, 2009 Share Posted August 29, 2009 Oops. erred on my part. Yes, if you use blocks to lower the rear, shock length will not be affected as the stock shock mounts are below the spring, regardless of where the axle is. Link to comment Share on other sites More sharing options...
jeepman09 Posted August 31, 2009 Author Share Posted August 31, 2009 Thanks Guys I will try to post pics and stuff on here as i progress! I knew that i would find the type of info i was looking for here :cheers: Link to comment Share on other sites More sharing options...
Darren Posted August 31, 2009 Share Posted August 31, 2009 Just get some really small wheels and tires. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted August 31, 2009 Share Posted August 31, 2009 Just get some really small wheels and tires. I put a set of P195/45R15's on a VW I once had. That'll lower you down some! Bad thing is, I don't think they make that size anymore. Link to comment Share on other sites More sharing options...
