jeepman09
Everything posted by jeepman09
  1. Its most likely a grounding issue! like mentioned above replace the sockets and check all your grounds for corrosion! I have had similar issues on all my jeeps and could not 100% track the problem to one thing so just keep pokeing around and they will magically start working... wish there was a solid answer to your problem to give you! Good luck and post your findings! :cheers: :Canadaflag:
  2. Thanks Guys I will try to post pics and stuff on here as i progress! I knew that i would find the type of info i was looking for here :cheers:
  3. OK i know most of you here have 4x4 MJ's However I do not and I am not intrested in doing the conversion to 4x4.. as i have a great YJ for just that purpose! My question is How do i go about lowering the suspension lets say 4" to 5"? If any one here has done this or can point me to where i can find info that would be GREAT!!!!
  4. the rad i got from flea bay was worth much more than i paid i just got lucky on bidding! and i totaly disagree i do think the change over was well worth it! just my opinion! either way if it fixes your problem and your happy thats all that counts..
  5. There is another option that i used. What i did was instead of putting my money into a different resivor was to switch my radiator to a 92 and newer xj open system rad. The only other thing i did was change the vacume valve to the newer type also! The radiator i got on flea bay for $60. Its that easy and i never had an issue since... there are lots or write ups on this but its as simple as i listed above !!! good luck :Canadaflag:
  6. I had similar issues and to solve them i had to run a seperate ground for the stereo, also i ended up running a hot wire directly to the battery as the constant 12v source was not strong enough for the head unit! hope this helps!! :cheers: :Canadaflag:
  7. Well i run TREND MICRO and it has never let me down and takes alot less memory to run than NORTON!!
  8. Dude i have been going to that site for a while now and never had trouble! If i was you i'd try updateing my antivirus as i have never had any luck with NORTON all it ever dose is take over the PC and gave me false readings about viruses!! any how good luck and HAPPY NEW YEAR!!!! :Canadaflag:
  9. this is the site i found the mounting plate: http://www.canev.com/KitsComp/Component ... 20page.htm and thanks for the link i have read that before and it is a good write up! :Canadaflag:
  10. that means that i'll have to find myself a 5 speed tranny from a 4 banger or use a AC Electric motor rather than a DC one! If i get this Project underway I'll post regular updates as to what and why i chose to do things that way! thanks pete! :cheers:
  11. I have been toying with the idea :idea: of making an electric MJ for some time now and have come across one question that i am sure someone here can help me with! Is the Tranny (5 Speed) the same in a 2.5L I4 as in say a 4.0L, or will they both mount the same if i want to swap! reason for asking is i can find a mounting plate already machined for a 2.5L, but the MJ i have is 4.0L! any help would be appreciated :cheers: :Canadaflag:
  12. i have been looking for head liner material and was wondering if any one knows where in westren Canada i can find it? maybe a good internet source? i checked fabric land, and wal mart and nothing! also what is the best adhisive to use when i do find it? any tips or sugestions would be helpful! Thanks this fourm ROCKS!!!!
  13. Thanks guys I will be heading to the pick n' pull sunday i hope i can find a 4 10 amongst them! :cheers:
  14. i have the opertunity to pick from a couple of 8.8's from my local pick n' pull and i want to be able to tell the gear ratio perferably with out taking the cover off! any help on where to look for ratio markings or worst case how exactly do i tell ratios if i remove the cover? thanks in advance :bowdown:
  15. OK I know most things are interchangeable between XJ amd MJ from the doors forward However my local junk yard says that the steering colums are NOT!!! What I want to know is if i find a XJ colum from similar years will they be a direct swap in to my 88 MJ ??? :cheers:
  16. I am not sure what it was but i undid all electrical connectors and vac lines and blew them out with compressed air waited 15 min and hooked it all back up and away it went! go figure! i didnot find any moisture in any connectors or vac lines but hey it worked :cheers:
  17. what no one has any ideas???? sugestions!!! HELP!!!
  18. OK i need some help i tried to search and i am sure its here some where but i used some engine cleaner today and got everything super clean! i made sure i opened the distributer and dried it out! but when i start up my MJ it races to 2500 rpm and won't kick down WHAT HAVE I DONE? :wall: I would like to resolve this tonight before i don't get any sleep over it as my son has a feild lacrosse game tomarrow and its a 1.5 hr drive and i need this fixed HELP PLEASE GURU'S!!!!! :bowdown:
  19. Hey guys! My wipers just stoped! Nothing at all happens i checked the fuses and all is ok.... I tried to by pass the black box thing and everything comes on when i turn on the wipers including the washer pump! I do have a non int switch that i tried in its place and it worked fine. but it is not of the same type as it is ment for a non-tilt colum in other words not the same... Could it be just the Box is toast? if so do auto parts depo's cary them or do i need to try and find one in the junk yard from a cherokee? Any other sugestions on how to fix would also be helpful as i need these fixed for winter!!!! :Canadaflag: :cheers:
  20. THANKS Motion off road those are exactly what i am looking for !!!! you rock!!!
  21. when looking for a d44 off an xj how can you identify it as a d44 i am headed to the wreckers early tomarrow and am wondering!!
  22. OK can any one please tell me exactly what year of 5.0 mustang injectors fit my 88 MJ? part # and the such would be helpful or even complete details of which mustang i need to quote in order to get correct ones??? or even if you have a site that dose the cross reference!! Thanks :Canadaflag: :cheers:
  23. i'd like to get my hands on a set how do i contact them or is there a web address i can use?
  24. thanks to every one for the help i now have the MJ up and running but i am sure ill have more questions in the future you guys ROCK!!! :Canadaflag:
  25. that would be very helpful maddzz1 thanks!!!!
