bigalpha Posted May 18, 2009 Share Posted May 18, 2009 What are the stock speaker sizes for the doors? 5 1/4 or 4"? Link to comment Share on other sites More sharing options...
Pete M Posted May 18, 2009 Share Posted May 18, 2009 Door speakers are 5 1/4" :thumbsup: Link to comment Share on other sites More sharing options...
bigalpha Posted May 18, 2009 Author Share Posted May 18, 2009 Cool, thanks. I figure while the Dremel is charging, I'll go get some new speakers. The ones in there suuuuuuuck. Link to comment Share on other sites More sharing options...
garmj Posted May 18, 2009 Share Posted May 18, 2009 Get 2 Pair there is a place to mount another pair behind the seat in the B pillar. Wires are already there.It sounds a lot better with 4 speakers. Link to comment Share on other sites More sharing options...
bigalpha Posted May 18, 2009 Author Share Posted May 18, 2009 garmj said: Get 2 Pair there is a place to mount another pair behind the seat in the B pillar. Wires are already there.It sounds a lot better with 4 speakers. I thought the space in the b pillar was for a set of 6x9's? My ranger had 6x9s in that space, and it didn't do too much for the sound. Is it a lot more noticable in the MJ? Link to comment Share on other sites More sharing options...
mfpdm Posted May 18, 2009 Share Posted May 18, 2009 The b-pillar mounts are actually for 4x6's. Hard to find good ones that size. I'm looking at the Infinity reference series 4x6's to go in mine. They sound so good for such a small speaker. Will match them up with the 5 1/4s for the doors and maybe the 3's for the dash knee board. These are very clear crisp sounding speakers and will be just fine with the factory stereo and will fit the stock locations without butchering the trim. :cheers: Link to comment Share on other sites More sharing options...
bigalpha Posted May 18, 2009 Author Share Posted May 18, 2009 mfpdm said: The b-pillar mounts are actually for 4x6's. Hard to find good ones that size. I'm looking at the Infinity reference series 4x6's to go in mine. They sound so good for such a small speaker. Will match them up with the 5 1/4s for the doors and maybe the 3's for the dash knee board. These are very clear crisp sounding speakers and will be just fine with the factory stereo and will fit the stock locations without butchering the trim. :cheers: Oops, I didn't mean to say 6x9. I'm retarded. So the wiring to the door is green and black. The wires for the speaker are black and black w/ white stripe. Which wire in the door is which? Link to comment Share on other sites More sharing options...
Pete M Posted May 18, 2009 Share Posted May 18, 2009 I had 4x6s back there. Then switched to 6x9s in little boxes. Then added a small 10 sub. Then removed the 6x9s. Having 5 1/4s in the doors (actually they are component 5.25s with separate tweeters) and a small sub in the back turned out the best for me. :thumbsup: Link to comment Share on other sites More sharing options...
johnnyc Posted May 18, 2009 Share Posted May 18, 2009 You can put 6.5" speakers in the doors. You just have to drill some new mounting holes. I put some 4x6 Alpine speakers in the pillars. I don't think they make these speakers anymore though. Link to comment Share on other sites More sharing options...
bigalpha Posted May 19, 2009 Author Share Posted May 19, 2009 Thanks for the suggestions. I think for now, I'll just stick with the 4.5" in the doors. There was a bigger speaker in the driver door, but it stuck out into the door panel all funny. The PO had wired some other speakers behind the seats, but they were taken out before I bought it. The little 4x3 speakers in the B pillar (they are there), don't work; presumably because he wired the rear speakers differently. Worse part is, it's not even a nice set of speakers or head unit. I just went and picked up some Sony Xplode speakers from Wally World since I'm not building some high end system. Link to comment Share on other sites More sharing options...
Comanche County Posted May 19, 2009 Share Posted May 19, 2009 For 4x6's for the pillars grab the infinity front door speakers out of a Grand Cherokee at a JY. I pulled a pair of nice Cerwin-Vegas our of a ZJ. Also, do take your time and do not pry out the back panel or the B Pillars of your MJ. There's a couple of tricky screws to locate and you'll be tempted to pull and pry. Just find all the attaching points and take your time. The pillars will practically fall out if you do it right. Just replaced mine....kind of a pain, since I had to pull out my interior roll cage and I did break a couple of plastic peices.... :fs1: Link to comment Share on other sites More sharing options...
Eagle Posted May 19, 2009 Share Posted May 19, 2009 johnnyc said: You can put 6.5" speakers in the doors. You just have to drill some new mounting holes. I put some 4x6 Alpine speakers in the pillars. I don't think they make these speakers anymore though. Crutchfield sells (or used to sell) the correct speakers for that location, which are 4" round speakers on a 4" x 6" rectangular plate. I bought a set a couple or three years ago. Havn't looked recently to see if they still have them, but it's easy to make your own. In general, round speakers work and sound better than ovals (IMHO). Link to comment Share on other sites More sharing options...
bigalpha Posted May 19, 2009 Author Share Posted May 19, 2009 Ah, good ole Crutchfield. Always have what ya need. I'll keep an eye out for ZJs next time I hit the PaP. The panels that cover the hole that the speakers sit in are already broken and siliconed back into place. Will a 4x6 fit in that spot pretty easy? I assume you just remove the 4x6 plate and the new speaker should just pop right in. Link to comment Share on other sites More sharing options...
maddzz1 Posted May 20, 2009 Share Posted May 20, 2009 bigalpha said: Ah, good ole Crutchfield. Always have what ya need. I'll keep an eye out for ZJs next time I hit the PaP. The panels that cover the hole that the speakers sit in are already broken and siliconed back into place. Will a 4x6 fit in that spot pretty easy? I assume you just remove the 4x6 plate and the new speaker should just pop right in. Do you mean just removing the speaker cover on the door? You have to remove the whole door panel. I just replaced mine and when I pulled the passenger side I noticed it felt kind of light. Turns out the magnet had actually fallen off the stock speaker and was just sitting in the bottom of the door. :shake: Link to comment Share on other sites More sharing options...
bigalpha Posted May 20, 2009 Author Share Posted May 20, 2009 maddzz1 said: bigalpha said: Ah, good ole Crutchfield. Always have what ya need. I'll keep an eye out for ZJs next time I hit the PaP. The panels that cover the hole that the speakers sit in are already broken and siliconed back into place. Will a 4x6 fit in that spot pretty easy? I assume you just remove the 4x6 plate and the new speaker should just pop right in. Do you mean just removing the speaker cover on the door? You have to remove the whole door panel. I just replaced mine and when I pulled the passenger side I noticed it felt kind of light. Turns out the magnet had actually fallen off the stock speaker and was just sitting in the bottom of the door. :shake: Eagle said the proper size speaker is a 4" that's installed on a 4x6 plate. Will a 4x6 speaker just drop into that hole? Link to comment Share on other sites More sharing options...
WahooSteeler Posted May 20, 2009 Share Posted May 20, 2009 yes Link to comment Share on other sites More sharing options...
bigalpha Posted May 20, 2009 Author Share Posted May 20, 2009 WahooSteeler said: yes Cool, thanks. Link to comment Share on other sites More sharing options...
88mjmanche Posted May 20, 2009 Share Posted May 20, 2009 yea i got 2 5 1/4 in the front 2 4x6 in the rear 2 6x9 in the rear and also a pioneer 10 inch comp. all powered by an alpine amp in the back sounds soooo nice Link to comment Share on other sites More sharing options...
maddzz1 Posted May 21, 2009 Share Posted May 21, 2009 bigalpha said: maddzz1 said: bigalpha said: Ah, good ole Crutchfield. Always have what ya need. I'll keep an eye out for ZJs next time I hit the PaP. The panels that cover the hole that the speakers sit in are already broken and siliconed back into place. Will a 4x6 fit in that spot pretty easy? I assume you just remove the 4x6 plate and the new speaker should just pop right in. Do you mean just removing the speaker cover on the door? You have to remove the whole door panel. I just replaced mine and when I pulled the passenger side I noticed it felt kind of light. Turns out the magnet had actually fallen off the stock speaker and was just sitting in the bottom of the door. :shake: Eagle said the proper size speaker is a 4" that's installed on a 4x6 plate. Will a 4x6 speaker just drop into that hole? Eagle was referring to the speakers in the B pillar behind the seat, not the door. Were you referring to the B pillar? Ive only had the panels off once; I know there is a bracket that holds the speakers in, not sure how they mount w/out the bracket Link to comment Share on other sites More sharing options...
bigalpha Posted May 21, 2009 Author Share Posted May 21, 2009 maddzz1 said: bigalpha said: maddzz1 said: bigalpha said: Ah, good ole Crutchfield. Always have what ya need. I'll keep an eye out for ZJs next time I hit the PaP. The panels that cover the hole that the speakers sit in are already broken and siliconed back into place. Will a 4x6 fit in that spot pretty easy? I assume you just remove the 4x6 plate and the new speaker should just pop right in. Do you mean just removing the speaker cover on the door? You have to remove the whole door panel. I just replaced mine and when I pulled the passenger side I noticed it felt kind of light. Turns out the magnet had actually fallen off the stock speaker and was just sitting in the bottom of the door. :shake: Eagle said the proper size speaker is a 4" that's installed on a 4x6 plate. Will a 4x6 speaker just drop into that hole? Sorry, I wasn't very clear. I got the doors replaced with 5 1/4" speakers. The B pillar has a 4" that's installed on a 4x6 plate. If you remove the whole plate, you can just drop in a 4x6 in that space? Eagle was referring to the speakers in the B pillar behind the seat, not the door. Were you referring to the B pillar? Ive only had the panels off once; I know there is a bracket that holds the speakers in, not sure how they mount w/out the bracket Link to comment Share on other sites More sharing options...
Comanche County Posted May 29, 2009 Share Posted May 29, 2009 The hole pattern is the industry standard for 4x6s I believe. I matched to it to every 4x6 at Best Buy but didn't get any because they were too expensive. Any 4x6 should go right in there. Some are actually 4"x6" speakers, some are smaller speakers with a 4x6 plate and hole pattern. My cerwin-vegas that I put in were actually too deep by about 1/4" and the magnet rubbed the outer sheet metal of the truck so I fanagled a cardboard spacer for them. Link to comment Share on other sites More sharing options...
88mjmanche Posted May 30, 2009 Share Posted May 30, 2009 Comanche County said: The hole pattern is the industry standard for 4x6s I believe. I matched to it to every 4x6 at Best Buy but didn't get any because they were too expensive. Any 4x6 should go right in there. Some are actually 4"x6" speakers, some are smaller speakers with a 4x6 plate and hole pattern. My cerwin-vegas that I put in were actually too deep by about 1/4" and the magnet rubbed the outer sheet metal of the truck so I fanagled a cardboard spacer for them. NEVER SHOP AT BEST BUY they are rip offs you can get the same product on ebay for half the price Link to comment Share on other sites More sharing options...
