Difficult to do on a unibody vehicle, since the roof is structural.
Definately, they would have had to reinforce the hell outta it.
Anyone else find any contenders yet?
if anyone will measure the front 2 bed studs (center to center) ill go measure the ones on my s10 frame and we can compare :D
Similar enough dimensions, that I bet it would work.
Big pluses:
They repro them
It would still be a Jeep bed
I'm thinking it will take a 4' wide sheet (pretty sure, but not 100% on this)
Would compliment the boxy body
General wheelwell shape should match the front
No other body lines to worry about
Negatives:
Cost for repro
Rear axle might not be wide enough (Willy's P/U rears are wider than their ft axles)
I absolutely do not see how ANYBODY likes that ranger bed on an MJ. I don't like it period, but it looks 1000% out of place with the squared and angular look of an MJ. Complete crap. I liked the idea of the older F150 stepside if you gotta go that route, I agree it's the most angular and therefore would match up the best. I suppose you could cut some out of the center and weld back together to get the width right. Just my nickels worth...........
How about building a thrift side bed from a J-truck???
That is exactly what I figured I would base a new bed design from. It would be very simple to build, and I think it would suit the truck nicely. The only thing is I may be selling the MJ. If I keep it, I will probably build it.
I got busy today........
Someday I'd like to build a bed like this, but with angular fenders. :D
Cut the outer bedsides off an MJ bed, and you're 1/2 way there.
  • 4 years later...
I'm sorry, but that ford ranger bed is just awful on that MJ, just awful! :dunno:
Need to get in touch with Spencer at jeepsticker.com and get a set of JEEP tailgate stickers for on that... :thumbsup:
Don't need to Taz..........
There's something in place where the "other" badge was......
:rotf:
Just another option - there is a picture somewhere on the forum a MJ with a Ford stepside bed on it. I searched but I can't find it - you may be able to do better. It looked good by the way.
Yes, the topic is Right Here
But I lost the pictures :eek:
I remember that. I liked it then, and I like it now. I think it would look even better with the fenders and grille updated to the "new" XJ style (1997+).
Before everybody gets in a twist about keeping the look of the MJ style ... Feature "here " with Mazda B4000 flares with trapizoidal (sp) outer curve to match the MJ/XJ style .....Could be a good blend  :thumbsup:
