comancheman Posted February 15, 2009 Share Posted February 15, 2009 does anyone know a p/n on the o-rings for the oil filter adapter housing on a 89 4.0 or where i can get something comparable? TIA, Tim Link to comment Share on other sites More sharing options...
ren Posted February 15, 2009 Share Posted February 15, 2009 Yep. Check this out. Help! brand PN 82560 oil adapter and cooler gasket assortment. This is a multi pack, but I paid like $3 and change for it, and it has the "O" rings for the 4.0 up to 1996 in it, along with some others for GM stuff. You can get Help! stuff at just about any decent parts house. If they can get Dorman branfd stuff, then this should be available, also, as Help! stuff is Dorman.I keep 2 sets in the shop. :thumbsup: Link to comment Share on other sites More sharing options...
Geonovast Posted February 15, 2009 Share Posted February 15, 2009 I never found any at a parts store, I ended up getting one from work. (lots of big machines, they have literally a file cabinet full of every O-ring you could imagine) Link to comment Share on other sites More sharing options...
BLHTAZ Posted February 15, 2009 Share Posted February 15, 2009 Most any dealership should have them in stock. I know we always kept them in stock at the one I worked at. There are 3 o-rings you will need and these are the OE part numbers... :cheers: 33002970 33002971 33002972 Link to comment Share on other sites More sharing options...
Wildman Posted February 16, 2009 Share Posted February 16, 2009 And........for a little more 'detailed' info - http://www.lunghd.com/Tech_Articles/Eng ... -Rings.htm Link to comment Share on other sites More sharing options...
BLHTAZ Posted February 16, 2009 Share Posted February 16, 2009 And........for a little more 'detailed' info - http://www.lunghd.com/Tech_Articles/Eng ... -Rings.htm That site always has a lot of good info, but I found this a bit funny... Update: Posted by tsc on J.U. - "I have a 92 ZJ 4.0 that was a very large allen wrench.... Not all of them were Torx." There is no such thing as a '92 ZJ" (they started in '93) so that would likely be why he has something different :rotf: Link to comment Share on other sites More sharing options...
88 Beast Posted February 16, 2009 Share Posted February 16, 2009 The dealer stuff is way over priced, about $15 I think. Go the NAPA route. I work for the CAT dealer here, we got lots of o-rings. Cat is awfully proud of there stuff, still only paid a buck and half. Link to comment Share on other sites More sharing options...
Rohls Posted September 9, 2014 Share Posted September 9, 2014 Is this the kit I need for my 1992 MJ 4.0L...? http://www.amazon.com/Jeep-J-Series-Cherokee-Filter-Adapter/dp/B00B9OR1ZS/ref=cm_wl_huc_item Link to comment Share on other sites More sharing options...
Rohls Posted September 9, 2014 Share Posted September 9, 2014 Is this the kit I need for my 1992 MJ 4.0L...? http://www.amazon.com/Jeep-J-Series-Cherokee-Filter-Adapter/dp/B00B9OR1ZS/ref=cm_wl_huc_item Anybody...? Link to comment Share on other sites More sharing options...
ScottJeep Posted September 9, 2014 Share Posted September 9, 2014 http://www.jeep4x4center.com/oil-filter-adapter-seal-kit-33002970k.html Link to comment Share on other sites More sharing options...
Jeep Driver Posted September 10, 2014 Share Posted September 10, 2014 Item Price Qty Subtotal Seal Kit, Oil Filter Adapter 4.0L 1992-1998 Jeep Cherokee XJ Part # 4720363 $1.99 Remove item $1.99 Use a Promo Code or Morris Giftcard Subtotal : $1.99Shipping & Handling (Ground): $4.99Grand Total: $6.98 ----------------------------------------- That's the one I need but I refuse to pay more for shipping than the actual part. Link to comment Share on other sites More sharing options...
Rockfrog Posted September 13, 2014 Share Posted September 13, 2014 some handy info - Renix era - 87-90 0.799 x 0.103 AS568 size -117 1.296 x 0.139 AS568 size -219 2.484 x 0.139 AS568 size -230 HO era - 91+ 0.676 x 0.070 AS568 size -017 0.859 x 0.139 AS568 size -212 2.484 x 0.139 AS568 size -230 the metric filter nipple from Renix era 4.0L's can be swapped for one from a later adapter or from a standard block mount (YJ and TJ) ... part number - 53007563AB. this will allow the standard later model, common as dog snot, damn near available at the 7-11, PH8A style filter (I use Ford's FL-1A myself). And here is the picture verification of the Renix sizes for those that need it. Cost? About $1.92 after taxes Canadian funds and taxation Link to comment Share on other sites More sharing options...
cruiser54 Posted September 13, 2014 Share Posted September 13, 2014 some handy info - Renix era - 87-90 0.799 x 0.103 AS568 size -117 1.296 x 0.139 AS568 size -219 2.484 x 0.139 AS568 size -230 HO era - 91+ 0.676 x 0.070 AS568 size -017 0.859 x 0.139 AS568 size -212 2.484 x 0.139 AS568 size -230 the metric filter nipple from Renix era 4.0L's can be swapped for one from a later adapter or from a standard block mount (YJ and TJ) ... part number - 53007563AB. this will allow the standard later model, common as dog snot, damn near available at the 7-11, PH8A style filter (I use Ford's FL-1A myself). And here is the picture verification of the Renix sizes for those that need it. Cost? About $1.92 after taxes Canadian funds and taxation This^^^ is excellent info!! Needs to be a sticky. Link to comment Share on other sites More sharing options...
