sinnaevd Posted July 25, 2006 Share Posted July 25, 2006 How's progress been? Any new pics?? Anyt new things put togethor Link to comment Share on other sites More sharing options...
Derek Posted July 25, 2006 Author Share Posted July 25, 2006 progress has been slow, summer is always my busy time, with work and baseball and my girl being 150 miles away got the 60 tore down last night, wednesday ill put it all back together with the new seals and grease and such thats all the time i have till the following week Link to comment Share on other sites More sharing options...
Derek Posted July 26, 2006 Author Share Posted July 26, 2006 well game was canceled today due to no freaking umpires oh well got the 60 , rebuilt, with all new seals and grease, also added these mad 4wd outer axle seals, seem to be wicked sweet Link to comment Share on other sites More sharing options...
Derek Posted August 11, 2006 Author Share Posted August 11, 2006 she is going to be one big bisnatch got the rear of the springs mounted, slide the axles under there and got it all centered up, will be running 119" wheelbase, started thinking about the front shackle mounts i also got my hydro stuff in from west texas offroad, now i just have to remember where the hell i put my pitman arm reemed for a 1ton tre should be installing the tranny and case tomorrow afternoon its starting to look like a truck again Link to comment Share on other sites More sharing options...
pingpong Posted August 11, 2006 Share Posted August 11, 2006 How far froward did you move your axle?, and what is the wheel base? Just from the pics it appears you will have some clearance issues on the front part of the fender.. unless you trim a lil :brows: Link to comment Share on other sites More sharing options...
DirtyComanche Posted August 12, 2006 Share Posted August 12, 2006 That front inner fender has got to go. Link to comment Share on other sites More sharing options...
Oizarod115 Posted August 12, 2006 Share Posted August 12, 2006 i think those boggers might take care of that "issue" for him. ;) Link to comment Share on other sites More sharing options...
pingpong Posted August 12, 2006 Share Posted August 12, 2006 i think those boggers might take care of that "issue" for him. ;) I don't think those are boggers... I think they be TSL's Link to comment Share on other sites More sharing options...
Derek Posted August 13, 2006 Author Share Posted August 13, 2006 yup don't worry guys there will be lots of trimming to the finders and such hoping to keep all the lights but we will see when i really flex it out 119" wheelbase as stated above Link to comment Share on other sites More sharing options...
Derek Posted August 16, 2006 Author Share Posted August 16, 2006 ok well ive done a bit of work and got a couple more parts got the half doors all finished off, just need some primer and some carpet for the inside to make them echo less. going to find some outdoor carpet that doesnt mind getting wet, anyone got a source for me? got my twin sticks in for the d300, they are slick i can do rear low, front low, both low, both high, and rear high, but i also did not switch out the shift rails for ones without detents so i can't acidently put one in low and one in high got new u-bolts bent up yesterday so the rear isnt going to fall out now also got the shackles in i am going to use, going to northeast fastener today to get hardware, I'm hoping maybe they will have a sleeve for the yj bushings as well, the ones i got did not come with them ??? :confused: hoping to get the brackets for the shackle hangers all designed, cut and tacked in today, maybe ill even have a roller by tomorrow night. that would be nice cause i could get a good cleaning of the garage without it in the way ill have pics tonight or tomorrow general to do list: 1. shackle hanger brackets 2. MC and all new brake line install 3. ream pitman arm and shorten drag link 4. install hydro steering 5. install tranny and tcase 6. drive shafts 7. roll bar, gas tank mount, some kinda bed or something 8. fix some wiring 22 DAYS TILL IT NEEDS TO BE TESTED AND ON THE TRAILER TO FALL CRAWL Link to comment Share on other sites More sharing options...
Kernel Posted August 16, 2006 Share Posted August 16, 2006 how bout a measurment from inside rim to inside rim in the frt. ppppplease. edit: how far do your hubs stick out or any with the rim/tire combo? Link to comment Share on other sites More sharing options...
Derek Posted August 17, 2006 Author Share Posted August 17, 2006 how bout a measurment from inside rim to inside rim in the frt. ppppplease. edit: how far do your hubs stick out or any with the rim/tire combo? ill take some measurements for you tomorrow Link to comment Share on other sites More sharing options...
Derek Posted August 17, 2006 Author Share Posted August 17, 2006 well i wish i had my own welder cause i could probably have a rolling chassis tonight these are the brackets i made today how they will mount, well kinda they will be welded to the angle, going to mount the angle to the tow hook brackets and gusset it in well so it won't move, i will also be boxing them in on the front, back, and the bottom half doors that are finished and the view out of them twin sticks Link to comment Share on other sites More sharing options...
bogginboy Posted August 18, 2006 Share Posted August 18, 2006 damn that there is my dream project for right now. thats what i wanna build for the time being.. that is sweet as hell!! Link to comment Share on other sites More sharing options...
minydigger Posted August 19, 2006 Share Posted August 19, 2006 What kinda springs are you using? And did you mount the rear of the springs in the original lower control arm mount? Link to comment Share on other sites More sharing options...
87manche Posted August 19, 2006 Share Posted August 19, 2006 absoluetly the dumbest question ever: where'd you get the flip off smiley guy? I want one for my diff :) Link to comment Share on other sites More sharing options...
JOMJ87 Posted August 21, 2006 Share Posted August 21, 2006 Lowes has the outdoor carpet for cheap and its the kind that goes in boats. Cole Link to comment Share on other sites More sharing options...
Derek Posted August 22, 2006 Author Share Posted August 22, 2006 damn that there is my dream project for right now. thats what i wanna build for the time being.. that is sweet as hell!! thanks man What kinda springs are you using? And did you mount the rear of the springs in the original lower control arm mount? the are stock YJ springs for now, i need to get my brackets set so i can see if they will be enough, and yes i mounted the rear in the stock lower control arm brackets which i plan on beefing up absoluetly the dumbest question ever:where'd you get the flip off smiley guy? I want one for my diff :) PBB Lowes has the outdoor carpet for cheap and its the kind that goes in boats. Cole thanks thats what i was looking for Link to comment Share on other sites More sharing options...
Oizarod115 Posted August 23, 2006 Share Posted August 23, 2006 nice project... comin along well i see. this looks like the easiest front leaf conversion ive seen so far. i really don't wanna deal with control arms sooo thats what I'm lookin at doing. Link to comment Share on other sites More sharing options...
Derek Posted August 23, 2006 Author Share Posted August 23, 2006 ok i was really tired from getting up yesterday at 4:30 am so i didnt really have the drive to do much but i did spend about an hour and a half at 2 different parts stores getting brake lines and fittings and such, i think i have everything i need probably going to work on getting that stuff in today also BIG WORK PARTY at my house on SATURDAY, i have to be up at about 8 to sell my quad, so anytime after 8 you are welcome to come, working on the jeep all day then out to the Salty Dog at night Link to comment Share on other sites More sharing options...
Derek Posted August 23, 2006 Author Share Posted August 23, 2006 and yes i realize no one here really lives near me, i just copied it from my club forum Link to comment Share on other sites More sharing options...
Guest Posted August 24, 2006 Share Posted August 24, 2006 You are not that far from all..... Juan is just above Hartford and I am in central CT!!! We are both long time Jonfund members. CW Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted August 24, 2006 Share Posted August 24, 2006 Sorry for above..... Why the heck doses this board allow posting before logging in!?!? I upgraded my securities and now all my links are deleted. I have to re-log in everywhere and I forget....CRS setting in. :eek: :eek: CW Link to comment Share on other sites More sharing options...
Derek Posted August 24, 2006 Author Share Posted August 24, 2006 I'm in granby MA not CT so i am a bit farther then you think, its on the other side of springfield about 30-40 mins from hartford def cme up saturday if you wanna spin a few wrenches or just stand and laugh while the rest of us do Link to comment Share on other sites More sharing options...
Pete M Posted August 24, 2006 Share Posted August 24, 2006 Sorry for above.....Why the heck doses this board allow posting before logging in!?!? CW I left it that way so people having difficulties due to forum glitches can still comunicate their problems. At least that was the rationale. Not sure if it really helps any. :( Link to comment Share on other sites More sharing options...
