Stumpy Posted July 11, 2006 Posted July 11, 2006 i know Rusty has a bad rap for his springs but what about his control arms? also who makes good adj control arms for a 6" lift? i need to get a set of real control arms so i can take the MJ wheelin!
BIGHEEP Posted July 12, 2006 Posted July 12, 2006 I ran Rusty's short arms on my XJ and they are now on my MJ. They are beefy and I have no complaints.
DirtyComanche Posted July 12, 2006 Posted July 12, 2006 I've seen the fixed length ones, and nothing bothered me at the time. However, I figure a few bucks more for something else, or making your own, and just having some peice of mind.
Stumpy Posted July 12, 2006 Author Posted July 12, 2006 i'm gonna see what i can get the RE ones for. i got my new RE 5.5" TJ coils for $135 shipped so i think i can get a good deal on the control arms.. :D
DansGreyMj Posted July 12, 2006 Posted July 12, 2006 how muh lift did u get from those coils cuz i heard tj coils don't give as much lift on an xj/tj
Stumpy Posted July 12, 2006 Author Posted July 12, 2006 bout this much..hehe here is with 3" coils and AAL i hope that once i get my rear bumper made and trail gear in the bed it will sit more level. i look 900lbs of scrap steel to a salvage yard yesterday and the rear sagged just a little lower than the front so i should be ok..lol
pingpong Posted July 12, 2006 Posted July 12, 2006 The only bad thing I know about Rusty's control arms is that he uses stock XJ/MJ/ZJ/TJ rubber bushings, that wear out quickly when overflexed or used alot
CWLONGSHOT Posted July 12, 2006 Posted July 12, 2006 The only bad thing I know about Rusty's control arms is that he uses stock XJ/MJ/ZJ/TJ rubber bushings, that wear out quickly when overflexed or used alot I feel I must correct you here... :D . The worst thing about Rustys parts is that they are made by RUSTYS!! Just to get your parts, you must deal with very poor customer service AS WELL AS sub quailty parts. Not to mention that I have seen many poor welds and herd of weld failures coming from RUSTYS. You get what you pay for. there is a saying out there...."Always time to do it over....never time to do it right". Well I say do it right the first time and do your self a favor, buy from a different company. My 2 cents... CW
Twisty Posted July 12, 2006 Posted July 12, 2006 has anyone ever tried rough country adjustables ive searched on JF for a while, and ive read many posts bashing RC...but none of the people owned them (and neither do i...but i wouldnt have a problem purchasing a set). the people who owned the kit loved them. if it means anything, the people on extreme 4x4 (powerblock on spike) used RC arms on one of the trucks they built (suburban gorilla).
jage Posted July 13, 2006 Posted July 13, 2006 The only problem I had with Rusty's non-adjustable LCAs is one got dented on a rock and the tube dent just got worse probably would have failed in time. When I cut the one in half to salvage the axle they were pretty thick tubing, so I imagine that any tube control arms could have had the same problem. I never felt like the bushings were a problem.
Pete M Posted July 13, 2006 Posted July 13, 2006 There are different strengths of steel tubing and I have to imaging that inexpensive control arms don't use the strongest stuff out there.
pingpong Posted July 13, 2006 Posted July 13, 2006 :smart: I have run a set of Rusty's LCA before, as well as a set or Procomp Lca's. Both where made out of thick tubing.. as for strength I never wheeled either rig... so I don't know. :dunno: I can tel you Pro comp used urathane bushings, and they did not wear out, where as Rusty's used stock style ones and they were slam wore out after a yr of strret use :smart:
jage Posted July 13, 2006 Posted July 13, 2006 Yeah I don't know exactly for strength but although the dent grew they never failed. Tube gets pretty weak once you dent it, so I imagine they were pretty strong. Anyway, don't take it as a recommendation!
JeepJeep82 Posted July 14, 2006 Posted July 14, 2006 So far so good from my ajustable lowers. I have had people say that it looks loke his quality has improved. They have only been on for about three months so time will tell. no complaints on his service here either but I am just one happy customer.
