thejum57 Posted December 3, 2008 Share Posted December 3, 2008 Are there any good sorces for Comanche parts, new parts. I don't mean the big, useless chains. At the IFSJA for example there is BJ'S Offroad, Z&M etc. For example, I'd like to find a temp. guage. The AutoZones etc. have no clue. While I'm on the subject, can you replace an "idiot light" with a real guage with no big modification? Link to comment Share on other sites More sharing options...
Darren Posted December 3, 2008 Share Posted December 3, 2008 yeah swap gauge clusters that solves all your idiot lights all at once, a pretty easy swap and real cheap too. Link to comment Share on other sites More sharing options...
manche Posted December 3, 2008 Share Posted December 3, 2008 ive been wanting to do a custer swap but what needs to be modified in order to go from dummy lights to gauges and and reguations on odometers? reason i ask is if i got to a junk yard to pull one :huh???: Link to comment Share on other sites More sharing options...
Pete M Posted December 3, 2008 Share Posted December 3, 2008 The engine temp and oil pressure switches need to be swapped for temp and pressure sensors. Try to get one from your era. 84-86. 87-90, and 91+. The 84-86 can be adapted to the 87-90 (and vis-versa) by reusing some speedo cable parts fro the old cluster. Link to comment Share on other sites More sharing options...
manche Posted December 3, 2008 Share Posted December 3, 2008 so do i need to splice anything or is it a direct swap and do i take a drill to roll back odometer to me current milage ? :???: Link to comment Share on other sites More sharing options...
Pete M Posted December 3, 2008 Share Posted December 3, 2008 No splicing is required. Just swap out the sensors. This will show you how to adjust your ODO: http://www.naxja.org/forum/showthread.php?t=921205 If you take it to a shop, they can reset the odometer legally and give you the proper paperwork. Link to comment Share on other sites More sharing options...
manche Posted December 4, 2008 Share Posted December 4, 2008 wats the shop run to do it ? and how is it illegal in some states if you set it as your current milage? Link to comment Share on other sites More sharing options...
Pete M Posted December 4, 2008 Share Posted December 4, 2008 wats the shop run to do it ? Don't know. Can't be much though. Call and ask around your area. and how is it illegal in some states if you set it as your current milage? Because unscrupulous individuals can roll back the odo and sell a 200k miles car as a 100k miles car. Essentially, the government doesn't trust regular people to do it properly. If a shop does it and you have the paperwork, your tail is covered. Link to comment Share on other sites More sharing options...
manche Posted December 4, 2008 Share Posted December 4, 2008 if i did do a swap how would they know??? :???: Link to comment Share on other sites More sharing options...
manche Posted December 4, 2008 Share Posted December 4, 2008 i can't find the sensors for the 2.5l at autozone the temp and oil ???? :fs1: Link to comment Share on other sites More sharing options...
Pete M Posted December 4, 2008 Share Posted December 4, 2008 I don't know. But then, I'm not the cops. 8) Some guys do it themselves, others have a shop do it. It's all up to you. Link to comment Share on other sites More sharing options...
manche Posted December 4, 2008 Share Posted December 4, 2008 well if i was to ppull the temp and oil press of a 4.0xj would those work??? :ack: Link to comment Share on other sites More sharing options...
xj_dummy Posted December 4, 2008 Share Posted December 4, 2008 i can't find the sensors for the 2.5l at autozone the temp and oil ???? :fs1: Did you ask for one with a gage or a light? I bought mine at Kragen (Checker same place). I look to see if I still have the box for them or a part number on them as well. Link to comment Share on other sites More sharing options...
summerinmaine Posted December 4, 2008 Share Posted December 4, 2008 if i did do a swap how would they know??? :???: IIRC recording mileage at title transfer, and other times in a vehicle's life, is under a federal mandate. Here's what Kalifornistan has to say: Odometer Mileage Reporting Odometer Mileage Readings Legislation requires that the department collect and validate the odometer mileage reading for most motor vehicles upon initial registration and registered owner transfers in compliance with the Federal Truth in Mileage Act of 1986. Reporting of the odometer mileage reading assists in the detection of odometer tampering. The collection of this information provides consumers with an accurate record of the mileage affecting the retail value of the vehicle. When Do I Report Odometer Mileage Readings? Odometer mileage readings are encouraged for all motor vehicles, but are mandatory when: you initially register a motor vehicle or transfer ownership, and the vehicle is less than 10 years old. Are There Any Exceptions To This Requirement? Yes. Reporting the odometer mileage reading is encouraged, but not mandatory if: the vehicle is 10 years old or older, the vehicle is a commercial vehicle with unladen weight of more than 8,500 lbs (more than 16,000 lbs gross vehicle weight), the vehicle is sold directly by a manufacturer to any agency of the United States, or the vehicle is a new vehicle transferred prior to first retail sale by a dealer. YMMV. :brows: Link to comment Share on other sites More sharing options...
carnuck Posted December 5, 2008 Share Posted December 5, 2008 When I swapped my dash to get gauges (about to do it again so I have the auto shifter marker hooked up) I undid the screws holding the speedo in (with pics as proof) and swapped it into the new one. Pretty easy to do. Beware that there are a couple different cluster plugs and if you get an '86, it won't work in an '87 (especially 4 cyl to 6 cyl) Link to comment Share on other sites More sharing options...
manche Posted December 6, 2008 Share Posted December 6, 2008 were is the oil pressure sensor on a 2.5l i want to do this but need to know were that is :doh: Link to comment Share on other sites More sharing options...
Pete M Posted December 6, 2008 Share Posted December 6, 2008 I don't know. On the 4.0 it's on the pass side of the block and has a single wire going to it. Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 6, 2008 Share Posted December 6, 2008 I looked in the FSM component locator, but it doesn't show it in an illustration...it only says that it's "on the right side of the block near the distributor". On the 4.0L, it's actually screwed in the side of the oil filter adapter housing. Link to comment Share on other sites More sharing options...
