robfg67 Posted October 2, 2008 Posted October 2, 2008 If anyone read the thread Question on rear axle upgrade they are familiar with the story...I bought a rear axle from eBay for $5 and the front axle for $250 (from same guy-Jeeps Unlimited in Providence, RI. Both came from a '94 Cherokee and have 4.10 gears. Front: Dana 30 High pinion - reverse cut - 27 spline, 1.16" diameter shafts, 7.13" ring gear & 5-260x u-joints- this axle is vacum non-disconnect. Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found Rear: Chrysler 8.25 - 27 spline, 1.17" diameter shafts, 8.25" ring gear, 3" axle tube Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found Image Not Found
CWLONGSHOT Posted October 3, 2008 Posted October 3, 2008 Ouch.. Thats quite a pile of rust you have there.... start cleaning..... The lower shock mounts on the FRONT axle looked FUBAR.. are they OK? CW
Sir Sam Posted October 3, 2008 Posted October 3, 2008 Jesus, did they dredge it off the bottom of the ocean? Man, talk about a bunch of snapped bolts!
500 MJ Posted October 3, 2008 Posted October 3, 2008 ... and THAT is why I hate road salt. They should clean up OK. Sandblasters work the best. It's gonna take some time though... Get them clean BEFORE you try to loosen any bolts!
robfg67 Posted October 3, 2008 Author Posted October 3, 2008 Here are some close-up pics of the front axle shock mounts...am I in trouble here? Image Not Found Image Not Found Image Not Found
robfg67 Posted October 3, 2008 Author Posted October 3, 2008 What's sandblasters? Are these axles much worse than normal? Remember, these came from a '94 Cherokee in the northeast!
jtdesigns Posted October 3, 2008 Posted October 3, 2008 What's sandblasters? Are these axles much worse than normal? Remember, these came from a '94 Cherokee in the northeast! Sandblasting,,read,read,read.
robfg67 Posted October 3, 2008 Author Posted October 3, 2008 I'm familiar with sandblasting. I wasn't sure if he meant something else.
offroader461 Posted October 3, 2008 Posted October 3, 2008 wow thats a ton of rust...probably couldve found a better front axle for cheaper but can't beat $5 for the rear LOL :cheers:
robfg67 Posted October 3, 2008 Author Posted October 3, 2008 I knew that there would be rust, and I'm not happy about it, but I'll put in the time to de-rust and prime & paint. Am I in trouble with the front shock mount-it looks like its rusted through. Do these have to come off anyway for the MJ shock mounts? If not, then can I take the shock mounts off of the MJ and weld ono this axle?
FxRacing282 Posted October 3, 2008 Posted October 3, 2008 i live here in new england, which is part of the "rust belt" of America . and those don't look that out of shape for a 14 year old truck exposed to NE. as for the mounts go. if you are going through the time to rid the metal of its natural process of deteriation (rust). cut em all off, put new ones on it. bring it to a trusted welder and give him a 6pack and a jelly roll of cash. the stub shafts as i call them. which is what i call the axle shaft that is between the wheel and u joint looks fairly rough. and the ears look kinda gnarly. i have no idea of your budget on this but its probabally not a bad idea to just get new axle shafts. but if its a off road rig then who cares. but its well worth the $255+ shipping. heck i just paid $200 for a chevy 10 bolt 8.5 front axle for my truck.
robfg67 Posted October 3, 2008 Author Posted October 3, 2008 FxRacing282, where should I get new shock mounts? Would a welder create new ones out of weld stock? What about axle shafts? Bone yard or dealership?
FxRacing282 Posted October 3, 2008 Posted October 3, 2008 a lot fo the guys around here just look around on the web or go to the dealer to get new mounts. you may be able to find a welder who will make them but if you give him the mounts and tell him where you want them its gonna be a little cheaper on that bill. I'm not to familiar with mass, but if you take 495N to 125N and then RT4 east in nottingham there is a welding shop that i have heard good things about. axle shafts i would not go to the dealer. i work at a garage and also go to a vocational garage for school and dealer stuff is big money. you can get same or better (or less) quality from places that are going to specialize in these axles. I'm sure someone on here who has done it before can help you out. there are a couple guys on here in mass with big mj's. so just check your phone book for welding and give the people a call and get to know them and decide if they are someone you want to risk your life with.
JeepcoMJ Posted October 3, 2008 Posted October 3, 2008 great deal on the rear axle. sorry to say, but the front axle is about worthless unless you can fabricate. it's best to pull the gears from the front axle and put them in another axle. your unit bearings are likely shot, I bet the brakes are close to junk, it will need new ball joints, and ALL new seals. new Ujoints will be needed, good luck getting the stabilizer and trackbar off too. it needs new shock mounts (at the very least). you will also need to inspect the coil spring buckets...that's by far the worst rust in that area I've ever seen. your lower control arm mounts probably have many many small holes in them, and will likely be junk. all of that can be taken off of your comanche's axle, but you'll need a plasma cutter or something of that sort. I'd build all new mounts for the axle, raise the lower mounts up to behind the axle so it doesn't catch on them offroad, raise the UCA mounts up, and give myself some free lift with raised coil buckets too. also a relocated trackbar mount so that it maintains proper geometry, and an OTK steering setup.
robfg67 Posted October 3, 2008 Author Posted October 3, 2008 ...and other than that how did you like the play Mrs. Lincoln? JeepcoMJ, thanks for your opinion/advise-I really didn't know any better when I picked it up. The brakes are junk and your right about the u-joints, ball joints & mounts-they are no good either! I'm sure a good shop would charge in the neighborhood of $500 to "fix" this axle. Would the 4.10 gears fit into my stock Dana 30 front axle-perhaps, that's the way to go? If not, I'll call this joker and see if I can get my money back. CW, how much did you want for your front axle?
Sir Sam Posted October 3, 2008 Posted October 3, 2008 .......I'll call this joker and see if I can get my money back. LOL. You saw the axle when you picked it up. You paid his price, there's no reason he should give you any money back.
robfg67 Posted October 4, 2008 Author Posted October 4, 2008 Sir Sam, you could be right, but I'm still going to ask.
maddzz1 Posted October 4, 2008 Posted October 4, 2008 Rob, you may have a shot at returning the axle. In your other thread you posted that he said it had the larger u-joints and if it has 260 u-joints they are not the larger ones he said. You also said he posted the brakes are good and they may not be. Are They?
cocco78 Posted October 4, 2008 Posted October 4, 2008 Wow, that front axle is way to far gone to make it worth while! Just by looking at it I'd say all the mounts need to be cut off and replaced. And yeah, probably new ball joints, unit bearings, u-joints, and probably axle shafts! Oh and new brake disks, doesn't look like they are turnable! I bet it would cost at the very least $750 to get that axle into shape with replacing everything an new brakets! Um, if you already have an axle under your MJ just take the gears and carrier out of this axle and pay a shop to put them in your axle, will probably need to buy an install kit with new seals and bearings. But used gears are very hard to setup correctly! But if you want to fix that rusty axle look into this http://www.ballisticfabrication.com/XJ- ... -1542.html Balistic fab has by far the best prices and service out there. I have ordered many things from them and they always ship very fast and are great to deal with..
robfg67 Posted October 4, 2008 Author Posted October 4, 2008 Jim-your right. One of his emails stated good brakes and larger u-joints. Do you know of this place? It's Jeeps Unlimited on Ambrose Street-just down the road fron the Foxy Lady.
robfg67 Posted October 4, 2008 Author Posted October 4, 2008 cocco78, will the 4.10 gears fit inside my stock Dana 30? If so, does anyone know what the typical cost might be?
JeepcoMJ Posted October 4, 2008 Posted October 4, 2008 Jim-your right. One of his emails stated good brakes and larger u-joints. Do you know of this place? It's Jeeps Unlimited on Ambrose Street-just down the road fron the Foxy Lady. HOLD IT. you bought this from a JEEP STORE?! dude, you've officially been hosed. unfortunately for them, if you they didn't give you a disclaimer about the VERY VERY POOR condition of that axle, they HAVE to give you back your money. if Jeeps are their profession then they can be held accountable for mis-information and probably quite a few other things. they robbed you buddy, go get your $$$ back
Sir Sam Posted October 4, 2008 Posted October 4, 2008 Jim-your right. One of his emails stated good brakes and larger u-joints. Do you know of this place? It's Jeeps Unlimited on Ambrose Street-just down the road fron the Foxy Lady. HOLD IT. you bought this from a JEEP STORE?! dude, you've officially been hosed. unfortunately for them, if you they didn't give you a disclaimer about the VERY VERY POOR condition of that axle, they HAVE to give you back your money. if Jeeps are their profession then they can be held accountable for mis-information and probably quite a few other things. they robbed you buddy, go get your $$$ back uh huh, so when he looked at when he picked it up it was in perfect condition then?
JeepcoMJ Posted October 4, 2008 Posted October 4, 2008 Jim-your right. One of his emails stated good brakes and larger u-joints. Do you know of this place? It's Jeeps Unlimited on Ambrose Street-just down the road fron the Foxy Lady. HOLD IT. you bought this from a JEEP STORE?! dude, you've officially been hosed. unfortunately for them, if you they didn't give you a disclaimer about the VERY VERY POOR condition of that axle, they HAVE to give you back your money. if Jeeps are their profession then they can be held accountable for mis-information and probably quite a few other things. they robbed you buddy, go get your $$$ back uh huh, so when he looked at when he picked it up it was in perfect condition then? nope, but some yuppie who just wants replacement axles doesn't know any better. it is THEIR JOB to disclaim ANY AND ALL pertinent information as to the completely terrible shape of the axle. if they did not, then it's their fault, not his. as a company with a reputation to save, I hope they give him his money back.
