feerocknok Posted July 6, 2006 Share Posted July 6, 2006 DirtyComanche said: Doesn't matter, I'm building the perches anyways. Lol, good point. Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 6, 2006 Author Share Posted July 6, 2006 Yeah, well, pinion angle at 10* up, caster would be at like +4 then. That'd be scary. I'll leave it relativly flat. Yes, I'm too lazy to rotate the knuckles. Link to comment Share on other sites More sharing options...
pingpong Posted July 6, 2006 Share Posted July 6, 2006 Remember to set you caster to what ever the caster angle was on the donor vehicle, other wise you will have some crazy handling issues. I am still chrunching numbers to figure out which leaves I am going to use as well. I plan on running a shackle reversal with a square driveshaft driving vibes don't matter on my rig, as i t is a trailer KING anyways :D More then likely I am going to ditch my front bumper for one with a better approach angle, I was also thinking of dovetailing the front :nanner: As I will no longer need my coil bucket area, plus it will allow me to run bigger tires :eek: Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 6, 2006 Author Share Posted July 6, 2006 I want to dovetail my front (shark nose?) just because I enjoy cutting things up so much. Link to comment Share on other sites More sharing options...
feerocknok Posted July 7, 2006 Share Posted July 7, 2006 I love my square shaft in rear on my Yota, but it won't see the streets. Link to comment Share on other sites More sharing options...
Oizarod115 Posted July 7, 2006 Share Posted July 7, 2006 pingpong said: More then likely I am going to ditch my front bumper for one with a better approach angle, we might need to talk if you decide to do this... i have no qualms with hand-me-down parts. Link to comment Share on other sites More sharing options...
pingpong Posted July 7, 2006 Share Posted July 7, 2006 All I have to say.. is once it is off... who ever shows me the money.. as quick as possible will get it :D But there is a list of ppl who have claimed "dibs" on it. Whats this "DIBS" crap anyway :chillin: Link to comment Share on other sites More sharing options...
jage Posted July 8, 2006 Share Posted July 8, 2006 DirtyComanche said: I want to dovetail my front (shark nose?) just because I enjoy cutting things up so much. Your avatar can't handle another picture! Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 8, 2006 Author Share Posted July 8, 2006 Well, I picked up some SJ front leaves today. Set 'em in place to looksee at things. Looks good so far. Just gotta wait for the machine shop to be open again (buy steel). I also got a ZJ pitman arm. Is there a way to pull a pitman arm without the puller? Can I BFH it? Link to comment Share on other sites More sharing options...
Bounty Hunter Posted July 9, 2006 Share Posted July 9, 2006 Doubt it. only other way I know of is with a cutoff wheel and cold chisel. Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 9, 2006 Author Share Posted July 9, 2006 Well, the pitman arm is @#$%ed anyways.... The TRE had seized in it so bad that I cut it off with the arc torch.... Link to comment Share on other sites More sharing options...
Bounty Hunter Posted July 9, 2006 Share Posted July 9, 2006 Oh ya, and then there's the gas ax Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 11, 2006 Author Share Posted July 11, 2006 As an update: I shaved the stock front crossmember, and pulled apart alll remaining steering (pump, box) as it is just in the way. I bought steel, but, realized I'd screwed up. I bought 32.75" of 4x4x.250 angle to make the front crossmember to hang the leaf pockets from. Later I realized that my spring centre-centre is 32", and the springs are 2.5" wide. Tomorrow I'll buy 35" of 4x4x.250 angle. I also bought various flat bar. Two peices were 12x4 to be the outside supports. After looking at it I realized that if I made them 12x5.5 they'd serve dual purpose as a steering box brace. And I bought assorted 3x3x.250 HSS (square tube) to cut open and make the leaf hangers out of. These I think will work. The idea is to weld the crossmember and supports to the front of the truck, and bolt the leaf hangers to them. This will allow me to easily 'do away' with them if I decide to at some point. Unless I get lazy and just weld them in place. Oh, and I trimmed the front fenders on my XJ there was some rub with the 31s. Then I relocated the flares higher, like the MJ. Then I decided to bedliner the lower quarters on it, but didn't quite get around to it. I've also decided to put my LAs on it, as my buyer backed out. I think it's scared of me already. Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 11, 2006 Author Share Posted July 11, 2006 After writing this, I had an epithany (of that's what it's called). I will use 35" of 4x8x.250 angle, which will (hopefully) allow me to mount my winch behind it, like I always wanted to do. Link to comment Share on other sites More sharing options...
feerocknok Posted July 11, 2006 Share Posted July 11, 2006 DirtyComanche said: Oh, and I trimmed the front fenders on my XJ there was some rub with the 31s. Then I relocated the flares higher, like the MJ. Then I decided to bedliner the lower quarters on it, but didn't quite get around to it. I've also decided to put my LAs on it, as my buyer backed out. I think it's scared of me already. laughin that thing isn't gonna last as a daily driver, my gut tells em. Are you mounting the leaves far enough forward that you don't loos any approach angle with a winch (as in the winch tray is the front leave hangers crossmember)? That's what it sounded like. Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 11, 2006 Author Share Posted July 11, 2006 The winch is going under the radiator, behind the stock crossmember. The new crossmember is getting built over the old one, with the 4" part of the angle plating the front, and the 8" part going back towards the engine. I will lose approach; over my old setup at least. But not much, depending how things work out. I will be running stock MJ rear shackles in the front, which aren't very big. However, my wheelbase will be stretched by maybe 2" by this, so that will make up for the loss of approach. Departure angle still owns me. And the XJ has GOT to stay DD. Or, at least work when the MJ doesn't. Or I'll lose my job; which would be annoying as it gets me hella discounts on tools/hardware. Not to mention I'd be broke. Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 13, 2006 Author Share Posted July 13, 2006 Progress is limited because I fubared my arm. However, I did some things, and even took pics (after the sun had set). I purchased a peice of 4x7x.375 angle to make the front crossmember out of. It was as close as I could get. Then I welded some nuts into the stock front frame rails so I could bolt the crossmember in place for fitting/welding. Image Not Found I'm going to need to clean a few things up to get it to fit better. And if the steering is going to clear it will be an entirely different matter. This is the winch I intend to put behind it. Image Not Found It's cheap. But it's the same as a ramsey 8000, just under a different name. Not much space back there. Even with no fans in, and the steering and belts all gone, I could not get the winch in through the top. Image Not Found This means that to remove the winch I would have to either pull the crossmember, or pull the engine! Obviously, it's starting to look like I should make this crossmember bolt in, if I can. Unfortunatly, the nuts I have already welded in are not ment to be structeral. This also got me thinking that I probably could have used a better design than just a peice of angle, and probably avoided these issues. Live and learn. Link to comment Share on other sites More sharing options...
Pete M Posted July 13, 2006 Share Posted July 13, 2006 If it makes you feel any better, I'd have to cut out my suspension crossmember in order to drop the trans on my 88. :D Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 13, 2006 Author Share Posted July 13, 2006 I was thinking I'd have that problem too, but I figured out a way around it; for now. But, this winch is cheap, and I anticipate blowing it up. Link to comment Share on other sites More sharing options...
jage Posted July 13, 2006 Share Posted July 13, 2006 it sounded from your post that you probably have to cut a tab/semi circle for the steering box to fit... What about making a semi circle "bite" out of the passenger side that gives you enough clearence to push the winch up an through and slide it over. Or to remove slide it back and pull through the half hole. If it takes too much out of the angle iron you might be able to come up with reinforcement... I guess it just depends on how much clearence you need/have on the pass side. Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 13, 2006 Author Share Posted July 13, 2006 I'm going to put my spare steering box in today and see how things fit. Then we'll go from there. Link to comment Share on other sites More sharing options...
87manche Posted July 13, 2006 Share Posted July 13, 2006 Along the lines of an access hole, why not make the hole to slide the winch into plaace, then make a second plate to bolt onto the bottom. Enough bolts and it should be strong enough. When in doubt choose excess. Link to comment Share on other sites More sharing options...
pingpong Posted July 13, 2006 Share Posted July 13, 2006 How about you reinforces the radiator support with a 1/4 plate behind it, and turn your angle iron around, and build your mounts like Rigid Co does for hhis front bumpers, and mount your winch on the front side with te winch bolted to the back side of your bumper, and recess the fairlead into the front, to help with the approach angle. I hope I explained this well, cause this is what I am going to do to Pong or Casper here soon Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 16, 2006 Author Share Posted July 16, 2006 This is gonna work, I just need to get stronger. Or pull the rad. The crossmember with the winch bolted to it weighs god knows what... I'm NOT benchpressing it in place. I'll have to come up with some crazy redneck system to lift it up for me. Or install studs into the alignment nuts. But, I got the steering to clear. Just took a little notching. Link to comment Share on other sites More sharing options...
DirtyComanche Posted July 19, 2006 Author Share Posted July 19, 2006 It fits. Steering, winch, rad fans... But, I've decided to do things a little differently. I think I will make the winch tray portion removeable, and weld the rest of the crap in. This should be easiest in the long run, and I don't mind buying MORE steel! Oh, and, in case you don't know; using 6011 stick for cutting out bolts doesn't work too well. It just seems to weld the whole mess together. Serves me right for being lazy... Link to comment Share on other sites More sharing options...
