Everything posted by Bounty Hunter
2.5L and an inertia ring
Bounty Hunter replied to mjeff87's topic in MJ Tech: Modification and Repairs
You'll see a benefit in all trail riding, doesn't only benefit in the rocks. I've also heard nothing but good, and have considered getting one. You'll have to do some grinding on the back of the block but it doesn't look to be too bad. -
D35 VS. 8.25 (27 spline)
Bounty Hunter replied to BIGHEEP's topic in MJ Tech: Modification and Repairs
On a side note, i think I'm going to reuse the 8.25 lower shock mount, welding it on parallel to the axleshafts instead of perpindicular like the XJ setup. -
www.mountainoffroad.com . They're available a lot of places. I just cut the perches off the 8.25 and welded them back on. Cut the welds with an angle grinder and cutoff wheel, then smack them with a hammer and they come off pretty clean. I just got done installing an 8.25 SOA in the rear of my MJ, used the 8.25 because it was lying around and the right gear ratio. It should hold up for what you want to do. I also used the 5.5" RE coils up front and I'm real happy with the finished height. The pic is on 32" TSL Radials. -
Looking for opinions on these mirrors
Bounty Hunter replied to Pete M's topic in MJ Tech: Modification and Repairs
I've seen YJ/TJ mirrors on an XJ, looked better than those Fugly mirrors. -
Should I risk it? (Spacers)
Bounty Hunter replied to DirtyComanche's topic in MJ Tech: Modification and Repairs
You should be fine, it adds the same amount of stress as using wheels with 1.5" less backspacing. -
Welcome. Where's the pics? :lol:
Most common in 4bangers are 3.73 (auto tranny) and 4.11 (manual tranny). Your 3.55 is the first I've heard of, and there are reports of rare 4.56 available as well. Like anything else Jeep, just when you think there is a steadfast rule, it isn't.
Clearanced for breakover angle as well. Anybody check out the Clayton LA kit? Seems popular in the rags and over at Naxja.
I've used TireRack before and always came out ahead despite shipping cost. It's always been worth it for me.
Swapped in an 8.8 w/ discs, now brakes suck
Bounty Hunter replied to 88emjay's topic in MJ Tech: Modification and Repairs
What you describe is not a common problem with 8.8 swaps into jeeps, I'd recommend installing that new master cylinder you have and see if that doesn't fix it. If you want to upgrade, consider a corvette or E350 master cylinder. Not sure what years make the best donors, but they're both pretty common swaps. -
New member here, two questions:
Bounty Hunter replied to thomasona's topic in MJ Tech: Modification and Repairs
You can easily change the broken stud yourself. Remove the brake drum and beat the broken stud out with a hammer and punch. Insert the new stud from the back side of the wheel flange and pull it through with the lug nut and washers. $100 :roll: :lol: -
It could be that your master cylinder doesn't push enough volume for the larger capacity of the rear calipers. Just a hunch. -
It's call death wobble (DW) and it's very common with coil spring front suspensions. There are many contributing factors and possible causes. Biggest cause I've seen is a worn out front track bar, and worn out OEM control arm bushings. DW is generally brought on by hitting a bump, sometimes while in a curve. Usually takes slowing to a near stop to get it to end. Yours was probably agravated by trailer tongue weight making the front end a little light.
Anybody know anything about this pic? I think I might know who that was, and where.
Did you plug one of the rear ports out of the MJ proportioning valve? How did you bypass the valve over the rear axle? Having rear disc, I've heard it's benefecial to remove the check ball coming out of the master cylinder. There's a check ball for drum brakes, it's not needed for discs. I've heard you remove the rear line from the master cylinder, pull the metal seat with a self-tapping metal screw, remove the check ball, and reinstall the seat. -
Here's an update on mine after the lift, looks like the RE 5.5" springs compliment the SOA rear very well. Still far from done, but it drove out of the garage ;) Tires are 32"x10.5" TSL Radials. They run pretty true to advertised height, pretty close to my worn 33"x12.5" TSL Radials on my YJ.
Got a better deal than I'd planned on
Bounty Hunter replied to HatchetMJ's topic in MJ Tech: Modification and Repairs
You've got a full plate for the next 3 weeks :shock: -
Got my 4.56 D30 on Saturday :):):):)
Score. What about the rear axle? What year/model/drivetrain was the donor vehicle? Thanks. -
You should have a dealership look into that problem :wink: And maybe they can tell you why only one rear wheel is spinning :P
Front waggy 44 is done.
Bounty Hunter replied to jeepmj_tj's topic in MJ Tech: Modification and Repairs
Isuzu D44 rear also matches the Waggy D44 front 6-lug pattern, WITH disc brakes :D -
The jeep will tend to push the tow vehicle around slightly anytime the jeep has larger tires than the tow vehicle. It can be minimized by making sure the toe-in on the jeep is correct, and the towbar is as level as possible. I've never had a problem with crosswinds, or any other problems while flat-towing.
Sweet, I flat-tow my YJ the same way. On the subject of tow-rigs, ours is an '05 TrailBlazer EXT with the 5.3L v8 and DOD. 20.5mpg on a recent trip, of course we weren't towing the jeep ;) It's rated at 22mpg, so it's got some more breaking in to do.
Disposing of a vehicle...
Any junkyard with a roll-back (flatbed) should be able to haul it away for you. I've got an XJ sitting on the tub that I'll eventually have to haul away for scrap, it'll be interesting to say the least when we winch it up onto a trailer. We'll then fill it full of D30 and D35 housings and other junk parts and hopefully get a decent dime at the scrapyard. -
Are there any parts catalogs that cater to MJ's? Similar to Quadratec or 4WD Hardware? What about online?
