Everything posted by JeepcoMJ
Project Utility Comanche. The Saga Continues
JeepcoMJ replied to JeepcoMJ's topic in Member Projects: Your Comanches
.I had one HEIL of a haul today... $300 takes anything I want....here's the list... complete harness, front to rear. ECU TCU heater box all 5 doors (ALL MINT!..well...maybe a small dent one the pass. front door, but nothing too bad...) both fenders hood valence/cowl front clip rear factory tint side windows complete dash (charcoal) charcoal kick-panel pieces keyless wiring all engine sensors and electronics '99+ intake manifold floor shifter front carpet front seats rear seat rear carpet e-fan 1,000 mile reman np242 (sealed output) with shifter @$$'y NEW radiator NEW plugs NEW alternator NEW power steering pump front and rear driveshafts factory CD player (works good) all that for $300. I didn't have room in the truck for the rear doors, rear hatch, rear glass, rear carpet, all seats, and the np242. going back monday to grab them (and I know he won't screw me on them). pics... -
that sucks man...I had one HEIL of a haul today... $300 takes anything I want....here's the list... complete harness, front to rear. ECU TCU heater box all 5 doors (ALL MINT!..well...maybe a small dent one the pass. front door, but nothing too bad...) both fenders hood valence/cowl front clip rear factory tint side windows complete dash (charcoal) charcoal kick-panel pieces keyless wiring all engine sensors and electronics '99+ intake manifold floor shifter front carpet front seats rear seat rear carpet e-fan 1,000 mile reman np242 (sealed output) with shifter @$$'y NEW radiator NEW plugs NEW alternator NEW power steering pump front and rear driveshafts factory CD player (works good) all that for $300. I didn't have room in the truck for the rear doors, rear hatch, rear glass, rear carpet, all seats, and the np242. going back monday to grab them (and I know he won't screw me on them). pics...
360 Fuel Injection Build
JeepcoMJ replied to 360MJDude's topic in MJ Hardcore Tech: Epic Journeys to Greatness
try picking up the current CPS and cam sensor? I mean...what's the worst that could happen? you could just make a jumper harness for each to accomplish this... -
project 1988 Pioneer My first project
JeepcoMJ replied to The BOMB's topic in Member Projects: Your Comanches
Why not? their mounting system is pretty week, and the control arms don't look too beefy. -
that makes sense. but why on God's green earth are you running a Rock Crawler control arm/longarm setup? -
I used tru-blu plumbers dope. just don't get it on the holes.
couple things for you... the LCA mounts aren't that thick. weld plate from your old shock mount/coil bucket area to the LCA mount. next thing....you probably don't realize this, but the holes are already there to just move the crossmember to the proper location. modifying it was completely unnecessary. -
project Old Rusty (new panel welded in)
JeepcoMJ replied to MancheKid86's topic in Member Projects: Your Comanches
that's a basic 4wd leaf pack, NOT a metric ton pack. two dead give-aways... 1st, it's a shortbed. they could have HD axles, but not MT springs from factory. 2nd is that the pictures show only 3 leafs plus an overload, which is normal. -
the new one actually bolts on and has a plug in it that looks like the plug for an injector. IIRC, it's white. it is a direct replacement part, and works great!
it's the knock sensor. without it, the engine will run like crap.
is your clutch master cylilnder leaking? look up above the clutch pedal and let us know.
I don't even know if you need both signals to make it work... oh, you should splice the CEL wire from the zj wiring to the xj dash harness. -
custom gauge pod is gonna cost well over $100. one single decent gauge goes for 80 or more. it's only $50 for that part. not too bad. -
go to http://myplace.frontier.com/~vze7erz1/id1.html and drop $40 for an inverter. ta-da, done. I used them for the VATS bypass for my '96 camaro motor to make it run. -
sorry to hear that. good luck! keep us updated
perhaps. maybe it won't work if there's no cps and cam sensor signal? idk. -
yep, it's possible. unless the owner specified what he wanted in gears (which is unlikely), it has 3.07's.
the tach should operate through the ECU, too....do you have a pin out for the ECU? -
huh. well that's good to know...I was thinking of doing the same thing on my '86 with the buick 3800 that's in it... -
huh. does it throw a check engine light on the gauge? -
what did you end up doing for gauges? if you used the stock ones, how did you get them to work? -
I'm at 27 and counting. but here's the most I had at 1 time and actually took pics....I think max at 1 time so far was 9 that's the 3800 (my '86), my lifted '89 (RIP), my beater '86 (RIP), the parts '89 (RIP), my dad's diesel (blue one), and my brother's '88 (still driving)
I have both, but AllData is my friend.
may have been coolant run through it. that could be not a problem at all, considering the shut-down and accident situation, but at the same time, it's not worth the risk of installing it and either having it not work at all, or only last a few thousand miles.
