randomguy310
Everything posted by randomguy310
  1. I would change the cps had mine give me all sorts of trouble on my 00 xj then bought a cheap ebay one ran but like crap.. bought one from auto zone been running fine
  2. same used in the trucks also, I have a 4x4 yota trans on the ground at the house with t case and there very similar
  3. I am going to guess that the t5 used in 84 85 is stronger then the ax5, the ax5 is not a very strong gearbox . but funny cuz its pretty much like the yota trans..
  4. wouldn't mind seeing the front suspension set up.. look like a ford bronco or f 150 from the 70's
  5. if it runs hot might want to put the fan shroud on
  6. that is a t5.. is that for a 4x4 or 4x2
  7. the trans could have been replaced at some point, I had a 86 4cyl.. and put two trans in it and one time I got one from the junkyard and they gave me a 4 spd but noticed it before I left with it and got the right one
  8. I might be wrong but it should of gotten better going to 3.55 from 3.07 gear that a lower ratio.
  9. they should just be a Saginaw box.. gm style.. they say that IROC Camaro boxes have a faster ratio
  10. the fenders interchange change but I think the hood is different and so is header panel
  11. just curious why is the bump stop so long, I love your truck and your work you have done, I just curious.
  12. not sure 85 is right.. but I could be wrong 86 was my understanding of 1st yr comanche
  13. curious how you put the 4.0L to the 2.5 trans
  14. I had a 86 Comanche in 94 and drove it back from ky to cali LA and got 30 mpg was a 5 spd with 4.10 gears bed was loaded with stuff with a tarp over it I had the 22 gal tank and got 600 miles to a fill up. when I got home around town 15mpg was about the best it got..
  15. hey I have a 00 intake if your interested
  16. hey if your replacing the end caps at any point I maybe interested have a classic the same color and need color matched end caps
  17. I am in nky near Madison ind
  18. how came you can see down there between the bed and cab.. when it should be part of the cab.. when you look inside it looks like it is flat not a place to have the bed gap
  19. also 86 had the ax4/5 trans not sure when they used the t4 t5
  20. that is glen Helen from the late 80s iam sure.. and its a 7 stock class truck,
  21. might be a chevy luv step side bed
  22. try the coil , I doubt its both fuel and spark
  23. ok, thanks
  24. what do you do about the coil pack bolting on?
