DirtyComanche
    11
  1. Guiness? Hmm, sounds fair. :cheers:
  2. Booooooooya! Thanks.
  3. They're not centred stock, if you narrow them they will be. Unless they cut more off the narrow side. These would be 404s, that is? Of, if you're swapping in portals, you might as well link the front and rear.
  4. Yeah, if you could get it a little clearer it'd be sweet. Thanks.
  5. If you want to try: (This order, I guess... Same size as it is now) Image Not Found Image Not Found Image Not Found Image Not Found
  6. Yes, the crossmember must go back to the rear mounting location. Snag the mount when you get the tranny...
  7. They'll fit, just you'll need to use a wheel with a low BS (3.5" or less) if you want to be able to turn.
  8. No, no. Just picture it in your mind. It's exactly like if it had the 89 fenders on it, minus the weight reduction holes. Okay, fine, sometime maybe I'll change my avatar. How about I piss you all off and change it to a pic of my (stock) XJ?
  9. Get a 4wd tranny (AX-15) with a NP231 or NP242 already bolted to it. It's next to impossible to convert a 2wd tranny to 4wd. The bellhousing is the same. Output shaft is different, but you're going to get a 4wd one with a tcase bolted to it already, so it won't matter. The pilot bearing is weird; don't remember which one it is you're supposed to use. Then you've just got to get your D/S cut down to the right length after you've got the tranny/tcase in.
  10. No, there's that change, then there's another... At least there was with mine. They mount differently. The 89 style was a hell of a lot easier to remove, as the 86 required taking the bolts out from inside the fender.
  11. I think you're going to have to go junkyard hunting for that.
  12. The fenders/header panel actually aren't the same. But can easily be modified to work. I've got 86 fenders on my 89.
  13. Depends what year chyrsler axle it has. Early ones were weak like the D35.
  14. Or 4-link it and coils. Like, it's already broken, so why not make it better?
  15. I had zero(ish) wrap with a SOA with stock packs plus an extra main leaf. That was without spring clamps too. Oh, and a 4.0. Blocks will quickly cause wrap issues though.
  16. The stock ZJ coils should give me about an inch of lift. It's hard to say. The V8/I6 ones are different, and I honestly don't remember which these are. Pat, looks like a deal. I'd just part it out though; I'm not into riding somebody else's girl.
  17. Shipping would be a LOT. So, no thanks. I've got stock 'manche coils, and ZJ coils sitting in my garage. Along with god knows what else. Almost everything on the to-do list I have lying around.
  18. I doubt these coils are stock, as at ride height the variable part of them is fully compressed. And the front is a hell of a lot lower than the back. The back isn't stock though, so who knows. I could ask the XJ yuppies at jeepforum or naxja, but I couldn't care less. I've got ZJ coils, so they'll go it.
  19. Yeah, I'll be using stock isolators as my poor-boy spacers.
  20. Just set it as always logged in...
  21. Finially, some somewhat reliable transportation. Maybe. The idea is I don't wheel this one (thus the name "DD") and actually don't @#$% with it. Reality is that won't happen. Image Not Found Anyways, 1989, 4.0, AW4, NP242, A/C, and blah blah blah... Factory tow hooks and a rear hitch to drag me out. D35 rear! And coils spirngs out of a car of some sort in the front? They're variable rate. Definatly not stock. The rear leafs seem to have been rebuilt/rearched. It has quite the rake when it's on level ground. Plans: (when I actually have time) -Clean the @#$%ing interior. -ZJ coils up front, and a couple isolators to make it level. -Trim, kill the running boards. -Try to find some 31 A/Ts or such. -Swing out tire carrier, or roof rack carrier. -Roof rack -If the rear explodes, put my disk brake 8.8 in and regear the front. Perhaps add truetrac to the front. Oh, and fix the @#$%ing Comanche so I can do real wheeling.
  22. DirtyComanche
    yo ho ho!
    I didn't notice the stack... Cab lights are alright if ya ask me.
  23. If you're willing to get 'heavy' with it you could strip it in a day. That's just taking a torch and blowing away everything that gets in your way. But the wiring will have to be removed without damaging it. And personally I'd save the doors, hatch, fenders, hood, header, seats, interior, steering box, driveshafts, etc etc. Even if it's not usable to me, I can sell it. But that means no taking a torch and jsut going crazy. Personally I'd leave myself a couple weeks at LEAST. And I'd not take the HoHo wiring, I'd just throw the renix intake etc on the HoHo block and run the renix system. Although, I'm not sure what your plans are. And you might need the wiring for the tranny and blah blah... I hate wiring.
  24. Just promise them it's only for a little while. Then rip the axles off so it can't move. Then plead so you don't get kicked out. Worked for me.
  25. $50? Do it, mini storage it if you can't put it somewhere for a while. I wouldn't run 36s on that drivetran, but you could sell them and get more than that back.
