Everything posted by danbyrambler
Sorry - Wish I didn't know how you're feeling - Have enough JD to sleep well tonight
IAD? WOOD EYE!
NEVER HAD A BETTER SHOOTING 22 - GUSSIED UP REM 581
A MANLY PROPELLANT
A MANLY HANDGUN IN 40 S&W
Battery Drain & Ecu Aggrevation
danbyrambler replied to danbyrambler's topic in MJ Tech: Modification and Repairs
Hornbrod: Understood - Sometime after reprogrm my radio a few I discovered my red top had the screw in type connections as well as top posts . . . So put in a neg post adapter 4 fast/convien & was happy until the gadget came along & I'm a sucker 4 gadgets of all sorts 88mj: I think it'll work ok with IS in acc position - Worked when swapping bat in wifes Chrysler TC & am aware of 21yr dif of the 2 - - Anyway, JIC, all thats at risk is a return trip 2 Wal Mart - return the dead 9v as well - lol :thumbsup: -
Introducing Myself (And A Question)
danbyrambler replied to Husafan's topic in MJ Tech: Modification and Repairs
Nice truck - I think you got the better part of the transaction - The commentators for Mecum & barrett Jackson say over & over that turn keys are the best deal - - Can't go wrong buying quality at a decent price esp 4 those of us who can't r dislike the wrenching/resto thing - - - - Anyway, enuff stating the obvious - - NiceTruck! - - - PM me if you ever lose your mind & wanna sell. :thumbsup: -
Tried their new Delux Burger? - - - - Extra grease! :banana:
Handy Dandy gadget/tool - - - Fixed some minor elec probs & no idea about 91 up ECU memory loss - - low idle & return to correct caused some head scratching & needless testing more than a few - - - Stumbled across this from HORNBROD :bowdown: On the 91-95 OBDI MJ/XJ HOs (and perhaps the OBDII system also, not sure) disconnecting the neg cable causes what I consider an issue. At rest, no IGN ON, residual memory current (microamps) is constantly fed to the OBDI ECU to retain it's open/closed loop memory. Disconnecting the neg cable causes the ECU to lose it's memory instantly. For the ECU to completely "re-learn" it's residual settings, it needs to be driven about 100 miles or so, especially on a modified engine. It's a minor PITA as the idle is always lower during the process, and sometimes causes stalling when in stop and go traffic. Preventing this loss of ECU memory is easy by hooking up a common 9VDC battery with alligator clip leads attached across the neg battery post and cable (observing correct polarity) before disconnecting the battery neg cable. A healthy 9V battery will retain the ECU's memory for days since the draw is so small while you are working an electrical problem on your rig & Then Found this - - - Wal Mart's got 'em - - - Google it & many other vendors - - Approx $10-12 http://www.walmart.c...Keeper/15523521 Hangs on shops pegboard now, right next to my favorite screwdriver :thumbsup:
Used to be into it - No so much anymore - Mostly just a day spent with an oil cloth every 6 mo or so - Anyway . . . Favorite handguns S&W 617 66 & 629 All 4" WO RR TS TH TT - - AMT LIGHTNING 6" tapered - - - Seldom shoot the Smiths - - The AMT is my plinker Favorite rifles Browning T-Bolt T2 - - - Remington 541T - - - Mostly for showing off - - - T2 is stock - - 541 has a Leupold 6X For squirrels - Browning Auto22 22 short only - - Plinker - AMT 25/22 fullstock with stainless Burris scope/rings For deer - Winchester 70XTR 6.5X55 Leupold 3X9 Favorite Shotguns Remington 1100 BDL .410 - - Another mostly show off For rabbit/squirrel - - Browning BPS 20Ga 24" with tubes Winchester 97 12Ga - Takedown - Mfg 1931 - bought used by my dad in '34 - Only gun he ever owned Hall closet - Marlin 1894C 357 with Williams foolproof - Used mostly for groundhog control & copperheads with a shot shell but has dispatched 3 armadillos in past 18 mo - can't believe they've made it this far north
c'mon - All these how many angels can dance on the head of a pin sexual senarios are bogus - DH is right - It's a bad idea - Mainly because of the distraction caused - I, like most, have always behaved, but the attraction-distraction is ever present - always has been-always gonna be - From the garden of Eden til sometime later this month around th 21st - That and you gotta be half off to get on one of those things anyhow - Ditto for those that jump from airplanes - They just don't need any more distraction than what's already clouding their better judgement. 'tis a bad idea. This day and age we're living in Gives cause for apprehension With speed and new invention And things like fourth dimension. Yet we get a trifle weary With Mr. Einstein's theory. So we must get down to earth at times Relax relieve the tension And no matter what the progress Or what may yet be proved The simple facts of life are such They cannot be removed. You must remember this A kiss is just a kiss, a sigh is just a sigh. The fundamental things apply As time goes by. . . . . it's still the same old story A fight for love and glory A case of do or die. The world will always welcome lovers As time goes by. :thumbsup:
Death Wobble Affected By Rake?
danbyrambler replied to MichiganDuck's topic in MJ Tech: Modification and Repairs
If you don't think rake could effect the toe, go measure your toe then put 1k of weight in the @$$ and re measure. The front will lift some due to the weight. Secondly if the rear of the truck goes down the lower arm goes forward around the pivot of the wheel. This changes the caster slightly, which in turn will also change your toe. An alignment of both caster and toe should be performed or checked after every alteration to front or rear suspension. I learned the hard way to be sure to do the alignment with driving load. So if you plan to have a canopy the alignment needs to be done with the canopy on. and redone if you remove the canopy and plan to drive for any length of time. If for nothing other to ensure best mileage on your tires. You can check toe at home w/ a 2x4 and a tape measure and check caster with a $9 angle gauge. Only said didn't see how lifting the bed would effect caster - still having trouble with that in real world apps - bed goes up - center gravity goes forward, but it's gotta be stupid/unreal before the front springs compress to a meaningful amount - - - - - - Home alignment methods have been beacouped this site & others - - What worked for me, working alone, was using an old school folding carpenters rule-quality type with slide out tip-way more rigid than a tape-also used TM & 2 straight edges fastened to tires with identical rubber straps - Best for me was with a helper & SEs - no need for straps-no crawling around measuring - - Also, since every system's gotta have an operating range 200lb was put in DS seat/floor pan when toe was ck'd & then 'nother 200lb in PS & recheck & again after little over 100 miles wi just me adding to gvw - Did it - MJs dialed in-no dw-smooth zero to 85+ - Ready for Bonneville :thumbsup: -
Jack And Lug Wrench Stowing
danbyrambler replied to Biotex's topic in MJ Tech: Modification and Repairs
This would/should also check exhaust system strength at same time - - lol http://www.ebay.com/itm/Titan-Exhaust-Air-Jack-Vehicle-Lift-New-TTC-2-0-/350665806891?pt=Motors_Automotive_Tools&hash=item51a54f942b&vxp=mtr :D -
Dollphins No Typo
Wife & daughter have Kindles - Daughter has a new Fire - Not sure what model the mrs uses/peruses? - Anyway, they love 'em & I've got the amazon.com bills to prove it - - Daughter's in her (Thank You Lord) FINAL semester & then a one yr internship - She also does the text book thing - - - - - - - -Rewards Cards - - The credit card wars are still going - A little diminished but still there - - - Basically most cash back card offers require $500 in purchases during the 1st 3 months you have their card & then the cash bonus is paid - We put everything on our cards except taxes, DMV & electric bill - Doesn't take a month for us to satisfy the minimum use & then that card is no longer used unless there's a 5% special going on - When the 3 mo is up we get the CB bonus then cancel the card & apply for another if we haven't already done so - We also alternate account names - mine, then hers, then mine again & so on - Satisfies the new account thing - This isn't a scam - We're just responding to their offers - - - This year we've received $850 in CBBs, last yr $1150 & $1050 in 2010 IIRC - - 6 new cards are the most we've applied for in a yr & they are/were scattered among BOA, CITI, CAPITAL, CHASE & AMEX - Just whoever's offering the most - - - in 2010 & 11 most CBB offers were $150 with some $200s & one $350 from AMEX - - - - I know this isn't for everyone - - Gotta have good rating & I've heard you can be dinged every time you close an account - A ding that supposedly falls off the next quarter - Dunno - I get our banks free yearly run downs on us & have not seen any evidence of this - - - Anyway it's a little tax free money - considered a rebate - Here's a link that's handy for keeping up with the latest offers JIC you're not getting enough of 'em in the mail. http://www.creditcards.com/cash-back.php :thumbsup:
Hmmm. . . . . Think it helped me - - - Am gonna fresh my 89s rear springs shortly & anticipate 2 inch or so higher in back - - - If my Jethro Bodine style math is correct a 113 inch increase in lift would amount to 45* increase in rake/caster on my 113 wheelbase so a 2 inch increase distills to zero point 81degrees of rake/caster - - - This almost one degree of change may put me back in DW trouble but at least now I'll be ready - - - - My LCAs length is good & I added adjustable uppers - - so much for that - - Don't see how lifting the rear will change toe, but checking/changing it is no biggie - - - we'll see. :thumbsup: -
JOINED YEARS AGO - SHORTLY AFTER THE BOY SCOUTS GAVE IT UP
