Everything posted by Eagle_SX4
NP229 rebuild or any T-case really.
Eagle_SX4 replied to eaglescout526's topic in MJ Tech: Modification and Repairs
If I remember correctly that is the detent ball to prevent you from putting the transfer case into 2-low. With some modifications you can remove it to get 2-low. When I rebuilt mine I had a factory rebuild guide. I will look for it when I get home tonight. -
ax15/np231 rebuild questions
Eagle_SX4 replied to watchamakalit's topic in MJ Tech: Modification and Repairs
When you get into the AX15 double check the shift forks. I bought a spare AX15 to rebuild so my truck wouldn't be down for more than a day. The previous owner said that it liked to pop out of first gear. There was a lot of slop in the shift forks. I replaced all of them. It hasn't popped out of gear since I finished rebuilding and swapped it in to my truck. -
I finally got the rear brakes fixed on my truck. After putting new drums, shoes, wheel cylinders and new hardware on the back. The brakes were constantly dragging and with my temp gun they reached 400 degrees F. Which then hardened my drums they turned blue and gold. The problem I found out after much trial and error was the brake shoes. The friction material was put on in the wrong spot on the shoes. Causing the wheel cylinders to over extend and not return when the brake pedal was released.
I can verify that the Eagle's vacuum shift mechanism is the same as the jeep one. When I swapped a 229 into my eagle everything bolted right up and works great.
Has anyone seen these plastic seat belt holders?
Eagle_SX4 replied to robfg67's topic in MJ Tech: Modification and Repairs
I can see what you are talking about in the photo. I haven't actually seen any bench seat ones in person. Didn't know there was much difference. I just thought the bench seat ones might be longer. -
I pulled some out of a Cherokee in the junkyard. The ones in the Cherokees are for bucket seats but should be close enough for what you want. -
Gremlins have invaded my Lt. rear turn signal
Eagle_SX4 replied to olddude's topic in MJ Tech: Modification and Repairs
I have actually had the wires break off at the brake pedal switch twice now. Double check for broken wires on the brake pedal switch. -
1988 jeep comanche pioneer olympic edition
Eagle_SX4 replied to Luis's topic in Member Projects: Your Comanches
Thought it would be possible to rebuild the engine without pulling the block but haven't seen it done before. Good job at getting it back on the road -
Have you checked the condition of the bulb sockets? Any visible corrosion? When I got my truck the front turn signal sockets were corroded and didn't work correctly. Maybe the sockets are to blame? I cut the old ones off and soldered in some "new" ones from the junkyard and everything is working great now. -
Yeah I had some left over after I rebuilt an automatic transmission and I figured since they use auto trans fluid it would be just fine.
The same thing happened to me when I rebuilt the NP229 I put in my Eagle. I had some sticky transmission assembly grease I used to put all those roller bearings back in place.
Brake height sensing vlave
Eagle_SX4 replied to Eagle_SX4's topic in MJ Tech: Modification and Repairs
Thanks got the how to written up and edited the links. Here it is. -
I could not find an answer any where on what the correct rod length was for the height sensing valve. So I was lucky enough to find an alignment tool on eBay(part number KENT MOORE TOOL J-35853-2). Here is how to properly set up your brake valve to the correct position with an empty bed. Without using the alignment tool. See this thread on making a new rod. I used a metal ruler from a combination square and a digital angle finder. I removed the rod and put the alignment tool in place. I also set my angle finder to 0. Hanging off the side of the mounting bracket for the valve. Next I adjusted the rod length for the correct position of the valve. I removed the alignment tool and measured the angle of the flat were the alignment tool indexes on the cam. As you can see the angle is just about 45 (44.5) degrees. Which is the proper angle for Cam to be in. The bushing and arm get pressed on the valve together and are not timed to the cam itself so the angle of the arm can't be trusted which is why my arm is pointing up and not parallel with the axle like many have suggested. In this last photo you can see the flat used the align the cam. That is where you need to place the straight edge to find the angle of the cam. In this thread you can see the inside of the valve and see the cam I am referring to.
I got the alignment tool in the mail and am working on a write up show how to align the arm properly without the tool. Just wondering how to link other threads in to my post with out using the url? -
Skid plate year comparability
Eagle_SX4 replied to Anthi4078's topic in MJ Tech: Modification and Repairs
Yeah it should also help keep your alternator dryer. I think it might help pull some hot air out the bottom(when you are going fast enough). -
It looks like the plastic bushing can be pressed on to the valve at any position which is why the alignment tool is needed. So if you had an alignment tool and new bushing the rod length wouldn't matter as long as you install the rod to the axle at ride height and use the arm as alignment point for the bushing. I am going to order an alignment tool and see if mine is adjusted properly. -
Thanks Ωhm . It looks like someone may have removed the arm on my valve at one point because there is no spring on mine. I am going to look at it closer when I get a chance tonight. -
Okay it looks like the arm is attached to a cam that pushes a spring to vary the amount of fluid allowed to the wheel cylinders. What is the relation between the cam and the arm? How are they timed together? I think I read somewhere in the FSM about a tool to check the position of the arm does any one know anything about that? -
Yes that is the thread I used to make a new rod. I am just interested in how an empty bed affects the brakes vs a fully loaded bed. Is there more braking pressure with the bed empty or full? -
Finally got a track bar cross brace made still need to pick up one more bolt at the hardware store but so far it does seem to have helped a little bit with stability. (Sorry about the last picture it is upside down. Even when I rotated it and uploaded again it always comes out this way)
I have been trying to figure out the right length for the rod that connects the valve to the axle. Does anybody know what actually happens with the valve when the bed is empty vs loaded. My thoughts was that when loaded it would increase the brake s on the back and decrease them with it empty. That doesn't seem to be the case with my truck it seems to act the opposite way. The longer the rod (simulating a heavy load) makes my brakes work less in the back and a shorter rod (simulating an empty bed) makes the brakes work harder and lock up before the fronts. Any info on how it is supposed to function would be great.
