Luis
Luis's Achievements
  1. Thought it would be possible to rebuild the engine without pulling the block but haven't seen it done before. Good job at getting it back on the road Yes , you just need a Lift
  2. Yes but slowly , no Just I nee to re-paint , fix the front bumper position. And I will custom make a Rack roll bar.
  3. The Heater Core has leak , I replaced it. Fixed the top dashboard. Intalled Water temperature Gauge.
  4. first clean new tires Preparing ti paint Finished and don't like .... I will re-paint using Raptor Paint - drark gray
  5. This is my Comanche Pioneer 1988,4.0L V6 , Olympic Edition. I got from a junkyard in Feb 2022. Richmond Virginia. Fixed: New: Gas Tank Gas Pump. Water Pump. Colling Tank. Thermostat Radiator. Cooling Hoses. Water Tank. Fuel regulator Fuel Pressure regulator 2- Transmission Oil Cooler Hose Assembly Throttle Position Sensor Power Steering Pump Piston Ring Timing Chain Rod Bearing Belt Power Steering Pump Pulley Belt Tensioner Pulley Drive Belt Idler Pulley Compatible Heater Blower Heater Core 4 Rough Country shocks Coil Spring Rear Vacuum Harness Front Vacuum Harness Rough Country Daytona Steel Wheel Black Rough Country N3 Steering Stabilizer Steering Track Bar LED Headlights Haedline. Cluster light. Fornt Bumper Rough Country for Jeep Wrangles with aparters . Rear Bumper Rough Country for Jeep Wrangler. Original conditions: TODAY : Oct/23:
  6. Luis
    1JTMG66P3JT159646
    Year, Make, Model. 1988,JEEP , Comanche Pioneer 4.0L V6 Richmond , VA Driving , but more thing to do Notes: This is Olympic edition
