Everything posted by MJCARENA
Front mud flaps (Not Mine)
MJCARENA replied to MJCARENA's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Cool. Looked like a good deal. -
Comanche Dawn
MJCARENA replied to Limeyjeeper's topic in MJ Hardcore Tech: Epic Journeys to Greatness
I am pretty sure there is a Federal law that says you can't eliminate it, if it came from the factory with one. -
Need someone smarter than me
MJCARENA replied to Renoenvy08's topic in MJ Tech: Modification and Repairs
Take the caps off and use plasticguage to check your rod clearances. (Might of spelt it wrong.) -
I think you have.
You did an awesome job on the rims.
Turn truck off and AC won't work when restarts...
MJCARENA replied to EvilMJ's topic in MJ Tech: Modification and Repairs
I also could not find the problem. So I did that work around. Worked so good I never looked for the issue again. -
Do you have any actual readings from the gauges?
I sold a pair of buckets with brackets for $250. They were a little dirty, but would clean up, and the driver side has a couple of small holes on the seat part. Also they were true MJ seats.
Looking good. Love the brass freeze plugs.
Got some NOS goodness in the mail today. The guy had 2 sets of them on eBay. I think TheDude got the other set.
Measure your voltage at the clutch. I had the same problem, AC would turn off at stops and had to rev the engine to kick back on. I only had around 9 volts at idle at the clutch, and when I rev the engine it would go to around 11 volts and the compressor clutch would engage. I could not find where I was dropping the voltage, so I installed a relay between the battery and the compressor clutch with the original clutch wire activating the relay. Never had an issue again. -
How many have seen or own a Jeep Comanche 1985 launch Coin?
MJCARENA replied to Kjdrew35000's topic in The Pub
Pete, here is your coin. -
I've always wondered how many were made.
Upgraded to a Gauge Package W/ Column Shifter
MJCARENA replied to photoguy_43420's topic in MJ Tech: Modification and Repairs
The way I routed it was through the square slot on the cluster and then to the clip "holder" on the column. Is that correct? Yes, I was thinking on the unit itself. -
Is the string broken? Looks funny. -
Emergency Brake release handle
MJCARENA replied to Virginia's topic in MJ Tech: Modification and Repairs
Yes, I still have both handles.
