Everything posted by JZLAJeep
How many of you guys run LT tires?
JZLAJeep replied to robfg67's topic in MJ Tech: Modification and Repairs
Not the tire expert here, but some empirical data. A while back I put LT tires on my stock 95 XJ and the tires lasted for 80K miles. They were sun rotting before they finally wore out. When they finally were getting sketchy for driving in snow I went back to the tire store, told the guy at the desk they ran for 80K and said I wanted another set. He couldn't believe that I had gotten 80K and had to come look for himself. On my second set of those. Lately I've been buying used LT tires on the other two Jeeps (because new tires cost more than the value of the vehicle) and have been having good luck with those. -
"Jared L" (the "J" in JZLA) inspired this article after we saw this in AZ this summer. https://www.theautopian.com/someone-combined-a-ford-excursion-with-a-volkswagen-new-beetle-and-made-this-v10-powered-monster/
Fender liners are amply available on Amazon too. https://www.amazon.com/Titanium-1984-1996-Cherokee-1984-1990-1986-1992/dp/B076C4TJ1J/ref=sr_1_6?keywords=jeep+cherokee+fender+liner&qid=1690261016&sprefix=jeep+cherokee+fender+lin%2Caps%2C188&sr=1-6&vehicle=1995-42-347-141--30-8-8-3330-242-8--19-14-1&vehicleName=1995+Jeep+Cherokee We passed up a decent factory rear bumper because we couldn't track down the end caps.
SporTruck w/Plow - Bantam, CT $2500
JZLAJeep replied to NHMJXJ's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
When I called to insure the Comanche the first time the insurance company asked me if I was planning to use it to plow snow. I thought that an odd and random question, until now... -
Adding supplemental electric fan?
JZLAJeep replied to JZLAJeep's topic in MJ Tech: Modification and Repairs
Yes, we flushed it a few months ago and it's definitely burped. It never overheated before or since driving around town, it just needs a little more help offroading, when we're climbing gnarly grades with not a lot of air coming through the radiator. Although i am impressed that it runs at 150, all three of our jeeps like to run about 190, which makes sense since the stock thermostat is a 190. -
On our last wheeling trip, the Comanche was having overheating issues. Nothing that couldn't be remedied by slowing down and giving it occasional breaks, but definitely annoying. It's an '89 Renix with just a mechanical clutch fan. The '94 and '95 High Output XJs never ever overheat, and they have an electric fan along with the mechanical fan. So I'm looking to add an electric fan to the Comanche. I have an electric fan from a '98 XJ, just need to install and wire it. Does the Renix hardware include any fan wiring like the High Output does, or is my best bet just to add an aftermarket electric fan switch and relay? I'd just hate to wire in a bunch of aftermarket stuff and then find out that the stock ECU supports an electric fan.
91 Pioneer Stripe Decal
JZLAJeep replied to Gary from Texas's topic in MJ Tech: Modification and Repairs
Where in Idaho? I happen to know some people in Idaho (us) that will be traveling to AZ in a month if you happened to want that one to come your way... -
AX-15 & transfer case in Boise, ID
JZLAJeep replied to JZLAJeep's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
Boise Jalopy Jungle on State Street. We may go pull it. Can't let an AX-15 get crushed. We previously retrieved the AX-15 and transfer case that is in our Comanche at the Nampa Jalopy Jungle. -
The J10 followed us home last weekend. Purchase price ended up being $650. Now we have another project...
The bed certainly has some rust issues. Otherwise it doesn't look too bad. Obviously it used to be red.
We are ending up with too many of those. The Comanche, a Cherokee, might as well add in a J10 right?!?
Little more info from my son: "[Owner] said it ran in the last month or two but the carb kept clogging up cuz the tank is rusty. Interior isn't bad. It's a straight 6 4spd 4wd [Owner] said he thought [the fuel tank] was bad enough to replace" So potentially tracking down a replacement tank or repurposing one from elsewhere sounds like it would be the first order of business. Neither sound easy, but not impossible.
The teenage boys of the family came across this J10 and the owner says he will sell it for $1,000. Has the straight 6 engine. Doesn't run, but ran when it was parked. Worth taking the risk?
Nice! They are getting hard to come by
Odds and ends - Advice requested
I can be interested... Contact me. -
CPS Plug inspection. Is this normal?
JZLAJeep replied to NC Tom's topic in MJ Tech: Modification and Repairs
I thought I had a picture, but can't find it. We replaced the CPS in December. I had purchased a cheap one on Amazon, and it worked, but only after some modification. The holes on the CPS didn't line up with the holes in the bell. Fixed that with some cutting and grinding to make slots on each end. Then the pins of the plug on the new CPS were mangled so cut it off and spliced in the old plug. But after that it worked fine... -
That helps a lot. Below is a picture from our Comanche. Looks like the jack attaches to these white hooks using two D rings and an elastic of sorts? Will need to fabricate a bracket for the rod, but I can see where the wing nut threads in. -
It's been a while, but to follow up on a couple of these topics and one follow up question. Purchased the 4 wheels for $100. Found a 5th at a junk yard. Got good tires mounted on the wheels. Haven't installed on MJ yet, might end up on one of our XJs instead. Purchased an installed a dark blue dash mat (Coverking on Amazon) and installed it. Improves the appearance of the interior immensely. Purchased a jack from ebay. Must be from a later model XJ because it's different than the "old" XJ jack we were expecting, but works the same. We don't have any hardware for mounting it in the Comanche. How is it supposed to attach behind the bench? A photo will be helpful if anyone has one handy. Badges - purchased the 3M 2 side adhesive, but haven't cleaned off the badges and vehicle to reattach yet. -
Dome light seems impossible?
Thanks everyone! Got the chance to play with these a little and got them to light up. Need to keep playing with them though. Not sure if the door switches are any good also. But this has helped a lot! -
So today I was trying to figure out why my dome lights won't work, and i ended up running into a wall. So there's three wires going to each light, the pink hot wire and the two black switched grounds. All of these seem to be connected as they should. The issue seems to be inside the actual housing. One side of the bulb is connected to constant hot, and the other side is connected to........ nothing. The bulb has no way of grounding to either ground, and it doesn't look like it ever did. Both side lights are like this. The bulb lights up great if I cross the ground side of the bulb to ground. So am I going crazy? Is it supposed to be like this and I just don't understand how its supposed to work? Getting pictures of the conductors inside the housing would be difficult but i can give it a shot tomorrow if that would be helpful.
Wet carpet - Leaky windshield?
Thanks for the tips. For now we got the carpet dry and threw a tarp over it - which seems to be working for now. Will get out the hose and take a good look and turn a hose on it on a sunny day. -
Disclaimer, this is an issue on my 94 XJ. Saturday was a nice day after a few day of rain and before a few days of forecasted rain so I was vacuuming and doing some upholstery cleaning on some vehicles. Got to the 94 XJ and the carpet in the drivers foot well was wet. I dried it all weekend, checked on it yesterday and it was dry. Went out again today after rain all morning and the carpet was wet again. Back to drying it out again... I had initially wondered if it was the door seal that was leaking. We had a nearly horizontal rain storm last week that would have blown straight at the drivers door. But today's rain was a drizzle straight down so I'm confident I can rule out the door. I've owned this XJ for about a year and a half. The windshield is in perfect condition, likely having been replaced not long before I bought it, but I have no idea who did the work. The carpet may have gotten wet everytime it rained or snowed and I just didn't know it because it was under a rubber floormat. But I know there is a problem now. I've called around to a few windshield places locally. I'm hearing various things from leak tests to trying to reseal it without removing the windshield to removing the windshield (hopefully not breaking it) and reinstalling it, etc. What is the treatment that I should be looking for? And what should it cost?
How did you aquire your Comanche and what is the story behind it?
JZLAJeep replied to Classy Comanche's topic in The Pub
After having looked for one for about six months, we found ours in a field while driving back from a day of Jeeping in our family's two Cherokees. The whole story is here: https://comancheclub.com/topic/69832-89-field-find/#comment-732342
