Everything posted by VorTekX
Thanks, I'll order that pump now
I recently bought the JPSU-6 MTS replacement sending unit as my fuel pump still worked and I thought I could swap it in. However when I finally went to swap it in, it doesn't seem to fit in the rubber mount that came with the kit. I read that I should get a Bosch unit off roackauto but it doesn't seem like they sell one anymore. Is there a specific brand I should buy that is compatible with the MTS unit? This one looks like it should work but I'm not sure: https://www.rockauto.com/en/moreinfo.php?pk=11961517&cc=1181584&pt=6256&jsn=853.
I can't seem to find OEM ones that fit directly from the filler neck to the tank. Is the only solution to buy Cherokee hoses and cut them down to fit?
If you still have these for both sides I'm still in the market
I can't find any results on amazon with that number
No Start after fuel injector install
VorTekX replied to NC Tom's topic in MJ Tech: Modification and Repairs
Yea I would wait till MTS replies to you, you could always put an ad in the wanted section. Maybe someone has a spare. -
https://www.ebay.com/itm/265058216240?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D20200818143230%26meid%3Db4ac0a01505f4eeab5cdfc41023eebee%26pid%3D101224%26rk%3D4%26rkt%3D5%26sd%3D372766136008%26itm%3D265058216240%26pmt%3D0%26noa%3D1%26pg%3D2047675%26algv%3DDefaultOrganicWeb%26brand%3DDelphi&_trksid=p2047675.c101224.m-1 Found this on ebay -
Stock Leaf Spring Leaf Count?
VorTekX replied to Bomberjeep's topic in MJ Tech: Modification and Repairs
I don't think XJ axles changed until 2000 and they should be the same under the MJ....... unless i'm wrong? -
Sound system suggestions
VorTekX replied to WranglingManche's topic in MJ Tech: Modification and Repairs
I have this head unit in mine: https://www.crutchfield.com/S-57twfm4V640/p_500UTE73BT/Alpine-UTE-73BT.html?XVINQ=GZ0&XVVer=144Z&awcr=628539558416&awdv=c&awnw=g&awug=9004171&awkw=pla-434008755498&awmt=&awat=pla You'd need to wire it to fit to the MJ harness. I've used it with the stock speakers and I don't think it sounds half bad so I'd think it'll sound much better with an aftermarket system. Couldn't tell you what aftermarket speakers to go with though. -
4.0 rebuild after engine bay fire?
VorTekX replied to VorTekX's topic in MJ Tech: Modification and Repairs
Update: So I finally got the parts XJ home and block doesn't look like its in great shape. The wiring harness, injectors and pretty much everything else was shot. I couldn't shift the tranny, I think it's because the clutch cable melted- I haven't gotten under to look yet. This was sitting with no hood on it in the tow yard for about a week and a half with about 2 days of poor weather. The intake manifold cracked and it looked like there was some particulates on the dipstick when I pulled it. I'll be purchasing an engine hoist soon to get this out of the jeep. I've never torn down an engine before so this will be a first. -
Could you link the thread? I can't find it. -
How much should I be paying for a non cracked junkyard one
FB marketplace
VorTekX replied to Armyvet25's topic in Craigslist/Marketplace/eBay... i.e. Not Your Stuff
I think those are just stock Cherokee flares -
What parts of it did you need to rebuild? How did you know what parts got damaged? -
Yea I should've been more specific, I didn't mean replace cams valves etc, but more like would the fire have warped the head so that it would need to be machined? Stuff like that. -
Cheap parts XJ near me had an engine bay fire. I don't know the complete severity of it yet and I will be going to look at it soon but in the pictures it seems that the top of the dash melted because the front windshield broke but below the steering column its fine. The front doors are also somehow fine. I needed it for the doors and tranny but curious if a 4.0 in a fire could rebuilt? I'll update with pictures.
If I'm correct, you could swap the bell housing from internal to external?
Is an internal slave 4x4 AX-15 about 500 as well?
And is this just for the transmission? not the transfer case? Locally I mean.
Cab corners needed for both drivers and passenger side
Just curious what you guys think.
Axle nut torque specs for 4x4?
I have an 88 4x4. The bearings bolts I put in I torqued down to 75 ft lbs each. I torqued the axle nut (i think that's what its called?) to 175 ft lbs and placed what looked like a castle-nut shaped retaining cover and cotter pin into their previous positions. It drove around with no issue. Do I need to go back and tighten it further?
