Everything posted by VorTekX
Thanks for the replies. I made a pallet so far but I was curious if anyone knew offhand what the weight of certain dana 30 components were? I'm only shipping the housing, diff, and knuckles. Fluid has been drained.
I do not have a compressor or sprayer at the moment but I would have to buy one from harbor freight. I have a friend who owns a 3 gallon which is no where near enough. I do have a place that I can use as a temp paint booth. I have a respirator and painting coveralls. I have a 5 in orbital sander. All my panels and bed aside from the cab are not attached to my truck right now so I would be doing them piece by piece. I could buy sanding blocks from HF as well. In the event I cannot buy a compressor, I am not opposed to a rattle can job. Obviously this is not going to come out the best but I intend to wheel this thing a bit anyway so I don't want something I'll feel bad about scratching up. I just don't want it to look awful with rust flaking off while I'm driving down the road. Lol. If you have tips on doing it that way I wouldn't mind going that route. It may be cheaper compared to buying the equipment and paint needed for a compressor job. I do intended to POR15 the frame as well but the prep for that is far easier/straightforward than body panels.
That's my plan. It doesn't need to look good, just protect the metal. I'll eventually repaint it better when I'm older with more money and facilities.
Trying to tackle painting my MJ..... never done this before and it seems super overwhelming. I have some panels that have really good paint, clear coat is still intact etc, and other panels that have faded clear coats with rust spots. The worst paint on a panel I have has paint flaking off from the primer, which you can see exposed underneath. I know for rust spots I have to sand down to metal and apply filler but for the paint what grits do I start at? From my understanding, paint that's still in good shape shouldn't need a lot of sanding so I should use a finer grit (600-800?). With the non clear coat/ flaking paint, I should start with a more abrasive grit (320?) and go to a finer one (800?). Is this the right approach?
Will a 96 dana 30 front axle work with an 88 dana 30?
VorTekX replied to VorTekX's topic in MJ Tech: Modification and Repairs
Honestly I think a better question would be would an 88 front ba-10 driveshaft work with a 96 AX-15? -
I should have specified, I meant driveshaft........ no idea why I wrote axle :(. Would be keeping my stock 88 D30 and using the 96 tranny and 96 front driveshaft. If that's possible that is. -
Where did you get the decal made? Might do this with the stock pioneer sticker.
Never done this before. Do I need to build the pallet? What carriers/ methods are the best for shipping? Did some quick reads and found that Amtrak can ship but on their website it says they suspended that service. I don't know of any small freight companies off the top of my head. Not sure if UPS or similar could be more convenient. Buyer is paying full shipping cost but I would like to get it cheaper for him. Any advice relating to this is appreciated.
Thank you
I should have clarified. Those connectors are just similar to the ones that came off of the wire that ran to the starter solenoid, I just did not have a picture. I couldn't find any info about the specific gauge wire for the solenoid connection. I need to solder a new one as the one from my old starter was crimp connected.
Does anyone know what gauge the wire going from the starter solenoid to the wiring harness is? And what type of connector these two female ends are called?
Can stalling my truck lock the starter?
The starter doesn't fit because amazon sent me the completely incorrect part. I ordered it over a month ago and was busy so I didn't open it until now. I don't think I can get my money back. It was supposed to be this: https://www.amazon.com/dp/B007Y86TIS/ref=pe_386300_440135490_TE_simp_item_image -
The hammer trick did not work. Additionally the wire which runs from the positive relay was connected using a crimp connector. Pretty awful. Turns out the replacement unit from amazon does not fit my truck. Are there any starters on rock auto that are good? -
All other electrical systems work -
Stalled my truck and afterwards the starter would just click when turning the key. No crank whatsoever. I had just replaced my battery and verified my alternator was working. I had bypassed the ballast resistor and it had started fine twice before that. I bought a new starter in case this one is just bad, but how could stalling make a starter die? Is it just stuck or completely dead?
South GA junkyard finds.
VorTekX replied to Greenjeans's topic in Craigslist/eBay... i.e. Not Your Stuff
Was the fiberglass on that MJ front clip damaged at all? -
How did you prep the metal for the POR15?
- 52 replies
- 87 chief
- restoration
(and 1 more)
Tagged with:
Looks like the "cruise" tier one upper and lower bundle is 319 on their website. Howhas the handling on the truck improved with them?
Looking for a rollbar that could fit into the MJ bed ideally within the NY metro area. It doesn't need to be MJ specific just similar looking. Not looking to spend a ton on this, so it doesn't need to be in great shape either just not rotting.
It looks like the Mj ones are bent downwards, not inwards. Do you have any issues with rubbing on these? Or do they have enough clearance
I know the WJ arms are a popular upgrade for allowing tires to clear without rubbing, but are there any curved tubular options available? All the old threads I've read have dead links to products that don't exist and I can't seem to find any bent inwards in my searches.
