13
Getting high beams to work again
eaglescout526 replied to hgeranium's topic in MJ Tech: Modification and Repairs
Check the rod on the left side of the column. There’s a rod that goes from the turn signal stalk down to the switch and that can come out of the switch when working on the console. I can’t believe I snapped this pic. But that rust colored rod is what pushes on your switch to engage the high beams -
1986 LWB Comanche sending unit
eaglescout526 replied to LoSwap88's topic in MJ Tech: Modification and Repairs
So the only unique thing to an 86 MJ sending unit is the size of the pump it can accept. Otherwise 86-92 long before fuel tanks are all the same. Now internally there is a baffle that separates the 16 and 23.5 gallon tank. Oh and the sending units is different but not my much. The length of the float arm is different. Somewhere around here I made a post about the fuel tanks and the sending units. Also the 18 and 23.5 gallon sending units are interchangeable between the two tank sizes but are completely different tanks. Hopefully that answers some questions. -
Manifold install
eaglescout526 replied to eaglescout526's topic in MJ Tech: Modification and Repairs
Theyre pretty good actually. I didn’t have an issue with them. I’ve learned that working on the Eagle made me actually use SAE sockets and wrenches vs the metric when I’m working on the Jeeps. From what I remember, new hardware can be had. I know if you get bolts for a Dakota or possibly a wrangler that has the 2.5L, the washers are RTV or siliconed to the bolt which is pretty damn smart. I wish I saved the part number for them. I might have thinking about it. -
Manifold install
Well what I was working on was the 258 4.2L which is carbureted, it was pretty easy to get off and was suspiciously easy to get back on too. If you can get all the bolts out, you can move it far enough back to clear the alignment dowels and remove the gasket and put a new one on if youre looking to do that easily. -
Replacing the radio in the 89 Eliminator
eaglescout526 replied to grey89elim's topic in MJ Tech: Modification and Repairs
Are ya looking for an opinion on the radio or how to put it in? i mean if it works, toss it in for that 80’s/90’s aftermarket goodness and look. Though if I was swapping that in I would look to make an adapter harness so I wouldn’t lose the original wiring. 84-86ish is packard connectors 87-89ish uses metri packs 89-96 uses the Jeep/Eagle/Chrysler connector. -
86 2.8 serpentine belt question
eaglescout526 replied to ratrapp's topic in MJ Tech: Modification and Repairs
Yeahhhh it can be. Well that sucks that you have to do a lot of work to convert it to a serp set up. -
What’s weird is I ran into an issue similar on my XJ where the belt would squeal, loosen it, stopped but became too loose when it was hot. Then I learned I had to get strong and really make the belt tight to not squeal and be an issue. Sometimes you just gotta really crank down on those tensioners. -
Not sure if many on here have done such. I know the 2.5L can be converted by simply changing all the pulleys. Maybe the S10 guys had better luck, if they kept the engine… -
Here we go again! A 1986 Eagle
eaglescout526 replied to eaglescout526's topic in Member Projects: Other Cool Stuff
It’s officially ours!! Let the fun begin! -
Quartz clock stuck at 1:00, not blinking
I’ve been hoarding them. I have a goal to learn how to rebuild them, such just happened yet. -
These clocks are starting to get old. I’d suspect failures internally. Either the Crystal or a capacitor or resistor. -
Hahaha I know. I knew Carter was gonna cause chaos and expect you to chime in. Though I suppose if I wait and build up some money I could just buy those wheels.
Huh. Interesting. You don’t really need the ballast resistor. It was put in place shortly in 88 to quiet down the fuel pump. But you can put it back if you’d like. Though since it’s running, I guess I wouldn’t question it. If you wanted you could always take a VOM and do a continuity test on the wires and see if they go to the fuel pump like I think.
Covers first. Then those wheels haha. Baby steps.
Unable to post in Classifieds, even a Private Message
eaglescout526 replied to JSAM's topic in Forum Issues, Ideas, Testing
i can’t see how many posts you have done but a minimum of 10 and the classifieds will open up. @Pete M, or I will look into why you can’t send messages. -
Looking for a set of these: Condition isn’t a factor. Typically found on AMC and Jeeps from the 80’s.
Manifold install
I actually got it all buttoned up last night, did the finishing touches this morning and able to drive it to my folks for thanks giving. I appreciate the input yall! Now go spend time with your loved ones. Weather it’s a Jeep or family, go spend it! -
Happy thanksgiving yall! Eagle is up and running so its gonna be a good one today.
Manifold install
I agree. Although what’s incredibly odd is I usually have to fight the lower bolts, but this time I didn’t. All threaded in just fine. Either this car likes me or I just got lucky. -
Manifold install
actually I only sweared maybe twice. I was able to jam a big flat head in between 6 and it moved the space enough for me to get 5 bolt in. And then I was able to get 6 in. Time to eat and do the lowers…yay. -
Manifold install
That’s what I thought. I didn’t know if anyone had a trick for doing this. I know it’s the same situation with the 2.5L. Patience and prying. -
Manifold install
Those are fancy. I need some of those. But what about getting the bolts in while the the exhaust manifold is too close and can’t get a bolt threaded? -
Alright my 4.0 brethren, let’s talk about manifold installation on specifically the I6 family. How are y’all getting the bolts in and get it to bolt up? About to fight with it tonight on the Eagle, I’ve got most of the top row in minus the ones are the back of the head.
Windshield washer pump
Haha no problem! I’ve done it maybe about 4 or 5 times now.
