boxyjeep
Contact Methods
  • Website URL
    https://boxyjeep.com
    South Orange County, CA
boxyjeep's Achievements
MJ Junkie
MJ Junkie (6/11)
  1. Cameron Hill in Apple Valley can and will do this for a reasonable fee. Recently had him install on my MJ.
  2. Yes, need to update website. keep an eye out
  3. EGR plate and adjustable FPR can help. The ECU is just so bad you need to “tune” around it. I’m running a 4.6L Renix stroker. It I had to do it all again, I’d 110% go LS.
  4. Good chance the needle has over-rolled. Rotate it counterclockwise by hand and see if it works properly thereafter.
  5. This! I almost want to buy this cluster for myself lol
  6. That looks about right. They are a tight fit
  7. Share some pics of how you installed it--it may be backwards.
  8. Scuff with 3M pad extensively. Clean with acetone. Self-etching primer. Then black top coat. I’d do semi-gloss or flat.
  9. The screw packs that I sell will work. Along with the MJ B pillar caps.
  10. We did stop making these.
  11. I stock a few of these. Take a look. https://boxyjeep.com/products/84-96-gauge-cluster-bezel-clear-acrylic-cover
  12. Thanks! I haven't tested it on the B-Pillar but believe it should work.
  13. Screw assortment: https://boxyjeep.com/products/interior-screw-assortment-jeep-xj-mj Caps: https://boxyjeep.com/products/interior-trim-bolt-hole-caps A Pillar Retainer Fix: https://boxyjeep.com/products/a-pillar-trim-repair-domes
  14. Sold all of them locally in 1 day minus the gold diesel and my original blue. These things go fast!
  15. Selling off some of my tailgate collection to fund other projects. Located in Orange County California (southern CA). $200-300 each depending on condition (excluding the mint diesel tailgate--$800 obo for that). Will include one of the BoxyJeep Wall Mounts as well if you want it.
