ghetdjc320
  1. I can add the info the the tailgate separation write up I did last year. I think it’s buried somewhere in the mods and repair section. If you want to move it to the diy area, I can add the info there
  2. It’s pretty straight forward. 3/16 rod, 7/32 holes carefully lined up. But unless someone tears apart their tailgate and adds support structure, there is no good way to add the locking pin guides which are crucial to not putting the strain on the actuator. I tried using the 1/8 rod that comes with the actuator but I could have easily opened the gate by force. The 3/16 rod just doesn’t allow for any play in the handle and it’s the biggest rod the actuator would accept. You’d probably end up bending the handle before shearing the lock pin. Going to tie it in with the door locks. It will be a nice addition to the locking hard retractable bed cover. There should now be a fully locked secure cargo area!
  3. Electric tailgate lock. High powered actuator, 3/16 locking pin with beveled guide. The pin is guided by 3 pints of contact before going through the actual handle. The handle has almost no play when locked and the actuator arm doesn’t have to bare any of the pressure from the locking pin due to the guides. And yes, you can replace the actuator through the tailgate handle hole. Though there is no way to build the additional pin guide without tailgate disassembly.
  4. Oem bumper straightened and trued. Took lots of heat and an air hammer for a few spots.
  5. Had to really dig for this picture but the MJ handled this no problem. That was at least 3k. No trailer brakes either and plenty of hills and curves in traffic. On a side note, that’s the kind of tongue weight it took to finally level those general spring 4 leaf packs setup soa against the rubicon express 5.5” coils
  6. X2 on the CO2. You can just use air in it but you will need much more than 150psi to be useful. CO2 is a much better way to go though
  7. I have an original oem receiver hitch I might be letting go. Not positive though yet. The most solidly built setup though imo is to have the receiver directly in the aftermarket bumper. Dirt bound does not do that, theirs in an add on that hangs onto the bumper mounts. JCR used to make them but have since stopped. Hansens will make them but you have to call them to request it. Every once in a while krusty makes a batch. You may find one on Facebook also.
  8. The NSG370 has an integral bellhousing. The actual location of the cps has been a non issue for conversions with the HO flywheel since it uses 3 sets of equally spaced reference points and the CPS was just at the next set of marks. I know Renix also uses 3 marks equally spaced but I’m not sure if their position is the same as the HO.
  9. 31’s on a 3.5” lift always seemed like the ideal setup on an MJ to me. You can still run stock flares, have a pretty stock ride experience but gain some good ground clearance overall. My last MJ was about 6” lift with 33’s but the new one I’m building is 3” on 31’s
  10. Started into the cut and polish.
  11. No not professionally. Restoration has just been a family hobby.
  12. This paint has a ton of pearl and metallic so shooting it all at once is preferable to have uniformity across the panels and gaps. Since I’m doing mine in sections, I’m shooting a final “guide” coat where I drop the gun pressure and increase the distance to essentially shoot a fine mist of texture that will settle into the partially flashed base coat. That helps keep things nice and uniform when shooting individual panels with these types of paints. Imo, the number one benefit of tearing these apart to this level is to repair all of those horrible factory seams
  13. X2, it was there on my 91 just kind of tucked away in the harness.
  14. And to think I had two in good shape no one seemed to want. Chucked them to clear space maybe 2 months ago
  15. All the ones I’ve had I drilled several large holes on the rubber then hit the shell with an air hammer to collapse it inward. There is a bit of access to the shell where the spring eye wrap comes together. The bolts also tend to completely seize within the inner sleeve and offer require cutting.
  16. Good points. I’ve noticed that the seams is where I’ve always had issues. Factory seam sealer was 1k air dry and cracks with age. There is seam sealer in the bottom of both window frames on each corner and I suspect that to be a big factor. I removed all the factory seam sealer in the window frames along with most of the cab. Got down to clean metal, epoxy sealed it and used a 2k seam sealer. Either way though, the factory urethane should have been applied straight to the primer.
  17. Whatever you go with, make sure to follow the procedure for break in. Make a big difference in performance
  18. The window sealing surfaces have been taped off now. Almost no body shops follow this practice but window urethane is supposed to be adhered only to epoxy sealer/primer per the TDS. Even the factory ignored this. There should be no base or clear under the urethane.
  19. It may have been powder coated. It’s hard to tell for sure since the entire wheel was clear coated. No idea on color, just wanted to share a pic of the end result. I had these done professionally from a company in TX and I’m not sure what they used.
  20. These are my restored turbines. The gray was painted, spokes polished and entire wheel clear coated.
  21. There are some XJ kits that cover most items. Changing the bushings in the leaf springs and control arms is quite a challenge. I’d recommend just replacing the arms since they are cheap. You’ll likely need an air hammer for the leaf springs.
