ghetdjc320
  1. Any part with the term “Comanche” in it is demanding a premium. As Pete mentioned though, who knows if they’re selling for those prices.
  2. Gears will be the best mod for a seat of the pants increase. And forced induction is typically the best bang for the buck if you want the engine to make more power. Having modded several 4.0’s now, I can say that most mods do not produce an appreciable power increase.
  3. There are so many bolts in that pan you’ll be fine. A good permadry gasket will take care of most any minor imperfections.
  4. Supposedly Napa still has them in stock but I spoke to Bosch directly and they discontinued it 2 years ago. I asked if they still had any of the other parts in the kit but they were unable to find any.
  5. Depends on your budget. if you can, give us a number and we can give suggestions. There are also some strategic installation techniques that can help. As a tule of thumb, you want to prevent the sound from the back of the speaker from interfering with the front. This is particularly an issue with the b pillars if you decide to install speaker there.
  6. I noticed the Bosch 69302 was a very similar size but had a plastic adapter/spacer. If you could find that part, I bet it would adapt these smaller turbine pumps great.
  7. Cargo lamp looks good! Nice and bright right?
  8. Looking good! Looks like the exhaust pipe is a bit oval in some areas?
  9. Good to know. I'll stick with a fine grit on the air file then hit it with some high build.
  10. ghetdjc320
    Tailgate
    Indeed, we have a bit of a write up on it plus I have some more detailed pics on my build thread.
  11. Been looking for a long time trying to find NOS chrome metal door handles. Found both now
  12. I used the same foam as the factory blower motor seal. It’s 1” thick “minicel” foam
  13. The “park” setting is purely a function of the motor itself.
  14. The power door/window switches are from a 2dr XJ 94-96 I believe as they are all black. Looking forward to trying you panels out. I plan on sanding them smooth and finishing them in the factory texture to match the interior.
  15. The novak or any other new ax15 for that matter is just a new tranny from Aisin. There’s no real upgrade aside from some minor tweak of the gear material which never were a strength issue. The parts Marlin manufactures for these are substantial upgrades but require a complete tear down as listed above. Here are the parts from Marlin Crawler: https://www.marlincrawler.com/transmission/parts-upgrade The “R” series parts are applicable to the AX15. The bearing retainer and thrust washer are the key strength upgrades but the shift forks are a nice complement for a built tranny also. Been thinking of sending them an ax15 core for a rebuild and have them add those components. Just not sure
  16. My original thoughts were wild but I need to wrap things up soon to get ready to ship out. Was thinking of a pair of w7 subs with the boxes built into the bed. Not sure how I managed to whittle my way down to a little 6.5 sub lol
  17. Have you seen what Marlin does with these tranny’s? They’ve been pounding 550 lbft of torque through their builds through KOH, Baja and the drag strip. The ax15 gearset is quite impressive across all the years but the 1st gear thrust washer and the rear bearing retainer plate upgrade really increase the torque ratings apparently. The Marin crawler board has a ton of tech in these trannys in their Japanese model numbers: R150/151f and the R154 in the Supra. https://board.marlincrawler.com/index.php?topic=103716.0
  18. @Minuit has been at work behind the scenes on the head unit. But it will be completely stock looking. Going to be running a DSP (possibly the JBL 8 channel). If I use the JBL it will be setup as active crossover on the front components, band pass on the rears and the last two channels feeding 60w @ 2ohms to each voice coil of a small 6.75” sub inside the oem center console. My TJ rubicon had a center console sub as well which is where the idea came from. It’s by no means going to be an all out spl build at all. It should just be a good sounding well rounded out system for daily driving. The DSP amplifier allows me to really tweak the sound and even “time align” the speakers. The DSP along with some specific installation techniques really do make a massive difference in the sound quality of the system.
  19. Yeah I’ve rocked plenty of similar setups but I couldn’t go with something like that on this build. The MJ cab is a bit tricky to get to sound right. When it’s all said and done though, you won’t see this system at all and it will look completely stock.
  20. Audio: after more research than a sane person should do, I settled on a pair of KS series Kicker component 5.25’s up front and 4x6 rears. Tough to find speaker with just the right physical and audio specs for this system. I went through all the Morel lineup, Focal, Infinity, JL and others. I’d don’t like the sound of any of the Focals I listened to. The Morel sound is excellent in pretty much the entire lineup but the physical size specs didn’t meet what I needed. The Nano Virtus series would have worked depth wise but I would have needed to cut a larger hole in the door panel. The goal is to keep everything completely stock looking. So I’m going with Kicker KS components, in the doors, tweeter in stock accusound locations in the knee panel, coaxial speakers on the b panels. I’ll be doing a lot of dampening work with all the panels and will also be working on isolating the front of the speakers from their backs which is a big issue in the b pillars. For amplification I’ll be going with a DSP amplifier and adding a 6.5” sub to the stock center console in a very stealth custom box. Just want a clean factory style system. Something that would have been installed if Comanches were still around today.
  21. An option if all else fails: https://www.quadratec.com/products/72503_800_07.htm They also have most of the other grill pieces if needed.
  22. We’ll call it a “traction aid”
  23. Have you tried the 5000x series? Rancho had a pretty bad rep until they made these shocks. They are truly a great shock for the price.
