ghetdjc320
  1. My dash unit only uses a single din and there was more space in the dash where the old hvac control went. It was much easier to mold everything in place by moving the head unit down. If you see my thread on that project you’ll see the pics I took and the problems I ran into. Definitely worth it though!
  2. I don’t have access to Facebook marketplace over here either so I can’t see the parts that pop up there. I do search outside of the conus though.
  3. And I’m in Guam lol! Very rigorous searching I suppose. I will mention though that I’ve been starting to search global supplies. Suffice it to say, I’m grabbing them up as I find them.
  4. Found a NOS matching black passenger side so that one will be for sale shortly in the classifieds
  5. Suspension: rear soa with 4x4 4leaf packs (would like to swap a couple of leaves out for some xj ones to lower the back a bit. front RE 5.5 coils full Artec bracketry for my original non-disconnect Dana 30 jks track bar Moog ZJ steering linkage (will upgrade later but not sure with what) RRO control arm brackets metal cloak control arms all new moog bushings
  6. Here is my modified dash. Tried to keep the overall look as oem as possible. Most of the time when I see this swap they remove the center vent. I have a whole new ac system and want every vent to work as it should so there was no way I was going to remove it
  7. A hint of things to come! I really appreciate all original build also but like I mentioned, this is a Resto-mod. I want to make sure every factory option works as it should and that every part is like new. However, I am adding some special touches along the way. I want it to be a clean build though. Kind of reminiscent to the reproduction CJs and FJs that are being custom built.
  8. At the paint shop getting some much deserved body work
  9. I’ve though about just turning the chrome one into a black version but I can’t bring myself to do anything to that original survivor.
  10. Or I would trade both for a new set or all red tail lights. Seems like the chrome one is one of the rarest especially NOS
  11. Here is my truck when it showed up at the port after crossing the Pacific Ocean and also when I dropped it off at the body shop
  12. Hello all, Been meaning to start my build thread for some time now but haven’t had a chance. I’ve already finished a lot of work on my truck but will try to document all the work I have already done and add what I’m doing now and still plan to do. The truck is now at my home on Guam so getting NOS parts and having access to specialty tools is difficult but not impossible. A little history: I bought my MJ in November of 2017. I can’t count how many Jeeps we’ve had before the first my first one I remember was a 1988 xj wagoneer. I sold my YJ in December of 2017 after having built that thing into a stroker powered show rig. I picked up my MJ at night in the dark from a guy on the Illinois side of the St Louis MO area. Was listed as a 92 and was pretty rough. Aside from the seats and the dash, there was no interior to speak of. Thick rubber floor mats covered over rusted out floor boards. The outside had been painted with rattle can bedliner. At the time I was living in Arkansas and I started stripping down the truck to repair body work first and stop the rust. After working on the body and cutting out and replacing rusted panels, I started working on the engine. Turns out someone had swapped in a renix block and head but used the HO intake and fuel injection components. It was a mess and ran terribly. To make a long story short, I decided to build high performance 4.0 engine. I had built a couple of strokers in the past and was pleased with the results but ultimately, not that impressed. Other guys who were building 4.0s were getting close to stroker HP/TQ numbers and to build a stroker right you really need to use the long 4.0 rods imho. So I started building a high performance 4.0 with the plan to one day boost it. Here is the basic engine build info: 96 XJ block with 200k+ miles (This block is the first year of the revisions for NVH) bored .060 and decked .025. Edelbrock aluminum head, roller rockers, hylift johnson lifters, cloyes roller cam set, 505 stage 1.5 cam (do not recommend 505 for anything but the final product was good quality and is a decent profile for boost). Melling HV oil pump Silovilte hypereutectic pistons 11cc dish ARP bolts for everything Coated cam bearings King main and rod bearings NEW 4.0 crankshaft not undersized Cometic .040 head gasket (.037 quench) felpro permadry gaskets 99+ intake manifold 24lb injectors accel coil Block was align-honed and blueprinted. Rotating assembly completely balanced I had some awesome pictures of the engine but of course I can’t find them anywhere now. Here is a spec sheet on what else has been done. Body: Spadano rockers JCR vanguard front bumper Bullet Lined JCR MJ rear bumper Bullet lined Bed Bullet Lined Napier MJ Flares Here is where the mod part of my resto-mod comes into place. My MJ is currently in the body shop getting every panel straightened to perfection. It will receive several coats of Aston Martin cinnabar orange. Also had a 1969 mustang mach 1 hood intake grafter into my hood. new windshield with 97+ XJ molding Interior: was able to find all the interior trim pieces at a salvage yard in TN and get most of the original gray interior trim pieces. My interior is originally the two tone gray with black accents and I’m keeping it that way while fully restoring it. Being an Eliminator I had quite a few factory options like: fog lights, full length center console, rear sliding window, bucket seats with flip forward levers and many other options. Here is a summary of what has been done: reupholstered seats back to original Dynamatted interior after replacing floor pans new auto custom carpets with mass backing new headliner restored all the trim pieces and repaired any cracked plastic with plastic welder new rubbers for doors Now for the mod portion of my build: reworked the dash bezels and layout to accommodate a Sony car play double din unit with backup cam (see my write up here in the diy section). new infinity reference speakers for all stock locations new interior map lights refurbished all under dash lighting and wiring to make sure every original option was working as it should Transmission was in good working order so I just did a flush and fill with new filter and added some seafoam trans tune. Transfer case I rebuilt and added double card an driveshafts front and back. Rear axle is the original Dana 35 but I installed revolution 4.56 gears, revolution chromoly shafts, Detroit truetrac, all new timken bearings and seals and a TNT truss. I know many will knock the d35 but after having built and worked on many axles, I just don’t feel like much is gained going with a stock d44 vs what I built. I have addressed most of the D35 weaknesses and am conservative with tire size. I’ll post up more info shortly along with some pictures and my future plans.
  13. I have a pair of new in box tail lights I need to match. The drivers side is the black trim version and I am looking for a passenger side black trim version. I have a chrome trim version that I want to trade for it. I know it’s a long shot but I know several of you have nos tail lamps. Hopefully we can trade to make two complete sets
  14. If you actually pick up the Currie or Synergy steering systems you will see exactly why they cost what they do. The most economical steering that is solid would be a ruff stuff specialties or similar DIY kit but you need to be able to weld well enough to trust your life with those welds. No matter what you decide to get, do not cheap out on steering (or brakes for that mater). Few other components are as crucial to your vehicle while driving. Currie and synergy make the same y link setup as stock but with much beefier components. They also angle the rod ends so you don’t have your steering limiting your down travel. No reaming or modifications are required but 6” of lift would be about the max. If you go with crossover or high steer you will need to modify components and will have to ensure that your track bar and drag link are parallel with each other (there is more to it than that but those are the basics).
  15. 2K rattle can clear is decent stuff. You need to figure out what it is. If it’s ink, try using rubbing compound, if it’s paint you may not be able to remove it without damaging the base coat. If it nail polish, get some nail polish remover. Just a few ideas
  16. That’s a good kit. The Currie system is similar and a solid system. I run Moog ZJ components right now but would like to setup crossover steering again later
  17. I built my own crossover steering with heims and it worked great with no dead spots. There are so many factors to steering and getting it right. There are also lost of different systems available. What’s your lift and tires size?
  18. I do though it is a bit rough. Is there a thread about these somewhere? Or do you know what material is used to replace the little “flappers”?
  19. Thanks for the input! I’ll throw that in the sketch book for the next build
  20. Hello all, just wondering if anyone has installed this system and/or has any feedback: http://www.boostwerksengineering.com/BWE-Comp-Mount_p_14.html
  21. Hello all, Looking for the cab vent inserts for my MJ. Let me know what you have. Thanks!
  22. https://www.copart.com/lot/59817719
  23. I had the originals vector traced and posted the file here on the forum somewhere. This guy could use those as a template since it would be precise
  24. Tough to compete with all the NOS parts hoarders so I have to grab anything I can lol
  25. That would be me lol. The same day I found another NOS twilight for the passenger side listed on eBay under the old AMC part number. I now have a new set of MJ tail lights on Guam! My MJ is in the body shop getting absolutely every panel straightened and perfected. I’m doing a tricoat paint job and when it’s done I’ll install the tail lights
