Replacement door hinges
ghetdjc320 replied to ghetdjc320's topic in MJ Tech: Modification and Repairs
On Guam, dealership is a no go for me -
Never mind, found some! Thanks -
Awesome! How can I get some? Is there a resource for finding and ordering these? -
Where can I buy one of these?
ghetdjc320 replied to KANTANKRUS's topic in MJ Tech: Modification and Repairs
Yep, that 90 can be found at almost any auto parts store On the shelves by the vacuum hoses. -
That’s what I was wondering as well. I saw the sets for the rear doors and they look the same when looking at the pictures. Perhaps someone could shed some light on this. -
I replaced my drivers side door hinges and added the reinforcement plate. Works great and was able to find the oem hinges from teamcherokee.com. Now my passenger side is going out and would like to do the same thing but can’t find any hinges. If anyone knows where to get an oem set that would be great. If not, what hinge pins will fit if I rebuilt it?
I can’t emphasize enough how much I like this mod. It works great and ads some real functionality. On to more electrical mods now!
True, but my license plate is mounted to my receiver hitch. I mounted the backup cam just below the tailgate handle and it works perfect there
Here are the final results. Everything works excellent and the center vent blows plenty of air. Plenty of trimming needed but all in all not to bad. I did not need to widen the opening for this head unit so I have about a 1/8” gap but it looks just fine and very clean.
Anyone have some hinges out there?
Thanks! Just waiting on the equipment now for the install. Going to mount the backup cam to the tailgate if i can get it to look clean enough.
I also picked up some adhesive backed felt at Home Depot (yep we have one here on Guam!) for the vents. It works awesome and takes up and slack or flop in the vents
Ok so here is an update. The conversion is ready to go. I must say, there is a lot of small things to mod but you can keep your hvac controls, center and install a double din unit. Here are some pics:
Just got the springs in from JW Jeep. Not to bad a shape. Knocked out the bushings and cleaned them up really well. Sprayed them with rustoleum industrial gloss black. Hope to have them installed by tomorrow. Thanks!
I’ve been looking for a good switch plate too. I think I might have a sign company make a new one for me.
Need of pair of door hinges for my 91. It’s the passenger side. Managed to find a new set for the drivers side but now the passenger side is going out and I can’t find any more.
There is no “lens” in the cargo light. They are a single piece of clear plastic. Everything but the “lens” area is painted black. Just restored mine with a good headlight polish then repainted it. Looks like new
Worked on my under dash lights today as well as my rear b pillar lights. Trying to get all factory options working again. Also have an oem cargo light to add. The Sony receiver is on its way. Here Is a pic of what I’ve been working on
I’ve been tossing around the idea of moding the dash for a double din head unit. Used to have one in my TJ and really enjoyed some of the features (especially a backup cam). Most of the pictures I saw involved moving the hvac controls down and deleting the center vent. However, as has been noted, the center vent is attached to the plenum and if I moved the hvac controls there it would not seal the plenum back up. I would also loose the center vent and I actually really like that vent. So instead I decided to move the hvac controls to the top and move the radio to the center. I plan on running a Sony CarPlay headunit like the ax1000 which has a single din frame but a double din screen. I’ll post pics on how I will install this setup. I plan to retain the center vent as well but move it down about 1/2”. Should be a good clean oem looking mod when done.
that pretty much sums up why I want to do custom gauges as well. That and accuracy
Speakers, speakers, and subs?
ghetdjc320 replied to Wounded_Fighter's topic in MJ Tech: Modification and Repairs
Will do! Contemplating a dash and sound overhaul -
Thanks for the ideas! I’ll check into building a custom piece
Thinking about an alpine Halo setup... still in the contemplative phase though -
Looking at putting in a set of auto meter gauges in my 91 mj. I’d like to do all 6 dash gauges. Has anyone ever fabed up some sort of panel or mount for this?
My plan is using 5.25 component speakers (morel or JL). Will be mounting the tweeters in the door panel and the b pillar panel. There are 4x6 to 5.25 adaptors for the rear pillars (common adapters for tj dash speakers). Head unit I’m not sure about the head unit but I definitely want to do double DIN. A pair of 10” JL subs and amp. My entire interior was dynamated after I replaced my rusty drivers floor board and coated them. Used ACC carpet with a heavy mass backer. New windshield seals and door baskets. Cabin is nice and quiet so should make for a good tune. Although it’s true you can find “cheap” consumer electronics, you still get what you pay for up to a point.
